Old 10-20-2004, 04:44 PM   #1
nonturbosubaru
Member#: 72394
2000 2.5rs Impreza
blue
Default what type of cams for '00 rs
what type of cams should i go with in my 2000 2.5rs, the mods i have are short ram intake, full ignition system, headers with stromung track pipe and greddy exhaust, 11 pund flywheel with stage 3 clutch, short throw shifter with sti linkage, super AFC 2, rota 15' sub zeros with falken azenas (they weigh pretty much nothing), and fully pully kit. i want somthing very agressive that gives me the most power to the ground. does anyone have any ideas?
nonturbosubaru is offline   Reply With Quote
Old 10-20-2004, 06:10 PM   #2
Seeinstars
Member#: 31226
2000 2.5RS coupe
2004 jbp forester xt
I have twe stage II on my 2000 rs.
I love them.
got them from WWW.boxer4racing.com
Seeinstars is offline   Reply With Quote
Old 10-20-2004, 06:25 PM   #3
ratt_finkel
Member#: 46218
06 EVO 9
Sell the ignition upgrade. It's a waste of money. And I vote TWE as well.
ratt_finkel is offline   Reply With Quote
Old 10-20-2004, 08:09 PM   #4
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
PAECO is cheaper, and aside from those two I hear COBB cams are nice. Someone had one break though...
powerlabs is offline   Reply With Quote
Old 10-21-2004, 09:32 AM   #5
nonturbosubaru
Member#: 72394
2000 2.5rs Impreza
blue
it actully helped out alot, thanks though
Old 10-21-2004, 01:21 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Old 10-21-2004, 03:15 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yeah, that someone sent the broken cam to Cobb and they determined that he was running it with the lash incorrectly adjusted...
10K mi on my Cobb cams and 151hp to the wheels at 5000ft...
Old 10-21-2004, 03:59 PM   #8
powerlabs
Member#: 45790
SUPERCHARGED
Matt:
I didn't know that. Your results are my inspiration to keep going N/A, BTW (and a lot of other people's too, I suspect
Except I plan on getting even more HP out than you because I want to reflash my ECU (advanced ignition timing, higher redline) and tune the A/F ratio with an Apexi S-AFC 2 on a dyno. I also recall you don't have a high flow cat. converter?
Old 10-21-2004, 04:13 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
Matt:
Nope. I have a high flow cat in my Cobb Headers. What I don't have for now is a track pipe. And it sounds like you wanna bench race. My car will be reflashed and dyno tuned by Trey as soon as they finish the AP for the RS. Afterall, I would be an idiot to run an EJ257 block with 12:1 CR pistons without tweaking the ECU...
BTW,
There is no need for an AFC if you have a reflash. That is redundant...
Old 10-21-2004, 04:48 PM   #10
powerlabs
Member#: 45790
SUPERCHARGED
Wow, you are running 12:1 compression?
*Bows down* OK, I guess I won't be beating your dyno results after all
Re: AFC; I will probably have to send my ECU in for the reflash, so I doubt the A/F ratio will be very well tuned without the tuner being able to measure it and adjust on the fly... I am hoping the S-AFC will take care of that...
Plus, I just love the way it looks sitting on my dash
Old 10-21-2004, 08:44 PM   #11
subru
Member#: 58959
01 imprezaRS
Do cams cause a check engine light to go on? In particular twe stage II.
subru is offline   Reply With Quote
Old 10-21-2004, 09:26 PM   #12
Seeinstars
Member#: 31226
2000 2.5RS coupe
Default !
Depends if your car wants to be picky or not, mine throws a missfire code for all 4 cyl's, but other people's does fine. I don't really care about the light, But the twe cams makes aa huge difference! I'm very happy with them.
Old 10-22-2004, 02:38 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
My car does not throw a CEL because of the cams. I only know this because I took off my headers a couple of weeks ago to pass emissions. 2000mi w/o a CEL. But as soon as the headers go back on I am pretty sure my 0420 will return...
Old 10-24-2004, 10:33 AM   #14
Seeinstars
Member#: 31226
2000 2.5RS coupe
PO420 is the cat. converter code. To fix this you need the mil o2 sensor resistor. This light is not caused by the header being a thiner metal and cooling the exhaust down before it reaches the cat. The resistor will fix this, its not caused by the cams.
you can by this resistor here.
http://home.att.net/~teaguesauto/exh...st%20Catalytic
-mike
Old 10-24-2004, 12:51 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
-mike
Mike,
You aren't telling me anything that I didn't already know. The point of what I mentioned was that the cams are not throwing any codes on the car. That is what this guy wanted to know about. I just explained exactly how I knew it wasn't the cams because many of the active members of this board know that I got the cams AFTER the headers. And I was trying to emphasize that at some point in an NA build you will start seeing CEL's and generally learn to live with them...
Old 10-24-2004, 10:21 PM   #16
Seeinstars
Member#: 31226
2000 2.5RS coupe
Mike,
Sorry I miss understood you. I got a cel after put the JE pistons in it. It runs great, but the computer doesn't really know whats going on.
Old 10-25-2004, 10:49 AM   #17
AzNStiImpreza
Member#: 17181
2013 Scion FRS
Whiteout
i have Rallispec cams, and my car does the same exact thing. misfire misfire misfire misfire.
you cant get the rallispec cams though because only 3 sets were made i believe.
AzNStiImpreza is offline   Reply With Quote
What type of bulb for 06 fog lights? Mooneyes13 Interior & Exterior Modification 7 06-03-2006 06:03 PM
What type of paint for bulbs? scoobydrew06 Electrical & Lighting 2 10-17-2005 11:14 PM
What type of springs for a 99 Impreza RS? Polishguy701 Brakes, Steering & Suspension 2 04-22-2003 05:44 PM
('93-'01) What type of grease for sway bar??? HIHO Impreza Forum 5 10-26-2001 01:41 AM
What type of paint for interior plastic vent pieces? bryant aka sky Interior & Exterior Modification 11 08-09-2001 03:33 AM
