Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-09-2004, 10:48 PM   #1
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
Default used vf30 without oil and coolant lines - can i use stock lines?
just purchased a used vf30 without any lines for $250. the seller said i can use the stock td04's coolant and oil lines without any problems. can anybody else confirm this? or should i purchase new lines? so can i swap all of the stock turbo's lines to the vf30 for the install?
i also heard that you should upgrade to 1step colder plugs when ungrading the turbo. i'm looking to go cobb stage 2.5 (i have the vf30, sti pinks, and walbro fp ready to go).
thanks for your help guys!
anthonyrb98 is offline   Reply With Quote
Old 10-09-2004, 11:12 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Yep.
Old 10-09-2004, 11:17 PM   #3
anthonyrb98
Member#: 48307
02 bugeye
sweet
FS: EWG Dump Tube (straight), Replacement turbo oil and coolant lines with washers ScoobyNubieToo! Engine/Power/Exhaust 10 02-15-2009 08:26 PM
Oil and coolant lines Chi_San Service & Maintenance 1 08-24-2008 12:13 AM
oil and coolant lines scoobyimprza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2003 01:01 PM
Can you use a lightened crank pulley and LTW flywheel can you use them together? M3toWRXin3seconds Newbies & FAQs 4 03-12-2003 09:10 PM
Turbo missing oil and coolant feed lines? S-1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-04-2003 07:12 PM
