Old 10-16-2004, 02:15 AM   #1
daWagon
Member#: 72665
2002 wrx wagon
whtie, 6MT, vf22
Unhappy asking for advice - fuel leak in/arround engine!
hi I'm new to nasioc as you can tell. I'm also new to wrx's and being the smart chap that I am, I just bought a stage 4 wrx, which I have a lot to learn about.
I have had the car for about a month and I just noticed a strong fuel smell tonight when I was driving. I didn't notice any power loss, or anything else that was strange, except maybe that the gas guage was going down quicker, but that could also be my mind playing tricks on me. I got out the car and found that the smell seemed to be coming from the front on the passengers side. The first thing I thought to look at was the injectors, but they appeared not to have any leaks arround them. What I found for sure was a small "puddle" of fuel, smack in the middle, on top of the engine block - right under where the TMI used to be.
I relly hope it's just a fule line issue but who knows. I'm basicaly asking for any advice that you all may have. Tomorrow I plan to start checking the fuel line and maybee the injectors.
I was wondering if any of you know where the fuel line runs up arround the engine bay? That info would help alot sine I haven't done any of the mods to the car and it is all new to me. i'm planning on trying to get a service manual tomorrow if I can, that will help too!
I would really appreciate any advice or info that would help me out.
Oh yeah - I have:
walbro fuel pump
blitz 550 injectors
link ECU
vf22 running @18psi
thanks
daWagon is offline   Reply With Quote
Old 10-16-2004, 09:01 AM   #2
hotrod
Member#: 14141
2002 Impreza WRX
There is a known problem and a TSB for cold weather fuel leaks in the OEM fuel lines. They repaired mine under warrantee (its both an emissions and a safety issue so they should repair it no questions asked). It involves pulling the intake manifold and replacing the small rubber hose sections in the fuel lines to the injectors with slightly longer ones.
If you do a search on "cold weather fuel leak" you should be able to find the TSB and all the details.
Mine leaked at the rubber hose section that sits right behind the power steering pump near the fuel pressure regulator.
Larry
hotrod is offline   Reply With Quote
Old 10-16-2004, 09:21 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Fuel leak info here-
http://forums.nasioc.com/forums/show...hreadid=131755
From your description it does sound like this issue, however it usually doesn't become noticeable until the temperature gets very low, well below freezing. Also your car is modded and particularly the injectors have been changed so it could be related to that.
Old 10-16-2004, 10:24 AM   #4
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I ran into a leak myself installing fuel injectors
I had to go back and lube up the top O ring with WD40 for a proper seal
What a pain
I will never install injectors with dry O rings again
-Scott A.
cky211 is offline   Reply With Quote
Old 10-16-2004, 11:44 AM   #5
SINthetic
Member#: 53775
03 WRX
If there is a leak, find it asap. You dont want an engine fire. One way to help look for one is turn the car to start but dont crank it over. The fuel lines get pressure and then you can search for the leak.
SINthetic is offline   Reply With Quote
Old 10-16-2004, 12:04 PM   #6
BrianH
Bing user
Member#: 44383
is an injector leak more likely to become evident at higher rpms/loads? I'm having a similar problem but I can't find a leak, I'm just getting a smell. It's not happening in the freezing cold either. Usually comes after getting on the throttle pretty hard.
BrianH is offline   Reply With Quote
Old 10-16-2004, 03:23 PM   #7
daWagon
Member#: 72665
2002 wrx wagon
whtie, 6MT, vf22
yeah, the weather isn't very cold here yet. yesterday the high was 61 and the low was 47. I have tried to duplicate the problem but have not had any luck yet. I haven't driven the car yet though! i've only been running it at a stand still. I'm going to take it out now - it's about 70 outside so I'll see what happens then.
there do seem to be conflicting symptoms though. The smell seemed to be coming predominantly from the passenger side - suggesting a problem arround the injectors - but I found the pool of fuel right in the middle of the engine which points more towards the loose fuel line issue talked about in this thread:
http://forums.nasioc.com/forums/show...hreadid=138069
Just have to see what happens!
Thanks for all the help so far, those threads are really usefull - I suck at searching!
Old 10-19-2004, 11:26 AM   #8
daWagon
Member#: 72665
2002 wrx wagon
whtie, 6MT, vf22
I think I found the source. It did seem to be in the typical cold weather problem place! There was a loose clamp screw that I tightened a bit and haven't run into a leak again. The loose clamp was straight down between the v in the intake manifold like discribed by others. Although the temp hasn't been as cold again!
The car has lived in FL all of it's life up intil now, so it hasn't seen much cold weather. My guess is that the slight temp drop made the loose clamp evident.
Either way I think I'm going to keep a long screw driver in the car along with a fire extinguisher . . . just in case!
thanks again
Doctors of OT: I Again Ask for Advice nogger Off-Topic 50 02-27-2008 11:54 PM
Ask for advice after a small accident kashun84 Tri-State Area Forum 14 12-01-2007 08:34 AM
CA freezing=fuel leak in '02 WRX blukestrel General Community 42 12-27-2004 11:07 AM
Why ask for advice and not take it? sonicblue Off-Topic 32 09-07-2004 09:39 PM
Fuel leak in back PharmCo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-24-2004 07:15 PM
