#1 |
Member#: 7958
Vehicle:09 GH B+ |
This is relatively new technology that gets considerable more light out of the same watt bulb.
The oem hihg beam 9005 (65 watts) produces 1700 lumens of light, the "new" 9011 HIR bulb (same watage) produces 2350 lumens- almost 40% more light! The catch- they are expensive (the cheapest I've found is for the Chevy Avalanche ~ $25/bulb). The other catch is the base has to be modified slightly to fit- very easy, did mine w/ a flat file in ~ 10 minutes both sides. Instructions here: http://www.scoobymods.com/forums/sho...&highlight=hir differences in base isn't much: 40% is a difference you can clearly notice at night- well worth the $50 and ten minutes ![]() Big Sky
#2 |
Member#: 36255
Vehicle:04 WRB WRX Drive 2 Work,Work 2 Drive |
Did you get the bulbs from a dealership or online vendor?
Interesting mod, had seen it previously on scoobymods but I thought the bulbs would be too expensive since the post said they come from a Viper. Viper = expensive. |
#3 |
Member#: 70234
Vehicle:MY86 BMW E30 325 SCIC/NWIC tranplant (-_-) |
i'd like to but i never use high-beams
#4 |
Member#: 8023
Vehicle:2004 2.5 RS |
I am using these bulbs and they are excellent. However
I simply removed the round plastic bulb retaining ring on the headlight (3 screws), inserted the bulb and replaced the retaining ring. The bulbs helped recapture the kind of lighting I was use to with my STI in my RS. I am not entirely sure if a current STI owner would see a difference. For me any improvement in night lighting is worth the cost. |
#5 |
Member#: 15773
Vehicle:2011 Impreza WRX Silver |
are there HIR bulbs available for the 02-03 crew?
(9007 i believe..) |
#6 |
Member#: 8023
If the 9007's are the dual filament type then I doubt it.
Here is a link to Daniel Stern lighting as would be the person to ask. He's good about answering emails and is a well known vendor. http://www.danielsternlighting.com/ |
#7 |
Member#: 54594
This looks very interesting. I'd love to see actual pictures of the light difference. I'd be much obliged if anyone could post some pics.
Where did you guys buy these bulbs? I don't really want to go down to the local Dodge or Chevy dealer; I prefer to make my purchases over the internet. Thanks. |
#8 |
Member#: 8023
I bought mine from Daniel stern lighting as shown in the link I posted. I just emailed him giving him all the details about my car including the current stock bulb type. I rarely give bulb recommendations because it is so subjective but these bulbs are excellent.
However two things. The STI with it's HID low beams and Stock high beams is pretty powerful and I doubt an STI owner would see a difference (they may but I don't know). Secondly I cant make any statement about longevity because I have had them for only 3 months. |
#9 |
Member#: 57264
Vehicle:2004 18g Wagon - WRB PDX Tuned - 329whp/315wtq |
anyone try this?
http://www.scoobymods.com/forums/sho...=4305#post4305 |
#10 |
Member#: 39620
Vehicle:2008 Lexus ISF |
lemme get this straight, these bulbs are only for high-beams. When is driving with high-beams on legal???? just curious. thanks!
#11 | |
Member#: 8023
Yes they are only for high beams in a subaru. |
#12 |
Member#: 7958
Vehicle:09 GH B+ |
Interesting never lookd at how the "rings" were captured- that might make it easier yet- simply swapping rings.
A 40% increase in lighting (lumens) is pretty significant. It's more light than many of the 100 wat bulbs are putting out (w/o melting your lamps). Funny- I run almost exclusively high beams at night, ofcourse about the only oncoming traffic is on four hooves ![]() Big Sky |
| Thread Tools | |
| Display Modes | |
| quick question, do you really need to drain the coolant when intall turbo? | VajraTLR | Factory 2.0L Turbo Powertrain | 9 | 12-29-2005 12:20 AM |
| Ok, now i really need to get the front bumper on. | Rentalpillow7 | Southern California Impreza Club Forum -- SCIC | 10 | 04-28-2004 12:55 AM |
| We really need to find the right cure for this hesitation problem | imprezawd | Normally Aspirated Powertrain | 6 | 09-05-2002 12:45 AM |
| do I REALLY need to replace the flywheel? | racerwad | Transmission (AT/MT) & Driveline | 8 | 11-01-2001 08:06 PM |
