Old 10-14-2004, 08:30 PM   #1
PhoKingWRX
Member#: 30861
2002 Silver
Perrin Parts Slut
Default thinking of putting back stock muffler
hey all,
so right now im completely catless via perrin's exhaust system. now that winter is approaching, the exhaust sound is a bit loud. i want to be a bit more quieter.
i was thinking of just taking off the perrin muffler and installing the stock wrx muffler in its place until spring. would this be a problem? im assuming some kind of "bottlenecking" would occur but the sound would be quieter. or would it just be safer to take out the entire turboback and put the stock one in until spring? i guess my main concern is long term effects on the engine if im installing a quieter muffler.
other options i was also considering would be purchasing a prodrive axle back or maybe the sti one. (which ever is cheaper really.)
any help would be greatly appreciated.
PhoKingWRX is offline   Reply With Quote
Old 10-14-2004, 08:32 PM   #2
ZapZilla
Member#: 51190
2002 WRX Wagon
well i know the perrin axleback will not fit the stock center pipe, not sure if the stock axleback will fit the perrin center pipe. You can fit the stock cat-back to the perrin downpipe i'm sure, it fits HKS downpipe. It will be quieter and theres not a big difference in performance from what I can tell.
ZapZilla is offline   Reply With Quote
Old 10-14-2004, 08:49 PM   #3
hondaeater69
Member#: 60324
Zap is right. I was in your same boat catless with a stromung, and the muff was loud as balls. I put the stocker back on and couldn't notice a difference in power. You'll be much better off just putting the stock cat back on as opposed to the entire turbo back. Just about all of the restriction is in the first two cats.
I had my car dynoed this last weekend too, and my numbers were right in line with what other cars were posted with a TBE.
Old 10-15-2004, 01:07 AM   #4
abaxter34
Member#: 34723
fwd FTL!
i have the stock catback matched up to a 3" exhaust depot downpipe. for auto-x's i swap in my axleback straight thru pipe mainly so i can hear the engine better, MUCH better. power wise i cant feel any difference though, even after giving the ecu time to adjust.
abaxter34 is offline   Reply With Quote
Old 10-15-2004, 01:08 AM   #5
dust12
Member#: 13417
I have 3" vishnu turboback exhaust that I thought was a little loud, so I had a muffler shop make a flange for the stock muffler so I can swap either muffler with just a couple bolts...
The stock muffler sure does make it nice and quiet...I don't know how much power I am loosing though...
dust12 is offline   Reply With Quote
Old 10-15-2004, 01:45 AM   #6
jlevy
Member#: 15696
2015 WRX 6 speed
Default me too...
I've noticed the same lack of power increase going from stock muffler to a custom magnaflow on a TXS stealth system. On a car with a stock turbo, it just doesn't seem to be a bottleneck. I'm now back on the stock muffler and my wife and neighbors are much happier
These are butt-dyno impressions only.
-my 0.02
edit: Note I have a cobb stage 2 reflash.
jlevy is offline   Reply With Quote
Old 10-15-2004, 04:24 AM   #7
awdf00
Member#: 57289
1998 BMW M3
I've also wanted to remove my ridiculously loud hks muffler and throw on a quieter or the stock muffler. Would there be a really quiet aftermarket catback or axelback that anyone would recommend?
awdf00 is offline   Reply With Quote
Old 10-15-2004, 04:27 AM   #8
feiron
Member#: 62327
2005 WRB STI
[S600BY]
borla hush? its dual-tip tho... or try MBRP, american brand, 2.5" piping
feiron is offline   Reply With Quote
Old 10-15-2004, 02:00 PM   #9
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
where is the GMK when we need him?!?!
HELP DWIGHT HELP!!!
camz911 is offline   Reply With Quote
Old 10-15-2004, 02:29 PM   #10
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
I see that a few of you claim no increase in power from the replacement of the stock axleback. Two pieces of information to possibly contradict that:
1) In this thread, the guy had TXS stealthback with stock muffler, then went to full 3" TBE with one cat and gained 20 HP.
http://forums.nasioc.com/forums/show...XS+stealthback
2) A friend and I were dyno'd same day on a dyno dynamics dyno...mine is an 02, his an 04. He is catless with stock catback. I have a 3" TBE with one high flow cat in the DP. All other mods the same. I put down 204, he put down 190. Here are the plots:
His:
http://www.ktrperformance.com/galler...phen_e_wrx.htm
Mine:
http://www.ktrperformance.com/galler.../jon_r_wrx.htm
Seems the data supports the idea that the stock axleback is restrictive even with just the stock turbo. Anyone have any data that can challenge this?
JonR is offline   Reply With Quote
Old 10-15-2004, 03:07 PM   #11
hondaeater69
Member#: 60324
Good effort Jon, but not quite good enough.
There could be a million different things that caused those differences. I'd like to see a graph of a car on dyno with a TBE, then one with the stock cat back on the next run. Now that would eliminate these possible differences in cars. I bet the differnce is more like 1-2 whp on the SAME car, not someone elses car.
Old 10-15-2004, 03:09 PM   #12
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
The first thread is the same car.
I agree though, that two different cars may or may not be comparable even on the same dyno same day.
Old 10-15-2004, 03:14 PM   #13
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
of course the stock axel back is restrictive even with the stock turbo. If any of you have actually looked at the inside of a stock muffler, you'd realise that the exhaust has to go through a laborinth to exit the muffler.
There is no arguing that the stock axel back is VERY restrictive, and I would put about a 10hp difference between that and an aftermarket straight through muffler.
Hondaeater69 does make a good point. You can not compare two different cars. There are soooo many variations in how the engine was broken in and there are also flaws in every engine. No 2 wrx motors put out EXACTLY the same power. some guys make 180whp out of the box and some others make 160whp.
Old 10-15-2004, 03:59 PM   #14
hondaeater69
Member#: 60324
It looks like the gains he made were from the DP, not losing the axle back. He said it felt better under 4500 RPM, and around town, that's a spool thing. I"m willing to bet that big ass TXS 4" DP was actually creating turbulence after his turbo because the gases had no direction and too much room to just sit there, and the new bellmouth was smaller and gave him smoother exhaust flow.
I think the stock axle back would be a bigger restriction under higher HP numbers, and probably would hurt you up top your rev range, not in the lower range.
Old 10-15-2004, 04:21 PM   #15
dust12
Member#: 13417
JonR - I'm not disagreeing with you that you loose some horsepower with the stock muffler. I'm just stating that I can't feel it.
If you or anyone else wants to pay the dyno fee to see the difference in the stock vs aftermarket mufflers I'd be happy to help.
Old 10-15-2004, 05:02 PM   #16
InfamousDX
Member#: 25413
My butt dyno from prodrive axle back to stock axle back is quite noticeable, especially on top end. That was with a stromung DP + mbc @ 16.5 psi.
Old 10-15-2004, 05:32 PM   #17
hondaeater69
Member#: 60324
Where you from in NJ DX?? I live in milford pa, which is right on the north west border of NJ.
Old 10-15-2004, 06:20 PM   #18
Microbomb
Member#: 39245
02 Subaru WRX
MBP
I put my stock cat back on a couple weeks ago. I had a full Helix catless system. I don't notice a difference in HP. I do notice that I don't boost quite as high or as quick as I did with the catback on. I really miss the sound of starting the car in the morning and hearing that low rumble, however it is nice having a little quieter car. I am still unsure if I am going to put my Helix catback back on or keep the stocker on there.
Microbomb is offline   Reply With Quote
Old 10-15-2004, 06:36 PM   #19
downshiftdan
Member#: 52006
2003 WRX
Platinum Silver Metallic
perrin is a very loud catback, heard my friend's the other day catless and it sounds beasty! Many other axle backs/catbacks will be much quieter....greddy, borla hush (my choice), stromung, cobb, bosal single tip, prodrive, fujitsobo, off the top of my head...even a generic magnaflow from midas will be much quieter than Perrin. peace
downshiftdan is offline   Reply With Quote
Old 10-16-2004, 12:09 AM   #20
PhoKingWRX
Member#: 30861
2002 Silver
Perrin Parts Slut
wow. thanks to everyone for all thier input. ive decided to put back my stock catback for now. once the whether gets better, ill put my angry badger exhaust back on. again thanks for everyones input!
Old 10-16-2004, 01:30 PM   #21
hondaeater69
Member#: 60324
When you put it back on, let us know if you feel a difference in power, boost, etc.
thinking of putting on a cruise toys for tots tommy05wrx New England Impreza Club Forum -- NESIC 84 12-10-2006 10:52 PM
Thinking of putting 18x8" wheels; do I need suspension mods? palpullero Brakes, Steering & Suspension 5 03-06-2006 02:21 PM
Put On Stock Muffler w/ Catless TBE EagleRockWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-07-2005 10:13 PM
thinking of installing a bike's muffler devilmaycry2020 Normally Aspirated Powertrain 7 12-22-2003 07:31 PM
Guaging intrest...thinking about putting to stock... kinjwrx North West Impreza Club Forum -- NWIC 9 08-12-2003 03:37 AM
