Old 10-10-2004, 03:32 PM   #1
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
Default Help.......Need torque specs
Can anyone give me the torque specs for a 98 2.5 cylinder head ?
Thanks
Barry is offline   Reply With Quote
Old 10-10-2004, 04:25 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I'm interested too...
jamesfacts is offline   Reply With Quote
Old 10-10-2004, 09:01 PM   #3
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
ok here is the sequence
step 1- 22 ft lbs
step 2-55 ft lbs
step 3- loosen all bolts 180 degrees
step 4- loosen all bolts an additional 180 degrees
step 5- center two bolts only 27 ft lbs
step 6- all others to 132 ft lbs
step 7- tighten all olts to an aditional 90 degrees
step 8- tighten all bolts an additional 90 degrees.
It is very im;portan that you follow these steps very very closely. If you don't serious head warpage or gasket damage WILL occur
Russell Rogers is offline   Reply With Quote
Old 10-10-2004, 09:11 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
no mention of oiling the threads on the bolts? Pretty sure you need to.
Old 10-10-2004, 11:17 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
And you need the correct pattern.
Tim Sanderson is offline   Reply With Quote
Old 10-11-2004, 03:00 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Exclamation
Oh LORD YES!!!! Do not use the LOOSENING sequence to TIGHTEN the headbolts. You'll scratch your head wondering why on earth Subaru wants opposite corners of the head torqued tighter than the rest. It all makes sense when the center bolts are torqued correctly.......
We'll see if Cometic's "reusable gaskets" really are. Since the motor hadn't run with the wrong torque values.....I'm keeping my fingers crossed!
Jay Storm
Old 10-11-2004, 05:59 PM   #7
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Okay I wish you guys would have actually posted how you think it should be done. I was merely helping......
Old 10-11-2004, 07:47 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Your right, I should have added useful info instead of acting like an armchair mechanic. I will do that asap.
Old 10-11-2004, 08:11 PM   #9
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Cylinder Head Torque
I've never had a head off, but here's some info on installing a DOHC head. However, I think this came from the 2002 Impreza?? It doesn't give you a specific torque spec, but just the 80 degree angle B.S.
-Charles-
ImprezaVA is offline   Reply With Quote
help!need torque specs for manifold to head bolts twinz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-01-2010 04:55 PM
Help! Need Torque Specs Eagle Rods okiedude Built Motor Discussion 2 02-26-2008 09:00 AM
help need torque specs for tranny mount install SpoolinUp Transmission (AT/MT) & Driveline 2 03-25-2004 10:26 PM
HELP! need torque specs scoobin' Mid Atlantic Impreza Club -- MAIC 2 09-07-2003 12:19 PM
Help! Need torque specs for '02 WRX wagon susp. parts! NETWRX Brakes, Steering & Suspension 2 08-16-2002 08:43 PM
