Old 06-22-2001, 12:54 AM   #1
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Default Help me choose a clutch!
Well...
I have 1999 Impreza 2.5 RS ..
Which clutch should I get?
I like ACT, but someone recommended ISR.
How much are these things?
STi Sev is offline   Reply With Quote
Old 06-22-2001, 01:06 AM   #2
oldpreza
Member#: 5259
1995 Impreza
there also Clutch Masters
oldpreza is offline   Reply With Quote
Old 06-22-2001, 01:49 AM   #3
preza
Member#: 1454
2000 2.5 RS-T
ACT sux ( i own one)
I would look into your other options such as clutchmasters and ISR
Old 06-22-2001, 02:17 AM   #4
Rubasu
Member#: 1418
MY00 2.5RS
Tha Act clutch is great. I have had the street setup in for a few weeks now and am loving it... And just a tip why you are replacing that clutch replace that pesky 26 pound flywheel with a much lighter one your scooby will thank you fir it....
Rubasu
Rubasu is offline   Reply With Quote
Old 06-22-2001, 04:10 AM   #5
preza
Member#: 1454
2000 2.5 RS-T
I have had mine for many many months, and im not very happy with it
Old 06-22-2001, 04:11 AM   #6
preza
Member#: 1454
2000 2.5 RS-T
but thats just me
Old 06-22-2001, 05:15 AM   #7
Shinji N
Member#: 3987
1999 Miata
Any explanations from the unhappy people.
Shinji N is offline   Reply With Quote
Old 06-22-2001, 10:03 AM   #8
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
I would be interested in opinions too. I've heard that the ACT clutch requires more pressure on the pedal....something that will suck in stop & go traffic and piss my wife off.
Is the lightened flywheel really worth the extra $500 expense?
Thanks!!
beethoven is offline   Reply With Quote
Old 06-22-2001, 11:37 AM   #9
Rubasu
Member#: 1418
MY00 2.5RS
The pedal action caused by the ACT clutch is not that bad. Geez. Once you get used to it in a couple of days you don't even know its there. The lightened flywheel is worth every penny, If you get the right type. I have the one from B-spec. It is designed with a majority of its mass towards the outside of it to ease startups, take offs, idle lumps which are generally caused by the type of flywheel with its mass mostly in the center. Again it takes a couple days to get used to the freeier reving mantality of the engine but once you are used to it you won't know its there until you look for it.......
preza -- just curious as to what your dislikes are
Rubasu
Old 06-24-2001, 04:33 PM   #10
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
bump-a-roony
Any thoughts on the ISR or Clutchmaster? Any reason to not go with ATC??
thnx
Old 06-24-2001, 10:48 PM   #11
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Yeah.
I need to get a clutch, so I need some opinions people!
Old 06-24-2001, 10:56 PM   #12
Rubasu
Member#: 1418
MY00 2.5RS
Like I said in the above posts . I love the ACT setup. The pedal feels a tad heavier until you are used to it. The engagement is quick and tight and takes little effort. Also this would be a good time to lose that heavy A$$ stock flywheel and get a decent lightened one. I am running a flywheel from B-spec. it weighs in at a hefty 11.22 pounds. It has a majority of its weight towards the outside to ease everyday drivability issues. pm if you have any other questions about it...
Rubasu
Old 06-25-2001, 12:32 AM   #13
tmaler13
Member#: 1992
And the benifit of a lightened flywheel is????????
what does it do for the car?
-Terry
tmaler13 is offline   Reply With Quote
Old 06-25-2001, 12:47 AM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
lighter fly wheel = less rotational mass
which means the car will spin faster sooner.. . helps a whole lot with turbo charged cars with their spool up time and other things.
Brad
STiTuner is offline   Reply With Quote
Help Me CHoose Clutch (POLL) Plz!!! Stikid04 Transmission (AT/MT) & Driveline 2 04-20-2008 08:31 PM
Need your guys help. Help me choose. Cosmic_Subie48 General Community 4 12-31-2007 09:59 AM
Sub: Help me choose which is right for me avsmusic1 Car Audio, Video & Security 5 05-10-2006 11:29 AM
Help me choose a clutch kit. legacy92ej22t Mid Atlantic Impreza Club -- MAIC 26 05-10-2005 07:27 AM
help me choose a clutch wrX-RTD Transmission (AT/MT) & Driveline 5 07-01-2004 11:52 AM
