Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 10-12-2004, 09:21 PM   #1
Papa Smirf
Member#: 61702
1997 impreza l 2.2
teailish blue
Default Even more insane than dual charging
There has been much expirementation with using a turbo charger to create a gas turbine jet engine. My teacher has a friend who setup one of these engines to produce way more compressor stage flow than was needed to selfsustain combustion in the turbine end he then would bleed off some of this compressed air and feed it into a big block chevy. It ran something like 30psi of boost ALL THE TIME. Wretched fuel consumption but murdered the field so badly at the drag strip nthat they banned it. Imagine this kind of power with a car putting it to four wheels!
Papa Smirf is offline   Reply With Quote
Old 10-27-2004, 02:27 AM   #2
blacktalon606
Member#: 73316
30PSI of bleed air to a big block Chevy? Turbo turbines are notorious air hogs and there is no way you would get sufficient flow through one to self sustain and have that kinda air left over for a 2 liter engine unless the turbo was the size of a truck tire. A big block Chevy is gonna be a deep breather as well... I would like to see pictures if such a setup exists though.
blacktalon606 is offline   Reply With Quote
Old 10-28-2004, 05:35 AM   #3
ncarn8
Member#: 71419
i beleive it is possible however there are 2 things im not sure of
- 30 psi boost at all times must mean at low engine speeds(under load) this is well above the surge limit of any turbo and engines cannot run such high pressures at low speeds
-how do they cool it?
i have a book with a jet turbine motocycle in front of me and incase ure intersted the specs are
pwr 250kw @ 56000 rpm
577 nm @ 54000 rpm
compression ratio 40:1
2 speed auto or mnual
brakes 3x 320mm discs brembo callipers and N1 shaft disc brake
dryweight 240 kg
1/4 mile 9.3@ 284.4 kmh
top speed 402.3 kmh(money back guarantee)
price $261,863 AUD
man i gotta get me one of theese
ncarn8 is offline   Reply With Quote
Old 10-28-2004, 08:50 AM   #4
blacktalon606
Member#: 73316
Yeah, well a vehicle running off of a jet turbine, and a home made jet turbine providing boost pressure to NA engine is a little different situation. The motorcycle is basically the same idea as a turboprop or turboshaft airplane or helicopter. YOu use a turbine to turn a a shaft and tap that potential. Lots of small airplanes and helicopters use APUs off larger jets as an engine. They sure make a lot of power for their size but they suck gas like no other.
Old 10-29-2004, 10:16 PM   #5
Papa Smirf
Member#: 61702
1997 impreza l 2.2
teailish blue
Most anyone who makes a backyard jet engine uses a turbo that was setup for a car with a compressor suitable for the required boost characteristics for a car not for a jet engine. Their probably is enough shaft power to run an excessive compressor big enough to feed the jet and the engine.
The turbo is cooled by its own oil circuit resivor oil cooler pump
Old 10-30-2004, 01:26 AM   #6
blacktalon606
Member#: 73316
Ok...dude... Again, to supply 30psi to a big block chevy it would take a big turbo. To self sustain a backyard turbine it takes a pretty big turbo... to self sustain and provide 30psi this thing would have to flow A LOT!
Old 10-30-2004, 02:00 AM   #7
Basshead
Member#: 112
2011 Jetta TDI
ncarn - jay leno has one..go see him..
Basshead is offline   Reply With Quote
Toyota to create a car with even more splendid flavor than the Scirocco AVANTI R5 Non-Subaru News & Rumors 42 11-23-2009 06:50 PM
I keep resolutions for even shorter periods than Jackffr Davenow New England Impreza Club Forum -- NESIC 8 06-22-2005 09:15 PM
Dual Charging a 2.2t Papa Smirf Pre-2002 Factory Turbo Powertrain 21 10-22-2004 05:04 AM
Dual Charging Papa Smirf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-14-2004 10:36 AM
