Old 10-13-2004, 04:35 PM   #1
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Default TPS Adjustment
Anyone got a link to the procedure?
OneOBS is offline   Reply With Quote
Old 10-13-2004, 04:46 PM   #2
kiltjim
Member#: 60002
2000 Impreza OBS
Running at OC'ed 900MHz
Didn't you get the memo?
I'm sorry I couldn't resist. And unfortunately, I have no idea what you're talking about.
kiltjim is offline   Reply With Quote
Old 10-13-2004, 05:39 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
PM MYfirst00... I think he's got it.
jamesfacts is offline   Reply With Quote
Old 10-13-2004, 05:41 PM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
I thought this was dubbed a bad idea?
LetItSnow is offline   Reply With Quote
Old 10-13-2004, 08:53 PM   #5
SpeedbeeqS
Member#: 26664
1999 Impreza 2.5 RS
I think that it is a good idea to adjust it once in a while. I drove my car for 2 years running with a TPS that only had 4.1 out of 5.1 volts. I had a hell of a time trying to get something to activate at WOT when it only put out 4.1 volts. It's funny how many people I beat on 4/5 throttle.
SpeedbeeqS is offline   Reply With Quote
Old 10-13-2004, 09:15 PM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
LOL!
Wow, who gave you that info? The only TPS I've ever adjusted was on a 1994 SVX and that was when I messed it up by doing so. I don't have any directions man, sorry!
Old 10-14-2004, 12:17 AM   #7
jamesfacts
Member#: 51282
98 RS
Originally Posted by OneOBS
LOL!
Eh... I knew had needed to do it at one point!
Old 10-14-2004, 08:28 AM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
So, somebody explain this one already!
orndog is offline   Reply With Quote
Old 10-14-2004, 09:42 AM   #9
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Unless you have the 4-pin TPS, you don't need to adjust anything.
The TPS is simply a potentiometer that is hooked up to the throttle plate. As the throttle is opened, resistance is changed. That information is sent back to the ECU to know what position the throttle is in.
The reason I say it's not necessary to adjust the TPS is that the ECU will take a reading of the TPS's resistance at startup. It then uses that as it's "throttle closed" benchmark. If you adjust the TPS while the car is running, you can make the idle go up and down. If you leave the TPS adjusted so the idle is high, turn off the car and turn the car back on, the idle will return to normal.
However if you adjust the TPS too far, its readings will be outside the set limits in the ECU, and the ECU will throw a CEL.
On the 4-pin TPS's they had the idle switch in the TPS as well. The newer cars have a separate idle switch. So on the 4-pin TPS's you would adjust the TPS based on the idle switch to make sure it's readings are correct.
here's the test procedure. Last scan tells you how to adjust the TPS via the idle switch
http://www.main.experiencetherave.co...S_testing1.jpg
http://www.main.experiencetherave.co...S_testing2.jpg
http://www.main.experiencetherave.co...S_testing3.jpg
Legacy777 is offline   Reply With Quote
Old 10-14-2004, 10:43 AM   #10
orndog
Member#: 34670
2013 No gears!
Saltine American
Wow, cool! Thanks!
Old 10-14-2004, 11:12 AM   #11
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Cool, thanks. Its exactly what I needed. Its not the TPS I need to adjust. Its the idle switch.
Old 10-14-2004, 11:56 AM   #12
Legacy777
Member#: 4800
Here's the diag pages for the tps from the 02 fsm.
It's not really super helpful IMO. For the idle switch circuit you want to use the first two scans I believe.
http://www.main.experiencetherave.co...PS_testing.pdf
Why do you want to adjust this? Are you having any problems?
Old 10-14-2004, 12:32 PM   #13
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Surging off idle. Its not a problem in normal driving, however if I am backing out of the driveway (in gear at idle RPM or a tad more), the car surges real bad.
Old 10-14-2004, 02:46 PM   #14
Legacy777
Member#: 4800
Hmm.....does it happen only when cold, or when the car is warmed up?
You have the 2.5 liter motor correct? What octane fuel you using?
Old 11-03-2004, 08:18 PM   #15
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I tried the procedure posted above last weekend and it doesn't work. Pins one and two are not the idle switch (nor do any other combinations of the other pins prove to provide continuity when the throttle is closed).
I do, however, seem to have fixed my surging off idle problem with a new air filter. The car only has 6500 miles on it. Go figure.
Old 11-03-2004, 09:48 PM   #16
Legacy777
Member#: 4800
hmm....maybe the sensor is different for non-turbo and turbo engines?
Old 11-04-2004, 02:12 AM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
adjusting the TPS on a 2.5 motor is blatenly a BAD idea, trust me, tried it, the car flips out with even .05 extra volts at idle. Leave it alone it's preset at the factory
Old 04-08-2005, 08:54 AM   #18
figgskzoo
Member#: 82547
2010 Forester
Default TPSs [B]do[/B] require adjustment.
NOT... Bad logic, plain and simple.
Consider the blockhead that depresses his throttle 1/3 of the way down before he turns his ignition on.
Are you going to try to convince me that 1/3 throttle is now assumed to be the 'throttle closed benchmark' for the ECU. I should say not.
Read the service manual. The ECU uses the voltage in the TPS feedback loop to interpret throttle position, simple as that. 1.2v and under, the ECU assumes idle. As the voltage in the feedback loop approaches 5v, the ECU then sees WOT. Simple as that.
figgskzoo is offline   Reply With Quote
Old 04-08-2005, 09:10 PM   #19
Legacy777
Member#: 4800
So you dug this thread up to tell me I'm wrong. Hmm....I said nothing about the blockhead who holds the throttle down. Yeah if he holds it down and then releases it, the ECU will know what's going on and adjust.
What I'm specifically talking about is moving the position of the TPS by loosening the screws that hold it to the TB. I'm talking moving it several centimeters at most. There's no need to do this, due to how the 3-pin TPS is setup.
I've done what I've said on the car....so I know what I say is not BS....so say whatever you want....I really don't care.
Old 11-02-2005, 05:22 PM   #20
WJM
Guest
Member#:
im diging this thread up for the pics that no longer exist.
Old 11-02-2005, 08:21 PM   #21
WJM
Guest
Member#:
Seen it.
Old 11-02-2005, 08:21 PM   #22
WJM
Guest
Member#:
who...i just posted before you did.....wt-h?
Old 11-02-2005, 09:20 PM   #23
Legacy777
Member#: 4800
replied to your thread on the USMB.
Old 11-02-2005, 09:40 PM   #24
Legacy777
Member#: 4800
wow....something got screwed up with the server's time stamp....maybe something to do with DST.
Old 11-02-2005, 11:24 PM   #25
WJM
Guest
Member#:
very interesting.
TPS Adjustment problem sixkiller Normally Aspirated Powertrain 5 08-02-2006 09:27 PM
TPS Adjustment on 00+ gumby647 Normally Aspirated Powertrain 7 12-10-2001 09:58 PM
TPS adjustment for 2-3 shift glenstiles SVX Forum Archive 8 01-11-2001 08:50 AM
TPS adjustment rsquire North West Impreza Club Forum -- NWIC 5 03-09-2000 05:42 PM
TPS adjustment Akiata Legacy Forum 0 10-02-1999 10:23 PM
