Old 06-21-2001, 03:18 PM   #1
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Question Graham Goode vs. STI short shifters
I am looking for a short shifter that is about that same height as the stock RS shifter. It looks to me like the lever that comes with the STI complete shifter/linkage kit is. I thought the Graham Goode shifter was the same as the STI and it looks very similar, but when they are laid next to an RS shifter the STI looks to be the same overall length and the GG looks like it might be shorter. I have an RS lever in my Outback right now, and I don't really want the shift knob to get any lower than it is now (which rules out most of the short shifters). I have a line on a GG at a good price, but I would like to confirm that it is about as tall as an RS shifter
Thanks, Doug
Edit: spelling
dvancleve is offline   Reply With Quote
Old 06-21-2001, 03:41 PM   #2
JGard
pooptastic
Member#: 1904
2013 Tundra
'02 BMW R1100S
get the Cobb or STi replica from larry.
they are not with the linkage, therefore, not too expensive, and the stick is actually as long as, if not slightly longer than, the RS shifter.
but don't worry, the throws are significantly shorter...
JGard is offline   Reply With Quote
Old 06-22-2001, 02:19 AM   #3
Rubasu
Member#: 1418
MY00 2.5RS
save some money get the Kartboy and the bushings. They rule. i have had them in for over a year now and still love the throw...
Rubasu
Rubasu is offline   Reply With Quote
Old 06-22-2001, 02:35 AM   #4
elemental
Member#: 2701
'00 obs
it was compared a little while ago and the stock RS and the STi were identical except for the stick... linkage was the same if i recall correctly, might as well save the money, thats what im gonna do, sti replica or kartboy and bushings, not sure yet
elemental is offline   Reply With Quote
Old 06-22-2001, 10:02 AM   #5
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Cool
Thanks guys. I am sure Kartboy's shifters are great, but like I said I don't want one significantly shorter than the stock RS (it would put my hand too far below my elbow when I use the armrest :^). I just want the throw reduction. I am not considering the shifter with linkage, but just the shifter (probably from somebody who switched to Kartboy).
Doug
Old 06-22-2001, 10:10 AM   #6
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Default You're not listening
The Kartboy isn't lower. It's the throws that are shorter. This is accomplished my moving the linkage up the shift lever.
see:
photo credit to Scoobymods.com
skidplatez is offline   Reply With Quote
Old 06-22-2001, 10:35 AM   #7
JGard
pooptastic
Member#: 1904
2013 Tundra
'02 BMW R1100S
yes, the Kartboy is DEFENITELY lower.
I've driven cars with both. It's very noticeable when driving it...
AS for the RS and STi being the same... ONLY the linkage is the same. The shifter is different, therefore giving shorter throws. That is the reason why I suggest the STi replica or the Cobb, because it's just the stick, not the linkage.
Old 06-22-2001, 10:42 AM   #8
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Default ?
skidplatz,
Thanks, but the picture you posted shows is being about 1/2" shorter :^) I really wanted to keep the shift knob about where it is now...
Doug
Old 06-22-2001, 11:41 AM   #9
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
If you look at the picture again you will see that it looks lower because they are centered on the linkage not the ball which is the bottom of the shifter. From the ball to the top it is only a very small amount shorter if any.
Old 06-22-2001, 01:32 PM   #10
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Have a Nice Day? You're right!
skidplatz,
For some reason I was thinking that the linkage pivot point was what determined the height (even though I have changed one of these out before). You are, of course, correct in that that ball is the fixed point.
Doug
Old 06-22-2001, 02:01 PM   #11
JGard
pooptastic
Member#: 1904
2013 Tundra
'02 BMW R1100S
*decides to chime back in*
Again, when actually installed, and you use a Kartboy, you will feel that it IS a bit shorter than the stock shifter arm.
The ball is the fixed point, yes, but it doesn't matter.
Your best bet, go to a meet, and you will find one of each installed in people's cars. You can then decide for yourself.
Old 06-22-2001, 02:03 PM   #12
jlyttle
Member#: 2815
2004 Forester XT 5sp
Get a cheap shifter like the Kartboy or (in my case) the STI replica from Cobb or imprezars.com
If you then find the shifter to be too short, get a different shift knob to fix that. Much cheaper than spending $250-350 on a setup that you don't need.
jlyttle is offline   Reply With Quote
Old 06-25-2001, 02:45 AM   #13
Firewire
Member#: 3430
2007 2.5i Wagon
Garnet Red
Looking for a short throw shifter huh? Well, why don't you guys check out this site:
www.rev-labs.com
The shortshifter they have is very nice. I have this one and the shifts are short and crisp. I really love driving with it. Check it out!
Firewire is offline   Reply With Quote
Old 06-29-2001, 07:57 PM   #14
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Thumbs up Wrap up
Well I got a Graham Goode shifter for a good price and swapped out the RS shifter I had in my Legacy Outback. The GG is actually a little bit taller than the RS which is great for me; I definitely didn't want anything shorter. Wow! The shifting is now very short, notchy and positive. I think I picked up a little bit of a humming/buzzing through the shifter with the swap. I also have the Cusco bushings. It isn't very noticeable so I don't mind. I am happy
Doug
Old 06-29-2001, 09:53 PM   #15
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
i actually had a shifter long enough to take a picture of it. All 4130 ChroMo, CNC turned.
i put one in my car and i like it even better than the older ones. they weigh a touch more than the OG ones. i think the extra weight makes it shift even better. silky smooth and ooo so short
tom@kartboy.com
www.kartboy.com
06 WRX TR Stock Short-Shifter vs. Aftermarket Short-Shifters tangmonkey Transmission (AT/MT) & Driveline 10 01-27-2009 11:37 AM
Pics Inside of Stock Shifter vs Kartboy Short Shifter Height skivvie Transmission (AT/MT) & Driveline 5 06-12-2003 05:00 PM
Vivid short shifter VS sti short shifter carpetsloth Transmission (AT/MT) & Driveline 2 08-29-2002 07:20 PM
sti vs. kartboy short shifter takumi Normally Aspirated Powertrain 3 07-01-2001 03:07 PM
Message Board Statistics All times are GMT -4. The time now is 05:28 AM.
