Old 10-16-2004, 01:26 AM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default Injector o-ring missing on never serviced injectors!
My car has never been to a dealership nor have the gbods/injectors EVER been de-installed in the past, until tonight...
for history, injector #2 has always leaked boost during a pressure test slightly, figured when i made the injector/turbo swap that'd be corrected... tonight when we pulled the GBODs off (which is NOT ANYWHERE NEAR as hard as people make it out to be!!!) I noticed the #2 injector *DID NOT* have a factory injector o-ring in the hole!@#
So now i'm finishing up installing the UR 680cc injectors (which is a PITA BTW, finessing those fuel rails is very difficult then try getting the spacers in there )... these injectors have an O-ring seal at the BASE of the injector rather than counting on the o-ring in the hole like the stocks, is it cool if i pull all of the factory injector o-rings out?
overdose is offline   Reply With Quote
Anyone know where to get a good deal on Injector O-rings, UP/DP/Mani gaskets? Wrx_Fan_0717 Mid Atlantic Impreza Club -- MAIC 17 09-19-2007 03:13 PM
will 06 wrx/sti injector seals/o-rings work on pinks subaman24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-01-2007 03:22 PM
lower injector O ring on wrx pics anyone, or where to get the part? jared nelson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-14-2005 06:08 PM
How many o-rings are on a injector? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-15-2004 12:25 PM
Need rubber wrx fuel injector o-ring or fuel injector Shaitiger Private 'Wanted' Classifieds 2 02-11-2004 09:17 AM
