Old 10-17-2004, 05:48 PM   #1
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Default Brullen header/cat install question
Edit: The parts are installed My review:
http://forums.nasioc.com/forums/show....php?p=7904114
(original message)
Hey all,
I just got a nice used brullen header and NEW brullen cat Yay! Currently I have a stromung muffler and stock midpipe so I need to figure out the best way to add on the header/cat, and decide what to do about the midpipe. I 'think' the stromung muffler piping is 2.25" and the brullen piping is 2.5"... so going with a 2.25" or 2.5" midpipe would be fine...? Anyone know about this?
My other questions would be, how do the cat and the midpipe bolt up to each other? The cat has a flange on it of course, but there's also a donut thing that I got with the cat that is suppose to weld to the midpipe or something? I was thinking of going to my local exhaust shop to have a new midpipe made since my stock one will suck with the new setup... but will I even be able to install the header/cat right now, to the stock midpipe?
Lots of questions. If anyone can give me some general insight, it would be much appreciated.
jonathan
ilmaestro is offline   Reply With Quote
Old 10-17-2004, 06:00 PM   #2
Nicklbrso
Member#: 44887
00 GC6
Your post is confusing. Do you have the stock RS, brullen or stromung mid pipe?
I would go with 2.25" piping. Keep the low end torque you got.
The cat has a flange on it and so does the mid pipe. There are 2 spring bolts connecting the 2 and the donut thing is a gasket. You can replace this if you want but most likely you can resuse it.
You will be able to bolt the header/cat setup to your stock mid pipe if the flanges match up. only way to find out is to crawl under your car and find out.
Nicklbrso is offline   Reply With Quote
Old 10-17-2004, 06:18 PM   #3
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
I'm sorry about the post. Agreed, it is kinda confusing, hahaha. I currently have a stromung muffler with a stock midpipe, and am going to be installing the brullen header/cat. I'll probably do the install and go to a muffler shop next weekend, so I can crawl under the car then. Supposing the cat and stock midpipe don't bolt up, the I won't be able to install the header myself and will have to take it to the exhaust shop, which would suck.
So, what is the size of the stock midpipe? Like I said, I think my muffler piping is 2.25" so a 2.25" midpipe would be fine as you said, but why would a 2.5" midpipe kill some of my torque?
j
Old 10-17-2004, 09:18 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Stock midpipe is 1.75" - IIRC, the Brullens terminate as 2.25".
Anything bigger than 2.25" is bad news for your car - the lack of backpressure will disrupt the exhaust pulses and loose torque.
jamesfacts is offline   Reply With Quote
Old 10-18-2004, 04:04 PM   #5
ksubaru826
Member#: 49578
2005 legacy gt
blue
i got the header/ cat for my car also from brullen and my muffler shop that i go to had no problem getting it on to the stock midpipe
ksubaru826 is offline   Reply With Quote
Old 10-18-2004, 10:08 PM   #6
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Thanks for the responses all. If the brullen piping is 2.25" and so is my muffler's piping... it obviously makes sense to have a 2.25" midpipe made
Do the brullen "quiet" catbacks have a resonator in the midpipe? I'd want to put a resonator in there so the thing doesn't get too loud.
j
Old 10-18-2004, 11:28 PM   #7
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
[email protected] Record Run.
i got 2.5inch, although the mathematics of the sizing arent in my favor, the car still feels better than stock. brullen will make any size from 2 inches to 3 inches in 1/4 inch increments. I got "medium sound" resonated. When you take out the cats your gona want a resonator
96Imprezadent is offline   Reply With Quote
Old 10-20-2004, 10:14 PM   #8
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Well I won't be eliminating the cats completely, I'll still have a Brullen cat section. I am not sure if that's what you meant.
Right now my stock header/cat/midpipe with the stromung muffler is about as loud as I'd like the car to be. Once I put on the header/cat/bigger midpipe, I'm assuming it will get louder... so should I put a resonator in the midpipe? How do I know what type or size or quality of resonator to ask for (I know nothing about this). I don't want to make the car sound like crap or lose power from having a resonator, I would just like it to be a little quieter if the Brullen headers/cat are going to make it loud.
jonathan
Old 10-20-2004, 10:17 PM   #9
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
haha na i wasnt saying that puttinh a catback in would take out the cats. I was saying that if you plan to go cat-less in the future a resonator is a good idea because it tends to get raspy w/o it
a resonator really doesnt restrict flow. Its a straight through but its perforated around the inside of the tube. It wont make it louder, just a little deeper
Old 10-20-2004, 10:37 PM   #10
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Sounds good. I can't wait to get this all together this weekend (weather permitting).
j
Old 10-21-2004, 03:02 PM   #11
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
You said you got your brullen header/cat to fit your stock midpipe. Do you know if it just bolts onto the stock midpipe or if there was some modification that needed to be done first? If the midpipe didn't fit, did you have to take your header and cat to the exhaust shop and have them install them for you?
jonathan
Old 10-22-2004, 12:09 AM   #12
iON Performance Inc
Vendor
Member#: 7673
ilmaestro - The mid-pipe needs to be modified with the supplied receptacle for the gasket to fit on the stock mid-pipe. All of our header packages come with this adaptor piece so that it can be used on other systems.
iON Performance Inc is offline   Reply With Quote
Old 10-22-2004, 07:06 PM   #13
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Thanks for the response. I do have some sort of donut/adapter, but it appears to be 2.5" to 2.5", not meant for the stock midpipe. This is all I got since I bought the setup used...
jonathan
Old 10-24-2004, 05:05 PM   #14
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
FS: for RS/TS: Brullen header/cat-back, Injen CAI, WRX rims Ice Master Canada Region Forum 13 06-30-2005 02:50 PM
CEL and Brullen header/cat ilmaestro Normally Aspirated Powertrain 10 02-26-2005 11:52 AM
Brullen header/cat with axleback lildragn11 Normally Aspirated Powertrain 5 07-09-2004 09:07 PM
WTB: Brullen Headers + cat = used Kucheto Private 'Wanted' Classifieds 3 02-16-2004 11:43 PM
brullen headers/cat?? spt_impreza Canada Region Forum 17 12-26-2002 02:54 PM
