Old 10-10-2004, 03:25 PM   #1
left footed whooten
Member#: 44652
06 WRX
16 Colorado Duramax comin
Default pop goes the timing belt
hi there, just popped a timing belt on my 96 impreza ej18. Can the ej18 sustain a broken timing belt? I cranked it briefly after it cut out and it semmed to spin alright, but i figured it was common knowledge as to whether a broken belt on this engine is curtains. pushing up daisies. I believe the cause was a seized idler pulley or water pump or tensioner or something, as something was screaming at me from in there as a valiantly tried to make it to school for a test. So if anyone can fill me in as to whether you can generally get away with it, and if you need a special tool for the tensioner or anything,id be very grateful. got lots of tests to study for, even though id rather be playing with my car.
east bound and down
dylan
left footed whooten is offline   Reply With Quote
Old 10-10-2004, 03:36 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Should be fine. I had one break on my ej22T, I tried to turn over the car and then took it in and had it replaced. Motor is fine.
EDIT: forgot to add that using a screwdriver in the bell housing is hard. I bent a craftsman screwdriver and had a hell of a time getting it out after I was done. I recomend getting the tool from subaru for 70 bucks. It should make life easier.
subiekid is offline   Reply With Quote
Old 10-10-2004, 04:23 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
It'll be fine. You'll need a press or vice for the tensioner, though.
jamesfacts is offline   Reply With Quote
Old 10-10-2004, 08:19 PM   #4
chip4761
Member#: 55867
2005 Saabaru
AS
Somebody at a foreign car garage told me once that the ej18 was an interference engine. I told her she was wrong. She got offended. I guess people who are "always right" don't like being told they're wrong.
I'll tell you, though. If you can find an excuse to take the engine out, the job will be WAY easier.
chip4761 is offline   Reply With Quote
Old 10-10-2004, 11:23 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I think pulling the engine to change the timing belt is overkill. Obviously you want to determine which part failed and replace it. A new belt will have alignment marks on it to make life much easier. Depending on mileage, now is the perfect time to replace water and oil pumps, and all the seals.
Tim Sanderson is offline   Reply With Quote
Old 10-11-2004, 02:53 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
If it went anything like mine, the waterpump had been squealing for awhile and you naive-ly told yourself it was a loose belt because it would sometimes go away after things warmed up. Then one day it squealed like crazy so you turned up the radio vowing to tighten the belt as soon as you got a chance. But before you could say "oh crap", the squealing stopped with a bang that wasn't metallic, followed by a flashing CEL and abrupt loss of "power"(in quotes because we all know the 1.8 has no power to begin with).
If this sounds familiar, you will be fine to just replace the waterpump and timing belt. It would be wiser to replace the oilpump and seal while you're in this deep. Also flush the coolant because the shavings of aluminum are evenly distributed along the flowpath.
I went the other direction and fibbed to my better half. I told her it was an interference motor and that the valves were bent and likely had piston damage too. So I put in a "project" EJ25 that I built up mildly after abandoning a nice little supercharger setup not unlike a prototype SPT setup.
For not a whole heck of alot of work, you can swap in a 2.5 and run it off the current ECU using your current sensors. It's being done by many folks tired of looking way too far down the street to see if it's safe to pull into traffic.
Jay Storm
Old 10-11-2004, 10:48 AM   #7
bobko
Member#: 64646
1995 Legacy wagon
Green
Default Replacing the timing belt
You can replace the timing belt yourself if you have a decent set of hand tools and some time. It's not the easiest repair by a long shot, but it can be done by a shadetree mechanic. The good news is that there is a tensioner that will maintain the proper belt tension once you get it all back together.
I concur about replacing all the things that are easily replaced once you get the belt off. The hardest part for me was getting the bolt off the end of the crankshaft. There is a special tool for it, but nobody where I live (including a couple of Subaru dealers) would rent or loan the tool. I resorted to using a couple of bolts and a breaker bar to hold the crankshaft pulley as I twisted off the bolt. You will need to compress the tensioner in a vise and having an extra pair of hands around for that is helpful. Otherwise, it's all pretty straightforward... just be sure you get the crankshaft and camshafts lined up to the correct marks.
--Bob
bobko is offline   Reply With Quote
Old 10-11-2004, 10:56 AM   #8
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
FWIW, I used a C-clamp on my tensioner. To break the crank pulley bolt loose I put a cheater bar on the breaker bar and laid it on the frame rail, then I bumped the starter. Bolt broke free with no trouble.
nunyo is offline   Reply With Quote
Old 10-12-2004, 08:12 PM   #9
left footed whooten
Member#: 44652
06 WRX
Default thanks
nice everybody,
music to my ears. she's gonna get quite a rodgering after midterms i say!
dylan
Old 10-12-2004, 08:29 PM   #10
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Timing belt that no longer times
As mentioned above, a C-clamp will suffice to push the tensioner back in. A really small allen wrench to hold it in is good too (2mm I think?) Make sure you leave the handle/bend out so you can remove it. If you replace the crank seal, which you should, you can drive it in with a peice of PVC pipe (2.5", 3" I forget). Hmm, an extra set of hands for tightening the cam sprockets (58 ft-lbs) with strap wrench will help. Sadly, I resorted to the breaker bar/pipe on the frame method to get the crank pulley bolt off (130 ft-lb or 94 ft-lb), but I have a 4EAT so cut me some slack . www.endwrench.com has some help, and there is plenty of other info as of the past 3 months.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 03-20-2007, 09:32 PM   #11
xride63
Member#: 132596
1996 impreza
red
my 3j18 is reaching the 120k mark and i understand the timing belt is estimated for 60k. at least thats what the dealer preaches. i am about to buy a belt from the dealer for $59.99 and i wanted to buy a new tensioner. how important is it to replace the tensioner or are they re-usable? on my dsm i always replaced them for fear of them failing on an interference motor. do a lot of you 1.8 and 2.2 guys reuse your original tensioner? if so thats great news because the dealer wants some $122.00 for a new tensioner.
this seems like a straight forward process. I'm guessing i can remove the radiator once i drain the coolant and pull the timing belt covers. then i assume I'd loosen the pulley and pull the tensioner. then remove the crank pulley and belt line the dowels put the belt on with the corresponding marks and shlapp her back together.
are there any other tricks with these motors and is there enough room to get in there with just the radiator removed? this is the first thing I'll have done on the car short of an oil change. any help or tips are welcomed. it seems like this will go similar to my Mitsubishi.
-thanks.
p.s. is there a good place to order a belt ($60) and or tensioner($122) that would save me money? does the dealership price sound out of hand or should i stick with the genuine parts at that price? any suggestions or any experience with the matter is also appreciated !
xride63 is offline   Reply With Quote
Old 03-20-2007, 09:41 PM   #12
SLI99
Member#: 134819
2005 Ford F150 FX4
haha i love the title of the thread
SLI99 is offline   Reply With Quote
Old 03-20-2007, 11:51 PM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
I't alsways best to replace the tensioner but if you take your time compressing it (and it isn't already borked) you can re use it. Check the bearings in all the tensioner pulleys. When in doubt, replace them. Removing the radiator/fans is all the room you'll need, besides the battery if you want somewhere to put your tools.....
How you break the crank pulley bolt loose is up to you...but it's not fun with halfassed tools. A long breaker and good socket will make short work of it if you keep the flywheel from turning too. I use a pinchbar through the top inspection cover. An Air gun works even better when the radiator is out too.
Other than that, it's pretty straightforward.
Jay Storm
Old 03-21-2007, 05:13 AM   #14
hitter
Member#: 144009
Your NASIOC Administrator
oh what a post
hitter is offline   Reply With Quote
Old 03-24-2007, 01:56 PM   #15
xride63
Member#: 132596
1996 impreza
red
thanks. sounds like it'll go smoothly if thats all the room i'll need.
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
Pop goes the end link bolts TheLegacy Tri-State Area Forum 9 06-20-2005 12:00 AM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
Pop goes the tranny! Conduit Transmission (AT/MT) & Driveline 7 02-03-2003 11:33 AM
Pop goes the rear bluey Newbies & FAQs 3 01-23-2001 07:43 PM
