Old 10-14-2004, 11:09 AM   #1
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
Default Revolutions Motorsports Header
Hello all,
I am about to buy one of the Borla replica headers and was wondering if anyone had fitment problems with them on new age GD models. One of the member on this site had problems with the swaybar hitting the Borlas. I was wondering if there is anything else I should know before I spend $$$ on these. Thanks!
Jay
Jyik40 is offline   Reply With Quote
Old 10-17-2004, 08:52 PM   #2
mrruins
Member#: 41337
2005 Toyota Tacoma
bump
mrruins is offline   Reply With Quote
Old 10-17-2004, 10:44 PM   #3
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I've got 'em on my car. They're a little better quality than borla's. Good sound and probably a little performance gains. There's no clearance issues at all (stock front sway bar with pillowball endlinks).
Installation was straightforward, had to push a little to get them to line up with the bolts on the heads. The support bolt that's on the cat section won't line up, but it's fine without it.
If you use the search function you'll probably pull up my post about installation and comments.
BlkTS02 is offline   Reply With Quote
Old 08-10-2008, 05:48 PM   #4
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i installed them, and the headers are resting on my front swaybar (perrin 25" sway) they clunk a bit every once in awhile, but other than that they are good. and sound awsome
olsen726 is offline   Reply With Quote
Old 08-10-2008, 06:30 PM   #5
bobbyjimmy
Member#: 114012
2002 Outback
I've got a set on my Outback (same engine etc), they hit the sway bar.
I wrapped the headers with heat wrap, and wrapped abit around the sway bar too, helped abit.
To fix it, im cutting the flanges off the original headers, grind/mill them flat, put a gasket and sealant each side and putting them between the heads and the headers, should space it down about 10mm or so.
bobbyjimmy is offline   Reply With Quote
Old 08-10-2008, 08:34 PM   #6
piker28
Member#: 22664
WOW talkin about bumpin an old thread
piker28 is offline   Reply With Quote
Old 08-11-2008, 01:56 AM   #7
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
lol, i know. i searched it and it came up, then i posted before i checked the date lol
Revolution Motorsports Headers??? RS22b Normally Aspirated Powertrain 0 01-08-2007 01:46 PM
Revolutions Motorsports headers SubaruImpreza_power Normally Aspirated Powertrain 20 04-13-2005 04:07 PM
Revolution Motorsports header info? anyone try em? Seeing StaRS Normally Aspirated Powertrain 40 10-19-2004 08:23 PM
revolution motorsport header? imprezey Normally Aspirated Powertrain 3 04-27-2004 04:06 PM
Revolutions Motorsports header - jet hot coat 2000 erice1984 Private 'For Sale' Classifieds 2 12-29-2003 12:59 PM
