Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-08-2004, 11:27 PM   #1
jelton
Member#: 72168
2000 25RS
Exclamation 00' RS-New motor CEL Code = Misfire
HELP, I just got a brand new ej25 bottom end installed, with exedy clutch + flywheel, Borla Headers , Apex-i exhaust, UR pulleys, and Magnacore plug wires. The CEL keeps coming on so I replaced the coil pack because #3 had some corrosion on it. Then 2 days later the CEL came on again, but it still reads that there is a misfire on all four cylinders. My car inspection is in 2 weeks.
jelton is offline   Reply With Quote
Old 10-08-2004, 11:47 PM   #2
iON Performance Inc
Vendor
Member#: 7673
jelton - Make sure you do the cam timing correctly. So it'd be best to check there first. Otherwise; you may want to put back your old crank pulley.
iON Performance Inc is offline   Reply With Quote
Old 10-08-2004, 11:49 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
The light weight flywheel could also contribute to the misfires, causes imbalance in the crankshaft. OBDII misfire monitor uses crankshaft imbalance to determine misfires.
Jay
Old 10-09-2004, 04:55 AM   #4
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
I say its the flywheel as well.
RyansJDMgc8 is offline   Reply With Quote
p0304 misfire code on startup/idle...new motor JT's06sti Built Motor Discussion 16 04-06-2009 04:01 AM
Engine CEL Code Misfire rexrook Newbies & FAQs 4 08-06-2008 03:53 PM
4 misfire CEL codes at once? help justboosted02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-19-2006 06:03 PM
FS: Cobb cold air intake 00' RS, seized RS motor etc..... egytian2.5rs Private 'For Sale' Classifieds 11 11-27-2005 06:34 PM
FS: Cobb cold air intake 00' RS, seized RS motor etc..... egytian2.5rs Rocky Mountains Impreza Club Forum -- RMIC 0 11-25-2005 10:58 PM
