![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 6482
Vehicle:2011 Transit Connect Metalic Silver |
I just had a flat on my summer tires and I was thinking about just putting my snow tires on the car now and just replacing the summer tires after the winter. I live in Boston and we probably won't see snow for at least another month or two. How bad is it to run snow tires this early in the season?
#2 |
Member#: 11620
Vehicle:1997 GF4 -STiV3 Saab 93 TX sportcombi |
The snow tire compound will not hold up to heat well at all. If you had a nice sunny day and drove many miles it could significantly wear the tread. If you don't drive much, it will likely not be a problem. Depends on the snow tire compound too. There is no safety issue, although the snows are not optimal for dry weather driving.
#3 |
Member#: 16523
Vehicle:JDM Maxxpro |
Snow tires don't like the warm weather. They get real squirmy and wear faster than normal, under warm temperatures.
#4 |
Member#: 6482
Well it's a done deal. This is the first time I've prayed for early cold weather!
#5 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
If you have a more all season snow tire like the Nokian WR or Bridgestone LM-22 you will be fine.
#6 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
No problems. Think of snow tires as temperature tires. As it gets colder, the softer tread compound works better than that of a performance tire, which gets rock-hard in temperatures below 40 degrees F.
Just don't drive all crazy and stuff, and you'll be fine. The other question is what kind of snow tires do you have? This makes a big difference. Kevin |
#7 |
Member#: 51946
Vehicle:2000 RS 2.5 Blue Ridge Pearl |
We'd a fall of snow about 2 weeks ago. I put my (New last winter) snows / studded tires on.
Snow lasted about 2 days then it was gone. We're due big snow soon, so I was going to leave them on. However, soon as they're warm, you can actually feel the car slip, under heavy cornering, so, I took them off again and put my summer tires back on. Here you're allowed to use studded tires from mid September I think, but, I could almost 'hear' the tires wearing on the dry roads.... |
#8 | |
Member#: 22452
Vehicle:'04 WRX witty comment goes here |
#9 |
Member#: 6482
I have the Kumho I'ZEN Stud Snow tires. They are not studded, but studable.
#10 | |
Member#: 22452
Ok. ![]() |
#11 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
you'll be fine .... I have a set of winter tires on 1 of my cars already
| Thread Tools | |
| Display Modes | |
| Tires: Wider and bigger, but how bad is that really? | metoo | Tire & Wheel | 8 | 03-04-2008 07:32 PM |
| How bad is it to drive on snow tires in warmer weather??? | Farnsrocket | Tire & Wheel | 4 | 12-16-2006 11:26 AM |
| When are you going to switch to snow tires? | Undepelo | Mid Atlantic Impreza Club -- MAIC | 14 | 11-30-2004 09:12 PM |
| When to switch to snow tires? | Rich10 | Brakes, Steering & Suspension | 15 | 10-31-2002 07:28 AM |
| How bad is that? | Subalo | Transmission (AT/MT) & Driveline | 6 | 05-03-2002 09:02 PM |
