Old 10-12-2004, 09:34 PM   #1
Red Rexx
Member#: 67187
2004 STi
Exclamation Big Problem With Accessport Connection...help Please!!!
Hey...I just purchased my AP for my 04 WRX. I installed all the software perfectly. When hooking up the AP to my computer, no "Sync to PC" option shows. I need to connect the AP to my PC so I can get maps!!! The COM1 port won't recognize it though. It's functioning properly...I need help ASAP so that I can remap! Thanks! What should I do???
Red Rexx is offline   Reply With Quote
Old 10-12-2004, 10:02 PM   #2
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
I had the same problem with mine. You first have to "marry" the AccessPort to your car and then it connects to the PC.
-Jason
jay25RS is offline   Reply With Quote
Old 10-12-2004, 10:24 PM   #3
Red Rexx
Member#: 67187
2004 STi
Hmm really....How do I do that?
Old 10-12-2004, 10:24 PM   #4
KGreb
Member#: 13463
2012 Chevy Volt
Try holding down both the up and down arrows while on the init screen. It should allow you to connect to a PC then regardless of whether or not its been married to an ECU. Saw this trick on Cobb's forums and used it last week.
KGreb is offline   Reply With Quote
Old 10-12-2004, 10:26 PM   #5
Red Rexx
Member#: 67187
2004 STi
Alright Ill give it a try in a few...Any idea on how to marry it if it doesnt work though?
Old 10-12-2004, 10:49 PM   #6
Red Rexx
Member#: 67187
2004 STi
Wow! The holding method works! Thanks Greb!!!
Old 10-13-2004, 12:22 AM   #7
bobondanet
Member#: 44399
2006 WRX Ltd
Steel Grey
Marrying it means installing a base map onto your ecu. Hook it up to your car first. You have to follow the sequence of the manual even though it doesn't tell you specifically to do the car first.
Great tip on the "arrows" stunt, THANKS!
bobondanet is offline   Reply With Quote
Old 10-13-2004, 12:31 AM   #8
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
problem solved...i love it
good luck with it!
Golfa is offline   Reply With Quote
BIG PROBS with utec delta!!! help please Ctracer911 UTEC 39 10-12-2009 04:05 PM
Big problem with red HVAC. HELP!! Manoxide069 Electrical & Lighting 6 01-30-2009 05:29 AM
BIG problems with a shop. Help please. EsTeaEye General Community 61 11-14-2007 09:39 AM
Big Problem with FMIC install....HELP please!!! lvfc_rook_1503 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-25-2007 11:21 AM
Big Problem With Accessport Connection...help Please!!! Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-12-2004 10:50 PM
