Old 10-11-2004, 02:21 AM   #1
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
Have a Nice Day? 2.2 Intake?
I know there's probably a thread out there for this somewhere ... but I'm getting frustrated digging through everything and not finding what I'm looking for. I'm looking to get an aftermarket intake for my 97 Impreza 2.2 L, but nothing seems to be for my engine. Which other engines could I get and intake for that would fit mine as well? Also, are there any great deals or brands that I should look into? Sorry to anger anyone for being impatient ... I really have loooked .. and looked .. and looked.
Any advice would be greatly appreciated.
-T
spinmastert is offline   Reply With Quote
Old 10-11-2004, 04:59 AM   #2
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
You can make a 2.5RS aftermarket intake fit. It would be fairly simple. If you want to do it a cheap way, go to EBAY and pick up a cheap short ram "no name brand" intake. Or if you want quality, and stay smog legal, I would go with an Injen Technologies Cold air intake for about $260.
RyansJDMgc8 is offline   Reply With Quote
Old 10-11-2004, 10:18 AM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Nope. His car is MAF... those intakes are not compatable.
What I found is a nice MAF intake solution is this: Rip out everything in the stock intake but the airbox and MAF sensor. (Snorcus, resonators, etc...)
Drop in a K&N panel filter, then use some 1st gen Legacy intake tubing to go from the throttle body to the MAF sensor - its 3" and straight.
jamesfacts is offline   Reply With Quote
Old 10-11-2004, 10:46 AM   #4
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
Know of anyplace I can get the tubing you're talking about? I'd really rather just buy the intake and be able to slap it on ... do they even make short rams with MAFs orrrr ... no?
Thanks for the idea, if you could give me some detailed instructions, I'll look into it
Old 10-11-2004, 10:49 AM   #5
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
You could buy a Rallispec intake for a 98-99 RS . . . from me even. PM me if you're interested.
nunyo is offline   Reply With Quote
Old 10-11-2004, 02:18 PM   #6
Blue98leg
Member#: 65036
2013 WRX
Im pretty sure the 97 model has a extra thick tube connected right after the MAF sensor that ure intake wont fit.
Blue98leg is offline   Reply With Quote
Old 10-11-2004, 03:42 PM   #7
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
The intake replaces the tube. The MAF bolts onto a MAF adaptor. I'll double check on my wife's OBS later. The bolt holes will definitely line up because the airboxes are interchangeable, I used the stock airbox from my 99 on her 96 for a few weeks. The only visible difference is that the MAF electrical connectors are different.
Old 10-11-2004, 04:56 PM   #8
jamesfacts
Member#: 51282
98 RS
I can... I wrote a big thing up once. The piping is easy to get at any junkyard, and the best part is all your vac lines mate up.
Old 10-11-2004, 07:27 PM   #9
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
If you would PM me or mail me that would be great :-P Any info would be good. So you know what I'm looking for .. I want the intake sound, and obviously performance to tag along with it
Old 10-11-2004, 09:46 PM   #10
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Rallispec will fit a 2.2L.
Old 10-11-2004, 09:49 PM   #11
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
Sounds good to me
Old 10-11-2004, 09:52 PM   #12
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
"americanyouth Nope. His car is MAF... those intakes are not compatable."
I said you can "MAKE IT FIT". I didn't say it will be a direct fit. With a dremel, all you have to do it cut off about 4 inches of the intake for the MAF sensor to fit.
Old 10-11-2004, 11:52 PM   #13
imprezin04
Member#: 39482
2000 Impreza RS
SRP
i just got a maf adapter and connected it to a cone filter. you can try that. its still loud but im going to make my own piping. ill tell you how it works out if you are still looking by then.
imprezin04 is offline   Reply With Quote
Old 10-12-2004, 06:43 AM   #14
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
Default Rallispec
I think I'm gunna snatch up Nunyo's Rallispec, but yeah, let me know how it goes.
Old 10-12-2004, 08:28 AM   #15
Black_Rain
Member#: 29932
2005 LGT Ltd
Womp
Sorry if this is a hijack....but i am also looking for an intake... I just bought my 98 2.2L yesterday...and now i'm looking under the hood. I see all these tubes that jut out, they look like large "test tubes" and 2 airboxes.... are there two filters? also, is there a silencer in the fender like on the late model subs? Any info on the 2.2 stock intake would be much appreciated... Thanks and sorry for the hijak
Black_Rain is offline   Reply With Quote
Old 10-12-2004, 09:55 AM   #16
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
It is a hijack, but whatever. There are two boxes, probably only one of them has a filter in it. The test tube things are used to increase the volume of filtered air available to the engine. This helps low end torque. If you have a silencer, you will likely have an intake pickup right behind the passenger side headlight. Duct work will lead into the fender just in front of the airbox.
Old 10-12-2004, 10:25 AM   #17
TurboCharged97L
Member#: 71508
1997 Impretzia
Artic Silver Metallic
Default Weapon-R
go to www.weapon-r.com they sell intakes with everything needed to fit your 97 2.2L i have it you can get the dragon or the new top secret they are very nice with differant colors available mine is 3" chrome piping with a black filter
TurboCharged97L is offline   Reply With Quote
Old 10-12-2004, 10:38 AM   #18
jamesfacts
Member#: 51282
98 RS
It will run like poo, though, and blow MAF sensors. Trust me, I've had three intakes on my car.
Old 10-12-2004, 01:19 PM   #19
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I took the intake pipe between the MAF and TB out of a MY93 and put it in replace of my MY99. works great and has better flow. Vaccum lines seem to fall a little short i.e. drive side is 2 inches short. works great and sounds like an aftermarket pipe but looks stock!
FuJi K is offline   Reply With Quote
Old 10-12-2004, 02:03 PM   #20
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
Hey, if any of your ideas have instructions to them, could ya PM them to me?
Old 10-14-2004, 10:34 PM   #21
spinmastert
Member#: 72116
'97 Impreza 2.2t
Brilliant Red
Well .. nunyo sold his intake so it looks like I'm looking for something else. If anyone else is selling anything that would work with the MAF and everything, gimmie a PM.
Old 10-15-2004, 01:09 AM   #22
rabbitnutz
Member#: 51940
dude, go to home depot and get some PVC piping for about 30 bucks. it will be "good enough" untill you can save up for a cobb.
rabbitnutz is offline   Reply With Quote
Old 10-15-2004, 01:51 AM   #23
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Before I bought the intake, I removed the intake silencer in the fender, and used a K&N panel filter in the airbox. Pretty good gains. In fact I'm using that setup in my wife's '96 OBS.
Old 10-15-2004, 02:16 AM   #24
Black_Rain
Member#: 29932
2005 LGT Ltd
Womp
^^^nunyo...how hard is it to remove the silencer?
Old 10-15-2004, 04:44 AM   #25
scottzg
Member#: 42618
pull off the wheel, take off the fender lining (that black junk under the fender) and you'll see a funny shaped tube-box. This is what you take off. You may need to take off the airbox to get to one of the screws, im not sure. That's easy, there's just 2 screws at the base of the box.
The legacy 3" piece is easy to obtain at any pick and pull salvage yard. it goes from the maf to the throttle plate.
scottzg is offline   Reply With Quote
FS: 2.2L heads ported by Fuji K, 2.2L Intake manifold, Cobb CAI, Custom test intake Back Road Runner Engine/Power/Exhaust 2 04-14-2010 02:23 PM
any difference between 2.2 vs 2.5 intake killah Newbies & FAQs 0 07-16-2009 12:26 AM
1996 2.2 Intake on 2000 2.5 Odyknuck Subaru Conversions 1 01-22-2009 09:32 PM
Will the 2.5RS Cold Air Intakes work for 2.2 Ls subby00 Normally Aspirated Powertrain 4 07-09-2007 10:42 PM
Will intakes for the 2.5 fit the 2.2? Husker05 Normally Aspirated Powertrain 3 11-11-2005 09:46 AM
