Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 10-11-2004, 05:03 PM   #1
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default 92 legacy turbo wont start
well, i bought a 92 turbo that has 110k on it, it sat for the past 5yrs, i got it home and took it for a test drive and it had a nasty miss at high rpms, when i got out of the car i could smell stale gas, i tried to siphon the gas out but i couldn't get a hose in it, i decided to let the car just run out of gas cause it only had about half a tank, after letting it idle for about 6hrs over two or three days i decided to unhook the fuel filter and let the gas run into a jug, i got about 2gallons out of it, i drained the fuel filter of the bad gas and put new gas in the tank and now it wont start, i get fuel pressure past the filter but the car still wont start. any suggestions? thanks damon.
damonmlime is offline   Reply With Quote
Old 10-12-2004, 06:54 AM   #2
Member#: 68853
'02 WRX
what does the engine do when you turn the key?? does it turn over or nothing??
STIdreamer17 is offline   Reply With Quote
Old 10-12-2004, 02:27 PM   #3
Member#: 2204
99 Rally Impreza
team graphics
Did you check if you have spark? Set the plug gap to around .036
(new NGK plug won't hurt).
If the head gasket is blown you might be getting a bunch of water inside the combustion chamber.
While the plugs are out turn the motor over with starter to purge any water in the cylinders (disconect the igniter plug when doing this).
If you have spark-
Disconect one of the vacuum line that goes in to the intake plentum (just forward from the throttle body and dump some gas down it.
Plug it back in and try to start it again.
Good luck - Eric
ProRallyEric is offline   Reply With Quote
Old 10-12-2004, 05:11 PM   #4
Member#: 5796
2013 BRZ & 2004
one of us might be able to help if u dont get this.........
check us out forums.subyspeed.com , wvu's subaru club
mcu81 is offline   Reply With Quote
Old 10-13-2004, 03:27 PM   #5
Member#: 4083
2011 OB 3.6R
pull a plug and check for spark (hold plug next to intake manifold while cranking) . possibly the ignitor, coil pack, or crank pos sensor.
I had a no start condition with mine a few weekends ago - but it was the fuel pump.
subarurabbit is offline   Reply With Quote
Old 11-05-2004, 05:31 AM   #6
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
What about Ignition/EFI/ECU Relay?? No known faults over there???
sixpack subaru is offline   Reply With Quote
Old 11-05-2004, 11:42 AM   #7
Member#: 70345
pull the plugs and let it turn over a while, then clean the plugs and reinstall.
My bet is that it flooded badly when recovering from running out of gas, due to intermittent air / gas from the empty new filter and drained lines.
You really should change all the fluids, filters, plugs, check the compression, add a some dry gas additive to a fesh tank of new gas, at the very least. Your connectors for ignition and sensors should all be removed, cleaned and reinstalled with dielectric grease. That miss is probably moisture worked in somewhere.
plasticguy is offline   Reply With Quote
92 legacy L wont start spdracr00 Legacy Forum 8 12-09-2006 04:09 PM
My 1997 Legacy GT wont start! Project84 Normally Aspirated Powertrain 17 03-06-2006 06:09 PM
93 Impreza L AWD Turbo WONT START! animestore Subaru Conversions 14 09-21-2004 04:55 PM
92 Legacy Studdering on starts TheShadowWRX Normally Aspirated Powertrain 2 07-09-2003 06:34 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
