Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-15-2004, 10:38 AM   #1
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Impreza WRX STi Has anyone removed the warnings on the sun visors?
I was sucsessful removing the airbag warnings on my 03 WRX with goo gone but what about the 05 STi lables? The visors are made of cloth material so I wouldn't uses fluids to try and remove them. Anyone has ever removed them?
Undepelo is offline   Reply With Quote
Old 10-15-2004, 11:14 AM   #2
fastsubie
Member#: 21999
2012 Wrx
I did the same on my 02 but am afraid to try it on the STi..
Fess
fastsubie is offline   Reply With Quote
Old 10-15-2004, 12:30 PM   #3
strohausii
Member#: 26770
'02 WRX
midnight black
...Is it possible just to get them reupholsered?
(hmm, maybe with some red baseball stitching, get that suede red stitched steering wheel mod, and matching gear shift/ e-brake handle..... sry, got carried away)
/btw/: did you just throw on the goo gone, or did you have to soak it and pick pieces off (it didn't just peel off did it?).
strohausii is offline   Reply With Quote
Old 10-15-2004, 01:29 PM   #4
slvrwgn
Member#: 32604
2003 Impreza WRX Wgn
Are you saying that Goo-Gone is all I'd need to remove those warning stickers?
slvrwgn is offline   Reply With Quote
Old 10-15-2004, 01:35 PM   #5
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
With that and elbow juice..I left my visors with a faint outline of the lables. The material of the visor starts to stretch and get puffy because you will be rubbing a bit but after you clean off the crap heat it a bit with a blow drier and put heavy books on it and it will come back to shape.
Old 10-15-2004, 01:41 PM   #6
slvrwgn
Member#: 32604
Did the final product still show a slight outline of the labels?
Old 10-15-2004, 01:44 PM   #7
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Do you recall the appearance of translucent but non transparent tape? The kind often used to wrap gifts? Sort of fog looking. Well thats how the final product looked like. It was a lot better than the lable but not quite as nice as nothing at all.
Old 10-15-2004, 01:46 PM   #8
slvrwgn
Member#: 32604
Undepelo, thanks for the info. I appreciate it.
Matt-
Old 10-15-2004, 01:58 PM   #9
Sperm
Member#: 25038
2002 PSM WRX sedan
I almost bought actual JDM(y0!) visors once. They are exactly the same except the writing is in Japanese(obviously). I figured at least then they would be somewhat cool.
But why the hell do they have to put those there? Wouldn't a warning in the owner's manual suffice?
Sperm is offline   Reply With Quote
Old 10-15-2004, 02:03 PM   #10
jdm25rs
Member#: 68118
2014 BRZ Ltd
Satin White Pearl
here's another way that you can do it
http://www.scoobymods.com/forums/showthread.php?t=133
jdm25rs is offline   Reply With Quote
Old 10-15-2004, 05:07 PM   #11
NorthstarSTS
Member#: 22869
2004 Forester XT
Java Black Pearl
Default visor tags
Reverse the visors , left to right. you have the mirror flaps to look at but better than those yellow tags!
NorthstarSTS is offline   Reply With Quote
Old 10-15-2004, 05:34 PM   #12
ChrisRC
Member#: 54594
I took the airbag sticker off my passenger visor with Goof-Off. It looks decent, but you can still see the sticker outline under direct sunlight (thankfully visors are usually inside the car!). I have not done the driver side mainly due to time constraints. It took approximately two hours and 16 oz. of Goof-Off to get the job done adequately. Do not do this if you want "perfect" visors; it would be impossible to entirely eliminate the "shadow" effect. I do think it's a mild improvement over the hideous stickers.
NOTE: Goof-Off and Goo-Gone are two entirely different products. Do not confuse them!
ChrisRC is offline   Reply With Quote
Has anyone run six points on the stock my00 rs seat? JTJ 2.5 Interior & Exterior Modification 1 01-25-2006 10:22 PM
has anyone installed/have info on the RA hardened gear set? BIGSKYWRX Transmission (AT/MT) & Driveline 6 11-24-2002 12:34 PM
Has anyone put a throttle on the shifter? rharder General Community 19 07-23-2002 08:06 AM
Has anyone tried STi tops on the stock WRX suspension? gtguy Brakes, Steering & Suspension 17 02-27-2002 01:30 PM
