Old 10-11-2004, 10:41 PM   #1
dreaminsubys
Member#: 71579
1998 Legacy Outback
Question torque specs, 2.5 DOHC
Does anyone know the correct torque specs for the camshaft bearing caps on a 98 2.5 DOHC or where I can find them? My Haynes manual only gives the numbers for the 2.2.
Thanks in advance,
Pete
dreaminsubys is offline   Reply With Quote
Old 10-12-2004, 12:23 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
14 ft/lbs. I'll check again when I'm not at work and edit this if it's wrong.
Jay Storm
Old 10-12-2004, 01:34 AM   #3
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
FYI, go to your local library and pull up 'Mitchels' on Demand from the computer... anything you will ever want to know
Honkey3k is offline   Reply With Quote
2.5 dohc to JDM 2.5 dohc... Need Help! suby53 Normally Aspirated Powertrain 20 02-19-2008 07:00 PM
Making a 2.2 SOHC cam gear into a 2.0/2.5 DOHC gear reddevil Built Motor Discussion 0 03-12-2007 12:21 AM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Subaru Conversions 13 03-02-2006 04:49 PM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Legacy Forum 3 02-26-2006 08:38 PM
id 2.5 SOHC vs 2.5 DOHC? [email protected] Normally Aspirated Powertrain 5 04-13-2001 10:01 PM
