Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-21-2004, 10:54 PM   #1
G.Subramaniam
Member#: 64528
Default Do Underdrive Pulleys damage alternator ?
I have noticed sometimes while driving the engine suddenly shuts off
The battery seems to be in good shape and even if jump-started, the pulleys spin, but the spark plugs refuse to fire ?
Is this an alternator problem
Are there new stronger alternators ??
G.Subramaniam is offline   Reply With Quote
Old 10-21-2004, 11:47 PM   #2
ScoobyNubieToo
Member#: 71743
Sounds like you better get this to a Subie dealer. Do you have any other mods besides under drive pulleys? I 've never heard of underdrive pulleys damaging the alternator but I have heard they they can damage your accessories because underdrive pulleys tend to "starve" your accessories of full power. I'm curious about any other mods because it sounds like it's an ignition problem that could be related to an improper ECU tuning map flash or a junky ECU piggyback chip. If I knew the mods U were running, I could probably narrow it down a little more for you.
ScoobyNubieToo is offline   Reply With Quote
Old 10-22-2004, 12:36 AM   #3
G.Subramaniam
Member#: 64528
I have a piggyback chip from Nextlevelracing for the last 3 months
I have a air cone intake
I have a hi-flow cat and a hi-flow 2.25 inch catback
Old 10-22-2004, 04:04 AM   #4
import111
Member#: 24447
2010 Evo GSR
GG
My guess is the piggyback chip. Just a shot in the dark though.
Ryan
import111 is offline   Reply With Quote
Old 10-22-2004, 11:04 AM   #5
Pat L.I.
Member#: 20498
2006 WRX TR
ive been running underdrive pulleys for over 40,000 miles without any trouble. Sounds like a timing or an air fuel mixture issue. which would be directly related to your chip.
most people around here do not use chips as there are not any that give proven trouble free gains. Its not like the vw world.
Pat L.I. is offline   Reply With Quote
Old 10-22-2004, 11:20 AM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I doubt the pulleys damaged the alternator, but it could be deteriorating anyway.
jamesfacts is offline   Reply With Quote
Old 10-22-2004, 12:21 PM   #7
jeffg
Member#: 2958
2001 WRX (GC8)
If the motor turns over but wont spark thats not a battery issue. The starter motor requires a lot more juice to turn over than the coil. When you installed your chip, I assume you spliced it into the wiring harness? I would double check those connections for a loose wire.
jeffg is offline   Reply With Quote
Old 10-22-2004, 02:31 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
112k mi on the car. Underdriven lightened pulley on the car since 10k mi. No problems. You decide...
Old 10-22-2004, 08:34 PM   #9
G.Subramaniam
Member#: 64528
The shop found I had inadvertently bottomed out while going over a pot-hole or a speed breaker or gone over a wooden plank on the road
This had damaged the oxygen sensor and created a short circuit that blew the 60 Amp Fuse
I was kind of surprised about the bottoming out since I just put in new suspension
KYB-GR2 and Eibach pro-kit 1.2 inch drop
what do you think of underdrive pulleys...like bomz? Meat Supply Normally Aspirated Powertrain 8 01-22-2007 11:35 PM
underdrive pulleys, alternators and hard hitting systems rexecutioner Car Audio, Video & Security 4 05-20-2002 12:47 AM
do underdrive pulleys help? Imprezafan1 Normally Aspirated Powertrain 22 09-25-2001 10:07 AM
('93-'01) do underdrive pulleys and a/c mix? Benjamin Tang Impreza Forum 8 07-20-2001 05:55 PM
Underdrive Pulleys, What do they do?? Mikemar Normally Aspirated Powertrain 9 06-19-2001 03:12 PM
