Notices
Old 06-23-2001, 05:10 AM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Default MRT CE light problem, anyone?
I reset my ECU but it came back again. I am wondering if it will just go off like the one guy I talked to. Mine is bright and glowing and I am wondering if there will be any damage from driving with it on for a while. Otherwise the performance is great and the gas mileage has gone from 280 to 300 for 14 gallons to 330 to 350.
Anyone know what is goin' on.
Scootr
scootr is offline   Reply With Quote
Old 06-23-2001, 09:17 AM   #2
aRSe
Member#: 6112
too many
to list
Default CHECK ENGINE light
The ECU is getting an "out of range" signal from one or more of the devices it uses to adjust the air fuel mixture ratio.
There is a recall on 02 sensors for MY01 vehicles
It would be a good idea to state what you are driving
aRSe is offline   Reply With Quote
Old 06-23-2001, 04:37 PM   #3
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Default MRT
I have a 2001 RS and I thought that the recall was only on 2000 models.
Old 06-23-2001, 04:46 PM   #4
slide
Member#: 1130
2013 STI Hatch
Its your o2 sensor, The pipe isn't hlding heat. MRT "heat coating" is no more than BBQ paint. Get the header heat coated, about 100- 150 bucks. The performance will go down once the O2 is working properly though
slide is offline   Reply With Quote
Old 06-24-2001, 12:22 AM   #5
Julian
Member#: 1182
MY00 RS
BRP
If you were affected by the O2 sensor recall, you should have gotten a letter. Not every car of any year was affected, but various ones were. I guess it couldn't hurt to call up your dealer and rattle off the VIN number to see if it is one of the recalled ones...but I'd wonder what they would think about the exhaust.
FWIW, I plan to P/C my header section when I get it. Might take care of the CE light, but will at least not smoke like a mofo for the first few days.
Julian
Julian is offline   Reply With Quote
Anyone changed high-flow cat without CE light problem? tabolau Normally Aspirated Powertrain 1 06-07-2001 08:24 PM
('93-'01) Engine Overheat, CE light problem Piusma Impreza Forum 11 06-04-2001 05:35 PM
CE light problem please help me! ac_gohan Bay Area Impreza Club Forum -- BAIC 15 02-10-2001 10:56 PM
