Old 06-22-2001, 11:47 AM   #1
ferretboy
Member#: 4782
well SF9, AE92
SF9-Brack and AE92-faded
Question What year NA 2.5 is best to turbo?
Hello everyone,
I am gathering info on what MY 2.5RS 5spd. is the best to turbocharge. I will be purchasing one when my lease is up and the Forester is paid off. So in the meanwhile, if any of you can help me out I'd greatly appreciate it. I want driveability,but still don't mind roosting some unsuspecting teen once in a while. TIA
~ferretboy signing out
ferretboy is offline   Reply With Quote
Old 06-22-2001, 02:21 PM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I think the best possible base motor for a turbo would have to be around the 99 ish area. The important part is find a motor that has a phase-II block with phase-I DOHC heads. I have this on my Legacy and even from stock with no mods I could feel that I have a little more high rpm power and faster throttle response.
MY99 2.5GT is offline   Reply With Quote
Old 06-22-2001, 02:59 PM   #3
gumball
Member#: 1209
For some reason I think those hybrids were only in Legacies. Could be wrong. In which case an RS w/a Phase II Block and single cam heads would be good. Whatever the case, its the Phase II block you want.
gumball is offline   Reply With Quote
Old 06-22-2001, 03:01 PM   #4
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
MY99 2.5GT - You are partially correct
1) yes the Legacy GT's in 1999 came with DOHC and phase 2 block, but only some, the rest used the phase 1 block.
2) You want to find a '98RS that is as close to that last build date possible, reason why is b/c that's when they had the DOHC + phase 2 block. If you get a '99RS, it will have a phase 2 engine with the phase 2 SOHC heads.
GTBGUY is offline   Reply With Quote
Old 06-22-2001, 05:33 PM   #5
subisonic
Member#: 6025
1998 Impreza RS
Rally Blue
How do you tell the difference between a phase I and a phase II block?
subisonic is offline   Reply With Quote
WRX/STi axle back exhaust bolt on to NA 2.5? Kid Icarus Normally Aspirated Powertrain 10 09-04-2011 01:43 PM
NA 2.5 rs turbo bbarnett83 Normally Aspirated Powertrain 4 11-24-2008 10:45 AM
ej 2.5 n/a to turbo b4u Legacy Forum 2 05-15-2007 09:16 AM
Would DOHC NA 2.5 heads work with STi 2.5 block? 2slofouru Subaru Conversions 11 02-21-2007 01:04 PM
What's out there for NA 2.5/2.2 ECUs? Hyper Engine Management & Tuning 5 10-04-2004 10:33 PM
