Old 10-15-2004, 09:43 AM   #1
imprezkid
Member#: 71462
2001 2.5rs
STM
Default Intake manifold
I'm lookin for a stock intake manifold that will fit the 02 ej25 engine, will a wrx manifold fit? there alot easyer to find.
imprezkid is offline   Reply With Quote
Old 10-15-2004, 09:44 AM   #2
imprezkid
Member#: 71462
2001 2.5rs
STM
will gc8 fit?
Old 10-16-2004, 06:40 AM   #3
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
NO they will not fit. The heads have to be the same model as the intake manifold. If you put wrx heads on your car, then you could use a wrx intake manifold.
RyansJDMgc8 is offline   Reply With Quote
Old 10-16-2004, 06:41 AM   #4
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
A 99-01 GC8 intake manifold should be ok but double check on that.
Old 10-16-2004, 09:20 AM   #5
orndog
Visiting NASIOC Timeout
Member#: 34670
If she smokes she
pokes
I'd check to see if the new plastic ones fit.
orndog is offline   Reply With Quote
Old 10-16-2004, 04:13 PM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
IIRC, an SOHC manifold should work.
jamesfacts is offline   Reply With Quote
Old 10-16-2004, 06:10 PM   #7
PabloEscobar'd
Member#: 69833
2000 Impreza 2.5RS
check out my thread in private classifieds.. it *might* be of som use to you, not really sure though.
PabloEscobar'd is offline   Reply With Quote
Old 10-17-2004, 06:52 PM   #8
imprezkid
Member#: 71462
2001 2.5rs
STM
so 99 rs intake manifold will fit
Old 10-20-2004, 12:45 PM   #9
Section 8
Member#: 821
You need to decide which injectors you want to use. 99 manifold will only fit 99 injectors. WRX manifold will not fit 2000-on injectors. They will fit 99 injectors by just widening the top of the injector pocket. THe WRX manifold is larger than the RS intake ports, so is not really a long term solution to begin with.
You need to purchase a 2000-2004 NA 2.5 manifold to use the more common injectors. THe plastic manifold will work, but will need a few things to work.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 10-20-2004, 01:14 PM   #10
jeffg
Member#: 2958
2001 WRX (GC8)
I have a 2001 2.5RS manifold extra at home. If someone needs it, please let me know. I have idle control motor, fuel rails and injectors too.
jeffg is offline   Reply With Quote
FS : Grimmspeed Intake Manifold w/ extras, ID 1000cc bigboy Engine/Power/Exhaust 17 07-17-2010 02:39 PM
USDM STi intake manifold to Spec C intake manifold caveats? Dasani Built Motor Discussion 2 02-08-2007 11:01 PM
WRX intake manifold vs. STI intake manifold AugustusMaximus Factory 2.5L Turbo Powertrain 18 01-29-2006 11:00 PM
STi (Red) Intake Manifold verses USDM (Silver) Intake Manifold Diversion Factory 2.0L Turbo Powertrain 10 09-25-2002 04:11 PM
MY98 Intake Manifold comparison to MY99-01 Intake Manifold latinskllz Normally Aspirated Powertrain 0 05-18-2002 02:50 PM
Message Board Statistics All times are GMT -4. The time now is 01:33 PM.
