Old 10-13-2004, 12:08 PM   #1
Rickyh
Member#: 40453
Default my first utec log. knock knock, who's there
yippeee. My first log. vf39 injectors turboback, stock ic, 18psi.
this is a 4th gear pull. I did this twice and I get knock around 5700 each time. doesn't happen in third. I let off the gas as soon as that lovely flashing light passed before my eyes. So what do you guys think?
5065 +18.0 4.2 103 80 00 rich +23.6 74.4 +21.0 -0.7 250.00 3.8
5027 +18.0 4.2 103 80 00 rich +23.6 74.4 +21.0 -0.7 250.00 3.8
5058 +17.4 4.1 102 80 00 rich +23.3 74.3 +21.0 -0.8 250.00 3.8
5136 +17.4 4.2 102 80 00 rich +24.4 76.8 +21.0 -0.9 250.00 3.8
5208 +17.2 4.2 102 80 00 rich +23.5 77.3 +21.0 -0.9 250.00 3.8
5232 +17.4 4.2 102 80 00 rich +24.7 78.0 +21.0 -1.0 250.00 3.8
5192 +17.4 4.2 102 80 00 rich +24.8 82.0 +21.0 -1.0 250.00 3.8
5333 +17.0 4.2 102 80 00 rich +24.5 77.9 +21.0 -1.0 250.00 3.8
5359 +17.2 4.3 102 80 00 rich +24.7 79.7 +21.0 -1.0 250.00 3.9
5411 +17.0 4.2 102 80 00 rich +25.0 79.9 +21.0 -1.0 250.00 3.9
5437 +17.0 4.2 102 80 00 rich +24.9 79.2 +21.0 -1.0 250.00 3.8
5455 +16.8 4.3 102 80 00 rich +24.9 80.9 +21.0 -1.0 250.00 3.9
5518 +16.8 4.3 102 80 00 rich +25.0 82.2 +21.0 -0.9 250.00 3.9
5537 +16.8 4.3 102 80 00 rich +24.9 79.8 +21.0 -0.9 250.00 3.9
5564 +16.8 4.2 101 80 00 rich +24.5 82.3 +21.0 -0.9 250.00 3.9
5688 +16.5 4.3 102 70 00 rich +24.9 85.4 +21.1 -1.0 250.00 3.9
5583 +16.5 4.3 91 80 00 rich +25.0 82.3 +21.0 -0.9 250.00 3.9
5668 +16.5 4.3 96 80 00 rich +24.8 82.3 +21.0 -0.9 250.00 3.9
5717 +17.4 4.3 99 90 00 rich +23.1 83.9 +16.0 -0.8 250.00 3.9
5678 +18.0 4.3 102 90 16 rich +20.5 85.1 +4.0 -0.8 250.00 3.9
5518 +15.7 2.6 0 00 00 rich +11.0 9.2 ecu. -1.0 250.00 2.0
5473 +9.0 2.0 0 00 00 rich +10.8 8.2 ecu. -1.0 ecu. 1.9
Rickyh is online now   Reply With Quote
Old 10-13-2004, 12:33 PM   #2
beaudawg
Member#: 57770
2005 Audi S4 Avant
Arctic White
Fuel looks good, so. . . too much timing.
beaudawg is offline   Reply With Quote
Old 10-13-2004, 12:33 PM   #3
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Hi. Do you have your Utec set to Gauge mode for the map sensor? You can check this in the perameters. If you have it set to absolute then you need to reduce your boost a bit. In my area going to gauge mode adds 2.8 psi to the readout. So that would put some of your boost logs over 20 psi.
What is your AFR? You did not include it in the logs.
Cya
Clark
Kingpin is offline   Reply With Quote
Old 10-13-2004, 02:09 PM   #4
Rickyh
Member#: 40453
My a/f never went over 10.5. i'll check the parameters.
*edit* It is set to gauge. egt's were right at 800. What should the knock sensitivity be set at? When I first got everything together it was showing knock all over the place. All of the knock sensitivity settings were 100 and over, so I put em all around 90.
Old 10-13-2004, 06:14 PM   #5
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Doesn't look too interesting - pull a degree or two of timing and see what happens. Is there any reason to suspect that there's something funky going on?
Also, your transition from the 80 to 90 column of 5 degrees is probably something you'll feel at least some of the time. Might want to try to smooth that out if you can. (have it step down by 2 degrees at a time from one RPM or Load site to the next, instead of 5)
It won't happen in 3rd because there's not enough load. I'll bet there's a decent amount less boost in 3rd at 5700.
serendipity is offline   Reply With Quote
Knock, knock; Who's there? STI_KLR Mid Atlantic Impreza Club -- MAIC 42 03-17-2009 12:48 AM
Knock, knock; who's there? STI_KLR South East Region Forum 61 03-14-2009 05:38 PM
My first ECU logs WebMasterP Engine Management & Tuning 1 09-29-2008 05:04 PM
My first UTEC log, with problem! AspenGC8 UTEC 6 11-11-2006 11:09 PM
Take a look at my VF22 UTEC log? 03WRXMA Engine Management & Tuning 12 07-02-2004 05:51 PM
