Old 10-09-2004, 09:09 PM   #1
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Default Cobb Cai
I installed my CAI last week, and i notice that the black filter piece is extremley close to a metal piping of some sort. Will this rubing or banging against it cause damage?
Also there is a rubber tube which holds what looks like the throttle wire.
This is being pushed down under the filter will the stretching of this cause
problems?
kevin2.5rs is offline   Reply With Quote
Old 10-09-2004, 10:10 PM   #2
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
I guess im the only one out there with a cobb CAI?
I also notice that 2nd gear is not as powerfull as before
i find myself shifting into 3rd at 35 mph
Old 10-09-2004, 11:11 PM   #3
roffle
Member#: 42251
uh oh
trumpet butt
the "metal piping of some sort" is likely your AC line
(is it less than 1/2 inch in diameter and shaped very rigidly?)
it might rattle, shouldn't be an issue though. I actually tensioned my CAI nearer the fender using duct tape
on my engine the throttle wire is on the other lateral half of the engine, so it is not an issue, but I think in your case that's not what it is. The throttle wire should not be covered by rubber..
roffle is offline   Reply With Quote
Old 10-09-2004, 11:38 PM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I have a Cobb CAI. My Legacy has an Intake Air Temperature sensor, which is just a probe that plugs into the intake. Not sure if this is what you're talking about.
I gained power everywhere.
Try resetting your ECU. Unplug the batter for an hour or so...search for more details.
DLC is offline   Reply With Quote
Old 10-10-2004, 12:06 AM   #5
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
I noticed the power didnt seem as sudden with the CAI, but more even through out the power band. Did you reset the ecu? if not, then do it this way. Disconect the negative battery terminal, then depress the brake pedal about 5 times to drain any power out. then connect the neg battery terminal and go for a spirited drive.
Crash477 is offline   Reply With Quote
Old 10-10-2004, 05:35 PM   #6
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
I took apart the CAI and reinstalled it to align it better.
But it still pushes this tube w/ wire in it down.
The wire comes from a 4"x7"x2" box on the side of the passenger strut.
travelsacross the engine and to the intake manifold.
after receting the ECU is it normal for the car not to stall.
I have done this 3 other times now, the first time the car stalled 2 times
but every time afterwards it just boged a little than ran fine.
Old 10-10-2004, 05:53 PM   #7
rsti02
Member#: 71329
2002 rs
is there any indication on when the ecu has been reset?
rsti02 is offline   Reply With Quote
Old 10-10-2004, 06:27 PM   #8
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Nope. Just leave it unplugged and use the brake-drain method.
Old 10-10-2004, 08:22 PM   #9
valenti01
Member#: 69331
2001 impreza 2.5rs
blue
I know my 2.5 second gear gets my to around 50mph or a little more, i definitely could feel the power. One thing might be the flash program may need to be updated, i know i was running way to right and the CAI was a very low sound, after i got my flash program updayted, i got even more power. Wires, i had no prob with rubbing or anything, just the silocone tubing at the fender kept moving, i fix that with with wider silocone piece and a clamp. hope that helps
valenti01 is offline   Reply With Quote
Old 10-10-2004, 08:26 PM   #10
piker28
Member#: 22664
take a picture, i dont know about anybody else but i have no idea what your talking about
piker28 is offline   Reply With Quote
Old 10-10-2004, 09:38 PM   #11
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
http://forums.nasioc.com/forums/showthread.php?t=597777
There is a good picture where you can see the wire im talking about.
Old 10-10-2004, 09:42 PM   #12
piker28
Member#: 22664
okk....
so whats the problem? its not doing anything but just resting there
Old 10-10-2004, 11:37 PM   #13
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Yeah I dont get what your talking about either.
I too can go to about 50-55 mph in 2nd gear, and about 70mph in 3rd.
SOLD! Cobb ELH & HFC, Borla resonated SS catback, Cobb CAI mrpedal 1993 - 2001 Impreza Specific Parts 6 10-27-2009 04:28 PM
FS: 00-04 Cobb CAI, or WTT: Cobb for Stock dRu888 1993 - 2001 Impreza Specific Parts 0 09-08-2007 09:26 PM
WTT: Cobb CAI for ur Ganzflow CAI ommmjido Bay Area Impreza Club Forum -- BAIC 0 11-05-2004 03:55 AM
Cobb CAI, Borla headers, Brullen cat-back, Unorthodox UD pulley, Cobb Spicy cams. yamarocket630 Car Part Reviews 2 12-21-2001 02:58 PM
Cobb CAI Review Stavros g Normally Aspirated Powertrain 2 05-14-2001 09:17 AM
