Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 10-21-2004, 06:57 PM   #1
STIdreamer17
Member#: 68853
'02 WRX
Question 93 2.2t intercooler
ok i have a wrx intercooler on my stock 2.2t engine, but the intercooler is all messed up. i looked up the engine to see what kind of intercooler was accually used stock and it didnt show one, i showed a pipe instead. so does this mean i can just run it stock with no intercooler and a have metal tubing fitted for it?? im not going to do any racing or anything until i start upgrading, i just need something to get from place to place right now, would it hurt to not have an intercooler?? thanks
Joe
STIdreamer17 is offline   Reply With Quote
Old 10-21-2004, 07:08 PM   #2
jake15
Member#: 36662
1990 legacy dohc 2.2
6speed w/ brembos bishes!
turbo legacys never had an intercooler, like you said, they have a plastic pipe. if you have the stock turbo you should be able to just go to a dealer or a junkyard and find the pipe. but remember if you start turning up the boost and changing turbos, and intercooler is a must.
jake15 is offline   Reply With Quote
Old 10-21-2004, 07:11 PM   #3
STIdreamer17
Member#: 68853
'02 WRX
oh yeah, i have everything stock right now, and i have plastic plumbing pipe in there right now, but i dont have the blowoff valve, there is a place right down the road called pro-flow which could put some custom piping in for me and a place to mount the blowoff valve. thanks
Joe
Old 10-21-2004, 07:13 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
No factory IC. You can run the car with no IC, just dont go past the 11 psi range.
subiekid is offline   Reply With Quote
Old 10-21-2004, 07:20 PM   #5
STIdreamer17
Member#: 68853
'02 WRX
do you have a picture from the front?? oh and where do you have the blow off valve, because the guy helping is trying to argue with me saying that i dont need it.
Old 10-21-2004, 07:44 PM   #6
subiekid
Member#: 25516
If you dont have a blow off valve you can piss your turbo good by in a few k miles. The OEM bov is under the pipe. I have some pics let me find them.
Old 10-21-2004, 07:50 PM   #7
subiekid
Member#: 25516
Here you can see the pipe that has duct tape on it is the OEM pipe that goes from the intake pipe to the bov. The bov is just before the TB, but on the underside. I dont have my car up here at college so I cant take any pics.
Old 10-22-2004, 04:46 AM   #8
ncarn8
Member#: 71419
Yeah everyone except US got intercooled legacies. Water/air 89-92 and then air/air thru to present. Y dont u dump that crappy pipe put ure WRX intercooler on as ure first mod itd be worth some extra ponies for sure. theyre pretty easy to modify to fit just get some bends and redo the whole intake
ncarn8 is offline   Reply With Quote
Old 10-22-2004, 01:56 PM   #9
STIdreamer17
Member#: 68853
'02 WRX
i have a blow off valve, i have the oem and a perrin adjustable. as far as the intercooler goes the wrx intercooler i have has kind of a big problem. the intake wasnt taking in enough air and sucked the filter apart. small pieces of it is all through the intercooler, so im going to get the pipe put on, then upgrade the turbo. im going to have to buy a new intercooler either way because the guy that i bought the car from had the intercooler rigged up and there is alot of leaks through out the hosing. this is just to have the car running, because as of right now i dont have a car to drive. thanks
Joe
Old 10-22-2004, 03:40 PM   #10
subiekid
Member#: 25516
What kind of filter did you have? I have never heard of a filter getting sucked into the intake. I hope nothing got past the IC and into the motor.
might try bbs.legacycentral.org
i am sure you can find a turbo/TB pipe there.
Old 10-22-2004, 03:45 PM   #11
STIdreamer17
Member#: 68853
'02 WRX
oh no, it was pulling it apart, ill take pictures of it and post them, it was little pieces, but you know how small the fins are in the intercooler. and i checked everything, im pretty sure its all in the intercooler. i bought a new filter with a screen mess in it so that it wont happen again. thats how i bought it though. so im not really sure what happened.
Old 10-22-2004, 05:08 PM   #12
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
I'm wondering how the pieces went through the Maf sensor (they have screens don't they) and through the hot turbo fins up into the intercooler. Those are some nasty aggressive pieces of filter.
Kevin Thomas is offline   Reply With Quote
Old 10-22-2004, 05:49 PM   #13
STIdreamer17
Member#: 68853
'02 WRX
i dont know if thats what is cloguing it, thats what im guessing, i pulled out the filter and it was starting to suck the filter part out. and im talking about a lot of small pieces, maybe one piece isnt alot, but they add up if they collected in one spot.
Old 10-23-2004, 03:28 AM   #14
-k-
Member#: 43881
01 25RS
You are fine to run stock with no IC. Turbo Legacys make a fun 160ish HP. If you use a BOV not the stock one make sure to plug the return pipe. When you say upgrage the IC what are you looking at, the WRX intercooler is OK on some 280hp WRX's. That is a long way to go from 160hp
-k- is offline   Reply With Quote
Old 10-23-2004, 11:37 AM   #15
LibertyEJ22T
Member#: 69198
I am 99% sure that a 02-05 WRX I/C will not fit without some banging of the firewall. You can go without it as others have already mentioned. If you decide to up the boost and install a top mount then check with vendors and search for the actual foreign market intercooler made for that car. The early Ver I-Ver III WRX I/C works perfectly.
LibertyEJ22T is offline   Reply With Quote
Old 10-23-2004, 02:12 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I know some folks have taken a dremel or grinder to the TB to shorten it to make room for the WRX TMIC. I have a spare if anyone want to go this route and not alter their stocker...
But personally I would buy an upgraded TMIC from MRT that was designed to fit the Liberty/Legacy turbos...
Old 10-23-2004, 04:00 PM   #17
STIdreamer17
Member#: 68853
'02 WRX
When i said upgrade the intercooler, i meant when i get a bigger turbo then i will also get an intercooler. i was planning on getting a TD05-16g, any suggestions on which intercooler is should get?? I also found a stock TB pipe. the only problem now is where i should put the blow off valve. and i also was wondering is there somewhere that it dumps the boost, because im afraid that when it opens to dump, water or dirt will get sucked into the bov. thanks
Joe
Old 10-24-2004, 12:49 AM   #18
subiekid
Member#: 25516
Joe
Use the stock ej22t bov.
Old 10-24-2004, 01:56 PM   #19
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Another option is a Saab 900 Intercooler and a Mazda RX-7 Inline BOV. It's pretty easy to make up some piping for it. We pressure tested mine to 30 psi.
You can get them on ebay for about $40 - $100
Here's Subachads old engine
BrysImpreza is offline   Reply With Quote
Old 10-24-2004, 05:39 PM   #20
STIdreamer17
Member#: 68853
'02 WRX
Ok, i think i have it now....a guy gave me a site to download the manual for the engine. it shows me where everything goes. i feel like a jacka**, turns out the bov i was trying to use was the stock wrx bov from the intercooler. i feel like an idiot. well thanks for everyone's help. i appriciate it. thanks
Joe
Old 10-25-2004, 12:08 AM   #21
ncarn8
Member#: 71419
Good u sorted it out, me finks. What is the addr. of the site u d/l the manual from? i cant seem to find much...... thnx
Old 10-25-2004, 02:55 AM   #22
subiekid
Member#: 25516
Hey its all good. When I first started on this site I knew nothing about cars, now I am tuning by myself , swaping out things like manifolds....
You learn by posting and asking question. Dont be scared but look out cause some of the forums can be kind of harsh. You might find bbs.legacycentral.org a nicer place. I post on both because the both have good things. This site has so many people while Legacycentral seems to have nicer and more well educated people.
Old 10-25-2004, 07:09 AM   #23
STIdreamer17
Member#: 68853
'02 WRX
ncarn8, heres the original site with the different manual's. http://www.finleyweb.net/default.asp?id=142 i d/l the parts manual.
subiekid, i agree with you, most of the people are nice on this smart and reply quickly where as on legacy central more people understand subbie's. but i wouldnt have found that site if you wouldnt have given it to me, thanks.
Old 10-26-2004, 04:48 AM   #24
ncarn8
Member#: 71419
Cheers sti that was exactly what i was after. good luck with ure project
Old 10-26-2004, 03:35 PM   #25
STIdreamer17
Member#: 68853
'02 WRX
hey thanks man. good luck to you too
OR:FS - Misc Engine - V7 Cams / WRX Cams / WRX Rods / 2.2t Crank / 2.2t Rods mick_the_ginge Engine/Power/Exhaust 6 03-20-2007 02:17 PM
WTT: my auto 2.2T for your manual 2.2T shemoves South West Impreza Club Forum -- SWIC 1 02-27-2006 03:10 AM
92-94 2.2T into a 93 1.8L subachad Subaru Conversions 8 10-10-2003 10:57 AM
anyone got a engine layin around? 2.5? 2.2? 2.2t? mcu81 Tri-State Area Forum 6 07-19-2002 11:36 PM
93 Impreza L engine swap to 2.2T? japporeyser Normally Aspirated with bolt-on Forced Induction Powertrain 9 05-18-2002 02:30 AM
