Old 10-10-2004, 09:47 PM   #1
stoney98
Member#: 65888
2010 FXT
Default P0301,p0302
I"ve searched, and found nothing conclusive to what would cause them to throw. It went sitting at idle warming up in the morning. I've noticed when driving WOT around 4-5K that my enginge tends to hesitate a bit.
Question is what does it take to fix said problem. I'm at 15K stock everything 03 TS. I'm figuring it's the sparkplugs, so that is my next course of action.
Am I wrong in this? Also what is sugested as good sparks? Daily driver, I'm looking for longevity morre then performance.
thanks in advance.
-stone
stoney98 is offline   Reply With Quote
Old 10-11-2004, 12:26 AM   #2
kiltjim
Member#: 60002
2000 Impreza OBS
Running at OC'ed 900MHz
Cylinder 1 and cylinder 2 misfired, respectively. Sounds like fun...
kiltjim is offline   Reply With Quote
Old 10-11-2004, 10:52 AM   #3
stoney98
Member#: 65888
2010 FXT
I know that it's a cylinder misfire. I'm assuming plugs would be the first place to start looking to correct this? Along the same line of questioning, what is a good set of plugs for longevity, not performance?
Old 10-11-2004, 12:36 PM   #4
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Also check plug wire ends and the coil for any corossion. When was the last time spark plugs were replaced?
-paK +2
Pakin is offline   Reply With Quote
Old 10-11-2004, 12:58 PM   #5
stoney98
Member#: 65888
2010 FXT
never. How do I clean the corrosion off the wire ends and coil if there is any?
Suggestions for good plugs?
Old 10-11-2004, 05:55 PM   #6
stoney98
Member#: 65888
2010 FXT
beuler? beuler?
Old 10-11-2004, 06:07 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
How much miles on the car? If it's around 30K-ish, change 'em plugs. If there is corossion, you can clean them off using a wire brush lightly if it's not too bad and some debuffering liquid/pads. I persoanlly just replace them so if there were any problems internally, I would not have to deal with them.
As far as plugs go, I just use OEM. I use the plat tip plugs for the EJ25 DOHCs, but those get changed every 60K.
-paK +2
P0301, P0302, P0303, P0304 questions slvrwrx02 Warranty Issues & SOA Problems 30 09-28-2007 02:51 PM
P0301, P0302, etc tkbailey Engine Management & Tuning 1 08-03-2004 10:38 AM
P0301, P0302, PO130...Please help/look AndyM Normally Aspirated Powertrain 11 12-05-2003 01:36 PM
P0301, P0302, P0304 Narcisse91 Tri-State Area Forum 7 05-23-2002 07:40 PM
Misfires- P0301 P0302 P0303 P0304 AndyHidley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-30-2001 01:18 AM
