Old 10-15-2004, 07:49 PM   #1
WildWolf
Member#: 72640
2004 WRX Wagon
Default Newbie about to buy a 2000 2.5RS sedan....
what should I be looking for? It has 75,000 miles. What needs to be changed soon/ what should have been changed recently? I drove it and it felt strong BUT the brakes were terrible......what are my options here? I want to keep the 16 inch wheels and it comes with a second set of wheels with Blizzaks. What can I do about the seats? They are kind of beat up. Will WRX seats fit in? Is there a better option (cost is definitely an issue). Thanks in advance.
edit- it is a 5 speed blue over cloth
WildWolf is offline   Reply With Quote
Old 10-15-2004, 08:15 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You should be looking for:
head gasket failure or proof of the fix.
wheel bearing failure.
oil pump/seal leaks.
make sure the fogs work and are not cracked.
If it has the factory sub, make sure it is'nt blown.
Clutch slippage.
spare tire and jack/wrench pack in the trunk.
Look under the hood for anything hacked up.
Tim Sanderson is offline   Reply With Quote
Old 10-16-2004, 06:37 AM   #3
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
If the transmission hasn't been replaced/rebuilt yet, its probably about that time.....
RyansJDMgc8 is offline   Reply With Quote
Old 10-16-2004, 10:00 AM   #4
WildWolf
Member#: 72640
2004 WRX Wagon
Where is the factory sub? How do I know if it comes with one? Also, why do the trannys only last 75,000 miles? Thx
Old 10-16-2004, 10:42 AM   #5
Nicklbrso
Member#: 44887
00 GC6
Thats a little premature. Just because Subaru has had some issues with their 5MT doesnt mean the tranny needs to be rebuilt/replaced at 75,000 miles. Maybe the clutch.
Check for clutch shudder too.
Nicklbrso is offline   Reply With Quote
Old 10-16-2004, 10:58 AM   #6
WildWolf
Member#: 72640
2004 WRX Wagon
The car had a CAI and exhaust (not sure which brands).....What are the next most popular mods for the car? Thanks
Old 10-16-2004, 11:08 AM   #7
Siper2
Member#: 1134
2007 BMW 328xi wagon
Not EVEN the clutch. I replaced my OE clutch at 102K miles, and honestly it was still in very decent shape. It only slipped twice, and very intermittently at that. I just wanted to get rid of it in case, I suppose.
(But I still have it in my garage...)
As for the transmission, yes, very premature. My car's got 110K on it, and no signs of problems thus far.
Siper2 is offline   Reply With Quote
Old 10-16-2004, 11:11 AM   #8
Siper2
Member#: 1134
For CAI:
Cobb / PRM
Injen
GanzFlow
AEM
PDM-Racing
HKS / SPT (Subaru option)
Cobb is the best. They are based off a design by PRM. GanzFlow is very popular as well, but the PDM-Racing CAI is nearly the same thing, at a much smaller cost: $50.
As for exhausts:
Scoobysport
Prodrive
Borla
Bosal (the Bosal BroSpeed is the factory muffler/axleback option)
Brullen
Magnaflow (generic)
...and about 50 others...
Old 10-16-2004, 11:14 AM   #9
Siper2
Member#: 1134
Be sure you check to see if the O2 sensor has been replaced, too. There was a recall on them, #WXW80, which was eventually replaced by an ECU reflash recall.
I had five O2 sensors replaced no-charge under that Parts Recall number, and then when they flashed my ECU, the problem stopped. Previously I'd been blowing a CEL every 10K miles or so.
The head gasket problem traditionally isn't as prominent with the SOHC EJ25 engine, but that opinion's been changing lately. There was a "recall" recently for a stop-leak coolant additive, but I'm not sure how realistically helpful the stuff is. I had it done at the dealership when they put my Exedy Sport clutch in.
=S2=
Old 10-16-2004, 12:18 PM   #10
piker28
Member#: 22664
wow all this for a 00 and i was lookin at buying a 99 sheesh cant imagine what id have to check for
piker28 is offline   Reply With Quote
Old 10-16-2004, 12:20 PM   #11
Siper2
Member#: 1134
Sounds like a lot, but it's not a WHOLE lot.
Most cars at that age will have a pretty good list of watch-out-for things.
Did you get my PM, piker??
Old 10-16-2004, 01:44 PM   #12
WildWolf
Member#: 72640
2004 WRX Wagon
Thanks for all the replies so far.
What about other mods? Are there reasonable brake upgrades for the street? What about audio? Aside from putting in a whole new system, is there anything that one can do to improve? Did anyone change the sub? Is it worth changing? JL Stealth box? Anything else? What about suspension? I read somewhere that u can just put a WRX rear bar in and it will handle more neutral- true/false?
Old 10-16-2004, 01:53 PM   #13
Siper2
Member#: 1134
Lightbulb
Brakes? That's an easy one. By far the most effective street brake upgrade is the "WRX/H-6" swap.
This entails swapping your front rotors and caliper brackets for those off a WRX. And the rear rotors and caliper brackets, for those off a 2000-2004 Legacy. That rear upgrade is often called the "H-6 upgrade," but that's a little bit incorrect, as other Legacies besides the H-6 model had the same, larger rotors (11.3" or 290mm).
Your car uses the SAME CALIPERS, so it's just the brackets and rotors that need changing. So effectively, this is the increase:
FRONT: Stock = 10.7" rotor WRX = 11.4"
REAR: Stock = 10.3" rotor Legacy = 11.3"
Bigger difference in the rear, for sure, but I haven't seen a single negative review about this upgrade in about three years. Haven't done it on my car yet, but for me that's a money problem. If you wanted to spend more, you can get the GC STi 4-pot calipers up front, which use the same size rotors as the WRX. There are STi 2-pot rear calipers, but they're frightfully expensive.
Many people use the Legacy Turbo rears, which are off the mid-'90s Turbo, **not** the '05 Legacy GT. All of this you can find here:
www.subaruwrxparts.com/gc8.html under Brakes.
You could go further and upgrade to '05 Legacy GT brakes, which are like 12.3" or 12.4" up front, but you need 17" wheels year-round, and to me that's excessive. I need to maintain 16"s for winter. But it's an unbelievable setup, if you want to go that way, and relatively cheap next to other aftermarket deals. For the street, "big brake kits" from aftermarket companies aren't going to help, anyway. Their major advantage is on the racetrack, when repeated braking causes heat that's too excessive for OE brakes to handle.
Audio is always worth changing, in my opinion. No stock system is ever going to be as good as a well-designed aftermarket setup. Visit the Audio forum for your answers to that.
As for suspension, a WRX *sedan* rear swaybar measures 20mm, and will bolt up directly. Now, BE CAREFUL... to my knowledge, the '02 WRX had a 20mm, but the sizes have gone up and down a bit, from year to year. To be safe, pick yours up for $80 here: www.subaruwrxparts.com/gc8.html under the Suspension section.
...NOW....
The stock rear swaybar is 13mm, pretty weak. An 18mm bar is ideal for neutrality's sake, with a stock suspension. I personally wouldn't use a 20mm bar until you got a better strut/spring setup, but then again 20mm isn't bad. 22mm+ is bad, on stock struts and springs. Too much roll resistance, without the proper dampening.
=S2=
Old 10-16-2004, 01:53 PM   #14
Stime187
Member#: 32779
'99 Tacoma
LightOfTheWild.com
The brakes are pretty darn good stock, if yours feel bad, I'd check the pads/rotors, bleed them and get some good fluid in there before doing any upgrades. But there are some available.
- Scott
Stime187 is offline   Reply With Quote
Old 10-16-2004, 02:00 PM   #15
Siper2
Member#: 1134
Yes, Stime187 has a point... Good fluid is always a good thing!
Don't get pads that are too aggressive, though. Remember that you need a balance! On the street, you either want OE pads, or something halfway between OE and racing quality.
Race pads have opposite traits as OE pads do, in that they have rotten initial bite (like panic braking on the highway), but do VERY well under repeated, high-heat braking.
OE pads, on the other hand, are excellent for initial bite, but under repeated braking, they go all to hell. So a "sport street" pad will strike a balance between the two. Even among those, though, some are more aggressive than others.
Hawk HPS is one of the better, not-too-much street pads. (www.tirerack.com)
I had Porterfield R4-S pads on my car once, but they're very expensive, and in my opinion, were too aggressive for my driving.
Old 10-17-2004, 01:31 AM   #16
jamesfacts
Member#: 51282
98 RS
black & blue from parking
jamesfacts is offline   Reply With Quote
Old 10-17-2004, 02:59 AM   #17
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
50k Miles on the tranny (with a Jun Flywheel and ACT clutch for last 30k) with no problems.
Marcin is offline   Reply With Quote
Old 10-17-2004, 10:18 PM   #18
WildWolf
Member#: 72640
2004 WRX Wagon
I think most of my questions have been answered! Thanks very much. I will take some pics and post this week.
Old 10-17-2004, 11:10 PM   #19
Marcin
Member#: 2874
2005 CGM WRX WGN
BTW: WRX seats will fit, fronts and backs. A former local did that to his 4-door RS.
Ask Mykrrrr.
There is also array of take off seats you can get from JDM Wrx'es and STI Versions
Old 10-18-2004, 08:23 AM   #20
Siper2
Member#: 1134
WRX seats fit, but they sit a bit high in the GC cars. Still comfortable, but for we tall-torso'ed guys, that can get tricky.
Old 10-18-2004, 12:49 PM   #21
Black_Rain
Member#: 29932
2005 LGT Ltd
Womp
Yeah...my tranny is fine...i have 146k on the clock and the clutch is still the same one from day 1... rarely ever slips....although i'm predicting a new clutch within the next 20-30k miles
Black_Rain is offline   Reply With Quote
Need advice - About to buy a 00 2.5rs twizy Newbies & FAQs 0 05-14-2007 05:50 PM
About to buy a 2000 2.5 rs, what do i need to look for? imprzya Normally Aspirated Powertrain 14 06-01-2005 08:01 PM
I'm thinking about trading in my 2000 2.5RS Impreza for the Outback limited sedan Piecode314 New England Impreza Club Forum -- NESIC 10 05-04-2004 07:59 PM
It's That Time: 2000 2.5RS Sedan For Sale imprezawrxsti.com Rocky Mountains Impreza Club Forum -- RMIC 6 04-26-2003 12:31 AM
FS: 2000 2.5RS Sedan JC Mid West Subaru Owners Club Forum -- MWSOC 9 10-23-2001 12:00 AM
