Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 10-20-2004, 05:18 PM   #1
PolTec Inc
Vendor
Vendor Sales Rating: (2)
Member#: 41768
Default End-Links for any Subaru - STi, WRX, Legacy and Forester, Adjustable Lateral Links
We offer:
ADJUSTABLE FRONT END LINKS FOR STi, WRX and RS priced from $79 to $109 for any Subaru
ADJUSTABLE AND SOLID REAR END LINKS priced from $89 to $169 depending on a model.
SWAY BAR COLLARS priced @ $35. Those will allow you to correctly position the sway bar and keep it from moving to the side.
4-PIECE PILLOW-BALL, ADJUSTABLE LATERAL LINKS FOR WRX, STi, AND RS priced FROM $660 TO $880 depending on a version.
In few days, we will also start offering 6-piece, pillow-ball lateral links as well as 4-piece and 6-piece lateral links with urethane bushings designed for those autocrossing.
Here are some pics of the Carbon Fiber , Carbon Fiber/Kevlar and Titanium links, they will be available next week (Dec 7) for STi and WRX Sedan.
D
Thanks
Dariusz
PolTec Inc.
708/308-0947
PolTec Inc is offline   Reply With Quote
Old 10-22-2004, 05:56 PM   #2
PolTec Inc
Vendor
Member#: 41768
Bump....
Old 10-25-2004, 11:10 AM   #3
PolTec Inc
Vendor
Member#: 41768
As promised, here are the pictures of the 6-piece lateral links sets that are available as of today.
These are aluminum pillowball version. MSRP for those is $990 and they include special adjustable end links that mount directly to the wheel hub (upright) thus increasing the effectiveness of your sway bar. We have versions that fit WRX, RS and STi
Here is a steel pillowball version. MSRP $720.
For those of you that cannot use the pillowball version, either due to competition rules of NVH issues, we also offer bushing version of both the 6-piece and 4-piece sets. All the components are aluminum (including adjustment nuts), mostly 7075 alloy, and the bushings are comparable with the Group N bushings.
4-piece sets are $495 and are available for WRX, RS, and STi
6-piece sets are $555 and include the adjustable pillowball (spherical bearing) hub mounted end links. Also available for WRX, RS and STi
All of those are considerable lighter that stock parts and are adjustable so that you can use them to adjust camber and toe without the need to disassemble anything.
They feature special nuts, designed by us, that allow for easy access.
Aluminum construction ensures corrosion resistance unlike any other.
Let us know if you have any questions.
Thanks
Dariusz
www.poltec.us
708/308-0947
info@poltec.us
Old 10-25-2004, 04:43 PM   #4
mr. m
Member Sales Rating: (4)
Member#: 44229
2000 2.5 RS
blue ridge pearl
so the bushings are rubber and not polyurethane?
mr. m is offline   Reply With Quote
Old 10-25-2004, 08:31 PM   #5
PolTec Inc
Vendor
Member#: 41768
No, the bushings are polyuretane but the actual diflection under load is about the same as for the links with group N bushings.
Old 10-27-2004, 11:25 PM   #6
PolTec Inc
Vendor
Member#: 41768
Bump...
Old 10-29-2004, 07:18 PM   #7
PolTec Inc
Vendor
Member#: 41768
Old 10-30-2004, 01:40 PM   #8
kidatari
Member#: 10441
I'm eager to see some reviews of the aluminum pillowball lateral/trailing link set, it looks very nice, and at $600 cheaper than the cusco ones, a very appealing item indeed.
What is the weight difference between the Aluminium and Steel versions of the pillowbaall links?
kidatari is offline   Reply With Quote
Old 10-31-2004, 01:40 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I have dealt with Poltec early on.
I have been happy with the service and quality of product, so........use them as a vendor with my blessings (for what it's worth).
Old 10-31-2004, 04:22 PM   #10
Patrick Olsen
Member Sales Rating: (29)
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm curious how the spindle-mounted endlinks work - do you have a pic of them installed?
Pat Olsen
'97 Legacy 2.5GT Sedan
Old 11-01-2004, 11:50 AM   #11
PolTec Inc
Vendor
Member#: 41768
Originally Posted by kidatari
What is the weight difference between the Aluminum and Steel versions of the pillowbaall links?
There is about 1lb difference between the steel and aluminum pillowball version.
Patrick,
Here is a picture of the end links installed with Perrin Sway bar and our 6 piece lateral links. The end links are tilted slightly backwards because the rear of the car is lifted, once the wheels are on ground, the end links would be in more vertical position.
Charlie-III, thank you for the recommendations.
Thanks
D
www.poltec.us
708/308-0947
info@poltec.us
Old 11-03-2004, 10:16 AM   #12
PolTec Inc
Vendor
Member#: 41768
Ttt...
Old 11-03-2004, 01:33 PM   #13
psyber_0ptix
Member Sales Rating: (25)
Member#: 60671
1992 Turbo Miata
351whp/344tq
bump
how exactly do you "lock" these rods in place so their settings dont get messed up?
is there a locknut at the end? i looked pretty hard and cant figure it out
also, i emailed you reguarding links for 99 l
psyber_0ptix is offline   Reply With Quote
Old 11-04-2004, 11:30 AM   #14
PolTec Inc
Vendor
Member#: 41768
Originally Posted by psyber_0ptix
bump
Yes, there are lock nuts on both ends of each tube. They are the silver(aluminum) discs with holes on the outside. For example you can see them on the first picture between the red pillow ball bearings and the black rods.
We make those ourselves so that you can tighten them without removing the lateral links. If they were regular nuts, you would not be able to use any regular wrench in the area where they mount to the chassis, as the two flanges between which the lateral links mount, leave no room for conventional hex wrench. We include the tools for these nuts with the lateral links.
Thanks
Dariusz
www.poltec.us
708/308-0947
info@poltec.us
Old 11-05-2004, 11:16 PM   #15
PolTec Inc
Vendor
Member#: 41768
We will be closed all next week and back in ubsiness on Nov. 15. All current orders will be shipped by tomorrow and any new orders will go out on Monday Nov. 15.
Thank you
Dariusz
Old 11-15-2004, 09:32 AM   #16
PolTec Inc
Vendor
Member#: 41768
We are back now, all outstanding orders will be shipped today.
D
Old 11-17-2004, 07:28 PM   #17
PolTec Inc
Vendor
Member#: 41768
Old 11-18-2004, 11:16 PM   #18
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
i got an email from paypal saying there was an additional shipment created for my order and then got another saying a shipment was cancelled. im going to assume somebody goofed and that my order was already sent. its hard to tell with the crappy tracking the usps provides.
steve m
omaha ne 68157
Old 11-19-2004, 09:52 AM   #19
PolTec Inc
Vendor
Member#: 41768
steve m
omaha ne 68157
Steve, unfortunately it's us who goofed, we put a wrong address on your package and it has returned to us, we had to re-ship it yesterday. I apologize for the delay.
Regards
Dariusz
Old 11-19-2004, 02:49 PM   #20
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
alrighty, as long as it gets to me next week its not going to be much of a problem.
Old 11-19-2004, 09:12 PM   #21
BIGSKYWRX
Member Sales Rating: (102)
Member#: 7958
09 GH B+
Dariusz
I noticed on my pillow sway links there appears to be a small threaded hole- is this to put a grease zirk on? If it is, what grease do you reccomend? If I'm imagining things- it was a couple of months since I last looked at them- it wouldn't be the first time
Thanks
Big Sky
Old 11-22-2004, 04:28 PM   #22
PolTec Inc
Vendor
Member#: 41768
Originally Posted by BIGSKYWRX
Dariusz
Thanks
Big Sky
These are not through holes, but you could drill them out if you wanted (you'll need to disassemble the end links and rotate the ball to do this) and tap them. As always, I recommend marine grease or any other grease that can withstand water exposure.
D
Old 11-22-2004, 11:19 PM   #23
BIGSKYWRX
Member#: 7958
09 GH B+
D- OK didn't look that close I'll leave them be for now.
Bump for very some very well built links.
Mike
Old 11-26-2004, 10:35 AM   #24
PolTec Inc
Vendor
Member#: 41768
Old 11-26-2004, 09:58 PM   #25
STi-MAN
Member Sales Rating: (24)
Member#: 70252
05 STI
blue
are the prices for the front endlinks for the 05 sti, shipped? also whats the difference between the steel and the alloy steel and the weight? thanks
STi-MAN is offline   Reply With Quote
Wagon and GC8 adjustable lateral links kingsubi Suspension/Brakes/Handling 13 04-08-2012 02:09 AM
Trailing arms, and adjustable lateral links for STI Token-Negro Motorsports Specific Items 0 05-24-2010 10:31 AM
For Sale: Subaru Impreza or Legacy or Forester Snow Tire Steel Rims 16 inch Essty-eye Wheels/Tires 11 10-04-2008 04:14 AM
WTT: Whiteline Adjustable Lateral links for Stock RS Lateral links Zephyr Tri-State Area Forum 1 11-28-2005 12:17 PM
Titanium and Carbon Fiber Lateral Links Only Here, End Links for any Subaru PolTec Inc Suspension/Brakes/Handling 89 01-31-2005 03:27 PM
