Old 10-11-2004, 12:11 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default STi Intake Manifold on NA 2.5?
Just a question about the sizing and fit of an STi intake manifold. I know the 2004 NA 2.5 block is different from the STi's EJ257, but I was curious to see if the intake manifold would be a direct fit / swap onto a NA 2004 2.5
I was just hoping to let my TS breathe a little better with the bigger manifold. Will it cause any problems?
Thanx!
Bry.
BrysImpreza is offline   Reply With Quote
Old 10-11-2004, 02:20 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
There is no provision for the coil pack or the throttle cable bracket. You will also lose the holes for the injectors unless you use the tumble generator valves. Our n/a ecu's have no control for them so they will not open. You could use the tgv deletes and solve that problem, but then I think you would need a different fuel rail system.
The 04/05 us sti have coil on plug and throttle by wire.
By the time you add up the cost of making that work you could probably have it extrudehoned and powdercoated red.
Good luck
Tim Sanderson is offline   Reply With Quote
Old 10-11-2004, 02:49 PM   #3
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Shoot, I forgot the STi and FXT were throttle by wire, ah well.
I'll stick with the stock PLASTIC intake manifold
Old 10-11-2004, 03:05 PM   #4
nySulli
Member#: 32617
2008 STi
whats wrong with the plastic manifold, it has smoother inner walls, allowing for higher air velocity into the cyclinders, stays far cooler then a metal manifold would, cooler intake air, more hp, and its lighter to boot
theres not 1 disadvantage to having a plastic intake manifold, its actually a good thing
nySulli is offline   Reply With Quote
Old 10-11-2004, 05:05 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya, I'd take a plastic one.
Old 10-11-2004, 05:12 PM   #6
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
How about using a new plastic intake manifold in an old school impreza; would it fit, and would it provide any performance gains?
powerlabs is offline   Reply With Quote
Old 10-11-2004, 06:13 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Don't forget weight! . New Legacy GTs/ OB XTs have the plastic intake manifold and other plastic goodies
-paK +5
Pakin is offline   Reply With Quote
Old 10-11-2004, 06:33 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It's (i'm guessing) probably in the neighborhood of 5 pounds of weight savings. I think the benefit would be the smoother more consistant runners. The aluminum castings always have seems/flashing and are pretty rough to the touch. This may or may not create unwanted turbulence. I don't have a degree but something tells me that smoother is better in this instance.
Not sure if they would bolt up to older heads but I don't see why not.
Old 10-11-2004, 08:12 PM   #9
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Good luck
I always thought the STI didnt have TGVs?
subiekid is offline   Reply With Quote
Old 10-11-2004, 09:05 PM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I believe you are correct. I was mistaken in my first reply. I think the coil pack and perhaps the pcv and/or vacuum lines are different. And the fuel delivery problem.
Old 10-11-2004, 09:07 PM   #11
subiekid
Member#: 25516
and i think the mounting bolts are much different.
Old 10-11-2004, 10:03 PM   #12
Jejunum
Member#: 15773
2011 Impreza WRX
it would fit afaik, but theres a cheaper easier way to get most of the performance gains (new manifodl is $$$). hondata intake manifold gaskets & throttle body mod.
Jejunum is offline   Reply With Quote
Old 10-12-2004, 12:26 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
It fits on the 99+ SOHC heads. It will not fit the DOHC heads.....but an EJ20G manifold will!!!
Jay Storm
Old 10-12-2004, 08:44 AM   #14
nySulli
Member#: 32617
2008 STi
spacers will help, but even with spacers your intake manifold will still get warm from the surrounding air in time, however i can touch my manifold even after 2 hours of highway cruising
Old 10-12-2004, 01:38 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I have an STi v6 intake manifold that I would consider parting with for the right price. It was going to be part of my NA build, but $$$ are short these days. As Jay mentioned, any of the post '99 EJ20 manifolds will fit post '99 EJ25 heads. The only trick I can see is plug wires, as the coil pack is offset like the older EJ25's. I do also have the wires that I would sell with it. I have the coil pack as well, but unless you want to cut and splice the connectors, it won't work with your stock harness. If you have an interest, send me a PM and we will take it from there...
EDIT: I almost forgot, getting the rails to fit will take a little rigging. The holes are much larger than yours and a thicker O-ring would need to be sourced to make it secure and sealed...
Old 10-13-2004, 01:27 PM   #16
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
What about the 95 1.8L, ant plastic manifolds that fit that, also plastic is easier to modify to add things like NO2 and extra injectors.
Tbird Man is offline   Reply With Quote
Sti intake manifold on a NA Bluefoton Normally Aspirated Powertrain 11 03-09-2010 11:09 PM
STI intake manifold on 2.5 RS engine SubeSTIle Subaru Conversions 10 02-16-2007 03:15 PM
STI intake manifold on a 2.5 RS engine. SubeSTIle South West Impreza Club Forum -- SWIC 5 02-15-2007 03:18 AM
WRX Valve Springs/Retainers on NA 2.5 DOHC Heads? MY99 2.5GT Normally Aspirated Powertrain 2 02-06-2006 01:01 PM
WRX Intake Manifold on a 2.5 spoolinsuby Subaru Conversions 2 09-19-2005 11:17 AM
