Old 10-15-2004, 11:11 PM   #1
gpatmac
Member#: 18446
2002 WRX wagon
psm
Default pro's and con's of non-subaru-informed vs. the infamous WRX tuners
There's actually two types of the non-subaru informed; import tuners and hotrod (or worse) N/A hotrod tuners.
I'm going to talk to these folks CFM Performance to get a general feel.
What are some of y'all's thoughts concerning this issue? Is there anything you'd take your car to someone besides the Subaru service dept. or to a WRX-oriented tuning shop like APR or such?
gpatmac is offline   Reply With Quote
Old 10-15-2004, 11:29 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
I'ld still take a motor to kenny duttweiler any day of the week. and I'ld still have wilson make a manifold if I had the money... but just cause I trust them doesn't mean I'ld take it ANYWHERE...
STiTuner is offline   Reply With Quote
Old 10-15-2004, 11:42 PM   #3
gpatmac
Member#: 18446
2002 WRX wagon
psm
I guess I should have oriented this thread more specifically towards heads, although discussing any sort of machining is probably appropriate.
It would seem that actually 'tuning', ie the ECU, piggyback or standalone, would be where you'd be most concerned that the shop was ultra-familiar with the WRX.
So, those 2 individuals are 'pushrod-type' guys that you'd trust your heads or cylinders with?
Old 10-15-2004, 11:58 PM   #4
STiTuner
Member#: 5778
09 135i
Jet Black
I would most certianly trust a head or any other part of my motor to duttweiler... but unless you're on his buddy list it'll take him a while to get to it, assuming he doesn't just say no from the beginning (which I can say he most likely would say NO). there are a few pro motorcycle builders I'ld trust a motor too aswell.
as far as tuning it depends on the EMS you're running as to who I'ld take it too aswell. if I ran an AEM I might take it one place and if I had a UTEC I might take it somewhere else. of course if both people were competent tuners you would yield good results. but if you take it to someone who is more familiar with the software (and hardware) you might yield better results.
there are a lot of good capable people that aren't on this board that could probably build you a pretty kick ass setup.
Old 10-16-2004, 12:10 AM   #5
gpatmac
Member#: 18446
2002 WRX wagon
psm
Duttweiller works at CFM? I just didn't want to mistake what you're saying.
Nah, I'm only interested in headwork right now. I'd assume that it's a given that Dan Paramore is a WRX heads guru, I wouldn't be surprised if it were actually he that ported heads for Quirt and I-speed. I'm not making any statements, just saying I wouldn't be surprised. Anyhow, the prices up at CFM AND the fact I'd only have to drive ~50 miles to have it done makes CFM look awfully attractive.
As far as EM, I'm tuning my own UTEC. Although as an azimuth check, I do plan on seeing if I can't get RiftsWRX, or someone of that caliber, to tune it at APR next spring/summer. That will be my first and last time of going to a dynometer.
Old 10-16-2004, 12:32 AM   #6
STiTuner
Member#: 5778
09 135i
Jet Black
Duttweiller does NOT work at CFM, he works on 1500+ HP GN's... I was simply using it as a point to illustrate that I would trust other non-subaru specific people in some cases. I don't know anything about CFM.
further more just because someone is a WRX specilist doesn't mean they are great (not saying anything about Dan or Jorge since I haven't seen their work personally).
Pick people who you know are knowledgable, and do their job well.
Old 10-16-2004, 12:48 AM   #7
gpatmac
Member#: 18446
2002 WRX wagon
psm
Sweet, Thanks.
Pro's and con's of driving a motorcycle as daily driver.... e11ys Off-Topic 83 06-02-2014 05:05 PM
Pro's and Con's of changing tranny fluid VBwrex13 Newbies & FAQs 27 02-04-2010 10:14 PM
Pro's and Con's of disconnecting ABS 4080wrx Brakes, Steering & Suspension 8 06-27-2008 01:36 PM
Pro's and Con's of nitriding Blue beard Built Motor Discussion 8 11-09-2007 12:51 AM
Pro's and con's of subaru impreza spriggan General Community 13 01-18-2002 11:22 AM
