Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-21-2004, 12:14 PM   #1
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Default Oil in spark plug hole, 91 2.2???
This is the original 2.2 motor where the plugs are at a severe angle and do not go thru the valve/rocker arm cover. So there's no seal there. There appears to be no oil anywhere else but enough accumulated in 2 weeks to short out the plug and cause it to miss. Where is it coming from? TIA.
rallynutdon is offline   Reply With Quote
Old 10-21-2004, 01:35 PM   #2
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Saw your post on the USMB. It has to be coming from the valve cover gasket. I don't know where else it could come from...
DerFahrer is offline   Reply With Quote
Old 10-21-2004, 03:54 PM   #3
rallynutdon
Member#: 24568
1993 Impreza, WRX
But the valve cover gasket is lower than the spark plug hole! And there's no sign of leakage on the top or sides of the cover. I'm totally perplexed.
Old 10-21-2004, 04:01 PM   #4
Bakergtt
Member#: 59207
'05 X was 98 LGTT
is there a crack in the cut out for the spark plug??
Bakergtt is offline   Reply With Quote
Old 10-21-2004, 10:18 PM   #5
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Which side is it leaking on? If it's the Drivers side, Usually the o ring on the Oil Filler tube causes that. If it's on the passenger side, the only thing I could think it would be is the Power Steering Pump.
Mike
wrx_driver_2002 is offline   Reply With Quote
Old 10-22-2004, 11:04 AM   #6
plasticguy
Member#: 70345
how does oil cause a miss ? The outside of the plug is shorted to the head, by way of being screwed into it. Also is the compression healthy in that cylinder ?
plasticguy is offline   Reply With Quote
Old 10-22-2004, 12:17 PM   #7
johnny_mastin
Member#: 68566
'05 Legacy GT Ltd
Dragon Wagon, V2.0
You can get a miss because the oil fouls the plug between the center electrode and the grounded prong.
johnny_mastin is offline   Reply With Quote
Old 10-22-2004, 01:06 PM   #8
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I forgot to add that it could be coming from the PCV hoses on either valve cover. I have had to put hose clamps on them before because the wire type spring clamp could not seal well enough. Just another idea.
Mike
Old 10-22-2004, 01:08 PM   #9
rallynutdon
Member#: 24568
1993 Impreza, WRX
This plug boot is not real tight and if I hose down the engine, water will get in there and cause the same problem. I usually sop the water out (but if you don't it will eventually evaporate or boil out, the oil won't).
Oil inside spark plug holes 240c Forester Forum 5 09-15-2009 04:34 PM
Oil in spark plug hole 7andSubie Owner Normally Aspirated Powertrain 3 09-18-2005 01:52 AM
Oil in spark plug tube Flexy Service & Maintenance 16 09-16-2005 01:17 PM
2.2L Crankshaft Positioning Sensor needed - also, oil in spark plugs question marcus12 New England Impreza Club Forum -- NESIC 10 01-11-2005 03:49 PM
Oil in spark plug NickSTi South East Region Forum 8 08-27-2002 09:55 PM
