Old 10-19-2004, 05:34 PM   #1
Sleepr56
Member#: 67326
2015 WRX Limited
World Rally Blue Pearl
Exclamation HelP! Starting Problems
Hey guys, a noob to the subaru forum, but have had lots of fun workin on Joncas' subie (dunno if you guys remeber his supercharger set up)...anyways, just picked up a 1994 Subaru Impreza L, fwd, 4 dr, white etc. Picked it up for 600 bucks, with a new battery and starter freshly installed.
Since i picked up the car, it has struggled now and then on cold starts. So me thinking its not that big of a deal ignored it, until now, where everytime you try to start it cold it will not start. I sit in the car and keep cranking it for it to finally catch, idle hops around, if you touch the gas it stalls out, car shakes, etc etc etc. Finally after like 5 min of this randomly idle, it shutting down, me restarting, it will catch, go to a normal 2500rpm cold idle and run fine. If i press the gas at all during this start up it will stall the car out immediately. Also i have a perminent CEL thrown, which is crazy annoying with the fans that constantly stay on....
Once the car is up and running it seems to be offly junpy on the throttle like letting go and pressing the gas, which make shifting jerky and normal driving a little rough. This is not a big concern, its the starting that is. Here is what i have done so far with Joncas' help....I cleaned out the IAC valve, reset the ecu, still got nothing, and we played with the idle to see if we could hold it up any higher. I changed the air filter, oil, plugs wires etc. I have read about the coil packs on subie's being a constant prob, didnt know if i had to check the connection on this at all....
So guys, what should i do. Winter is comming, I really enjoy the car besides this small issue, and I am not afriad of it not starting when snow hits. Thanks a lot
Matt
Sleepr56 is offline   Reply With Quote
Old 10-19-2004, 05:45 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Info on pulling codes, on a 94 you can do this yourself without a scanner-
http://www.troublecodes.net/Subaru/
If the fans are always on that may be a sign of a bad coolant temperature sensor which will definitely cause hard starting and poor running.
Old 10-19-2004, 11:17 PM   #3
Sleepr56
Member#: 67326
2015 WRX Limited
bump for the night and more help, prices and places to buy new stuff to help. Thanks
Matt
Old 10-20-2004, 11:00 PM   #4
Sleepr56
Member#: 67326
2015 WRX Limited
still searching the forums, and everything that describes my problem is allways let unanswered. Ahhhhh
help!!!start problem leesung85 North West Impreza Club Forum -- NWIC 18 03-21-2007 05:08 PM
Help With starting problems zroom tsuchiya Subaru Conversions 7 08-25-2004 12:03 AM
please help in desperate need of advice for starting problems y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-14-2004 08:49 AM
Emergency starting problem, help! KURB21 Service & Maintenance 4 11-17-2003 09:19 PM
engine starting problem, help, please!! KURB21 Rocky Mountains Impreza Club Forum -- RMIC 3 11-16-2003 10:14 PM
