Old 10-19-2004, 03:05 AM   #1
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
Default ABS or no ABS in autocross w/non-stock brakes?
I would like to hear from people who run non-stock brake calipers, and I would to know whether or not you disable your ABS when autocrossing and why. I right now am using STi non-Brembo 4-pots in the front, and H6 Legacy brakes in the rear, and I feel like my ABS is going on too early/ being intrusive. Has anyone else with a similar setup experienced this? Then again, it might just be my bald Azenis .
-Wes
RebelINS is offline   Reply With Quote
Old 10-19-2004, 08:22 AM   #2
Scooby Freak
Member#: 40751
'94 SER
I used to think my ABS was coming on too early. Untill I pulled the fuse & realized I was just expecting way too much from them, as I locked up all four tires & slid off course
Just try it, then you will know for sure.
Scooby Freak is offline   Reply With Quote
Old 10-19-2004, 10:13 AM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
If you aren't used to driving a car with no ABS then it's going to take some getting used to. You can't just stomp on the brakes because you will lock them up, a lot easier than you think. It's probably easier to modulate the brakes with the ABS around than not.
Old 10-19-2004, 12:28 PM   #4
makofoto
Member#: 25243
2006 Legacy Outback
In our group of 20 or so AX'ing Suby ... the WRX's all seem to pull their ABS fuse, with stock or after market brakes or pads. The ABS comes on too early and obtrusively ... STI ABS seems O.K. Not sure if the ABS has been re-calibrated on the '04 WRX's ...
makofoto is offline   Reply With Quote
Old 10-19-2004, 01:07 PM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
I found my '99 RS ABS to be very competent and far better than driving without assuming you were fully acclimated to both. I also noticed that the proportioning goes to hell when you disable ABS.
Subaru ABS has definitely been changed and tweaked over the years, so I would think other 98-01 RSs are going to be the best comparison for you. What the WRX and STi are experiencing isn't necessarily all that relevant.
ColinL is offline   Reply With Quote
Old 10-19-2004, 07:32 PM   #6
t.renz
Member#: 49067
2006 BMW 330i ZSP
Snob Silver
LOL I tried that too last year in my ESP F Body (the abs likes to freak out in those too) and wound up boiling the front tires.
t.renz is offline   Reply With Quote
Old 10-19-2004, 07:48 PM   #7
joey1313
Member#: 53839
2005 STi, 06 S2K
Brakes....You wimps use the brakes....
joey1313 is offline   Reply With Quote
Old 10-20-2004, 12:45 AM   #8
AlpineFD
Member#: 42573
2004 WRX
I sometimes pull the abs fuse depending on the course. When ABS is disabled, the car turns in better under trail braking me thinks =) However, one of our local course is pretty dusty and I have better braking performance leaving the abs on. On a stright line braking, you can't outthink the computer =)
AlpineFD is offline   Reply With Quote
Old 10-20-2004, 12:45 AM   #9
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
if your nto used to it you'll be locking them up all the time. i ran all last season with abs on and know how to handle the car with it so i'm faster with it on casue i know how it reacts.
-Jason
#54 STX
angryfist is offline   Reply With Quote
Old 10-20-2004, 01:54 AM   #10
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
there's a reason Lambos, ferraris, porsches, and every other high performance sports car comes with ABS standard.
projectrally is offline   Reply With Quote
Old 10-20-2004, 04:02 AM   #11
makofoto
Member#: 25243
2006 Legacy Outback
Just checked with one of our top drivers ... 2nd in PAX at the last event out of 125 drivers ... he doesn't disconnect his ABS with his '00 Impreza ...
Old 10-21-2004, 02:02 AM   #12
Skibum4444
Member#: 21914
2002 WRX/2013 BRZ
05 Legacy GT Wagon
No,My nickname to some is Conebasher.
Skibum4444 is offline   Reply With Quote
Aftermarket brakes, no ABS? drivingkingwrx Brakes, Steering & Suspension 10 09-11-2007 11:45 PM
no luck in the tech forum, slotted brake question 1FastREX Texas Impreza Club Forum -- TXIC 26 06-01-2007 09:43 PM
ABS vs No ABS in snow...my experience express_wagon New England Impreza Club Forum -- NESIC 42 12-10-2005 02:21 PM
AutoX, ABS or No ABS? makofoto Motorsports 26 02-15-2004 11:54 AM
Gravel roads - ABS or no ABS? 8Complex General Forum Archive 7 06-20-2000 10:35 PM
