Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-15-2004, 02:08 AM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default are front wheel bearing on Impreza'a press in bearings?
like the title says...do they need to be pressed in and out? I can't remember. I have a 94 Impreza L AWD 5 spd, incase it makes a difference.
thanks, Micah
Old 10-15-2004, 09:24 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Yep.
Old 10-15-2004, 11:10 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
ok thought so but wasn't sure.
thanks, Micah
Old 10-15-2004, 03:05 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Get yourself new inner and outer oil seals. And some good high temp grease to pack the bearing with. And a new axle nut.
Doing the job yourself?
Tim Sanderson is offline   Reply With Quote
Old 10-15-2004, 08:56 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
the job is done...thanks guys...and tim thanks for the pointers.
Old 10-20-2004, 07:14 AM   #6
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
You know, I'm curious about this. I had the front bearings on my Legacy done because they were old and rumbling in turns. It was god-awefully expensive. If I were to go buy one of those $30 hand presses that do like 2T or one of those cheapie ones consisting of a bottle jack welded to a spring loaded bar on a frame, could I do this myself? I've changed plenty of wheel bearings before, but I've never done pressed in ones because I lack that hydraulic press I thought I needed. I'm not even really sure what needs to happen. How do you get them out? Can you press them out, or do they get pulled? I'm thinking my rear bearings should get done and I plan to rebuild my transmission and replace my diff in a few months. That would be a good time to do it. I'm just curious to see if I can save myself several hundred dollars.
Lots and lots of questions!
Al_Smokemcrack is offline   Reply With Quote
Old 10-20-2004, 11:29 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
you can actually do them by hand, using the old race and a hammer. being careful and tapping evenly. The press would make it easier though.
Old 10-22-2004, 10:33 AM   #8
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Awesome. That's what I though.
location: thrust bearing on crank vs. thrust bearing on block kiwee Built Motor Discussion 21 04-25-2008 09:56 PM
The majority of performance cars are front wheel drive... JC Off-Topic 33 04-03-2004 09:00 PM
Replacing Front Wheel Bolts on an 02/03 WRX mandrOid Tire & Wheel 3 10-20-2003 02:06 PM
Front Wheels Flanges on SG...for what? RunForestRun Forester Forum 3 06-16-2003 11:02 PM
Stuck on, or pressed in? 02R6 Newbies & FAQs 6 08-16-2002 07:36 AM
