Old 10-21-2004, 11:26 PM   #1
squidney
Member#: 73018
Default 04 sti hid onto a 04 wrx???
anyone know how to put the hid from a 04 sti onto a 04 wrx headlight housing i have the ballast and bulbs with ignitors??? help ahha dunno wat to do since bulbs do not fit in the hole.....
squidney is offline   Reply With Quote
Old 10-21-2004, 11:35 PM   #2
MDChevyguy
Member#: 51024
2005 Dodge Durango
2004 WRX Just Sold
I know one of the things that you have to do is disable the daytime running lights in order to do the conversion. Check out Scoobymods. They may have step by step directions regarding this.
MDChevyguy is offline   Reply With Quote
Old 10-22-2004, 07:37 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It sounds like you don't have the complete headlight assemblies from the STi, only the HID components? That really isn't going to work well. As you are finding out, the halogen housings are made to accomodate H1 bulbs while the HID housings are made for D2R bulbs which are very different. Assuming it is even possible to physically install what you have, the results aren't going to be the same as installing a complete set of STi lights. The internal reflector designs of the halogen and HID lights are different even though they look similar so the lighting performance will not be the same, and due to the differences in bulb setup it will be difficult or impossible to align the bulbs correctly. The proper way to do this is to replace the entire headlight assembly.
Old 10-22-2004, 10:50 AM   #4
dithergizzard
Member#: 58232
Also see here for more information on that:
http://forums.nasioc.com/forums/showthread.php?t=651777
dithergizzard is offline   Reply With Quote
Newb Q: Blox Lugs fit okay onto 04 STI wheels on an 04 wrx? Strider327 Tire & Wheel 6 02-16-2010 10:08 PM
04 sti hid headlights on 05 wrx? team trucha racing Electrical & Lighting 5 05-25-2009 08:38 PM
04 STi BBSs onto 02 WRX? aasim_a Interior & Exterior Modification 19 05-06-2008 04:27 PM
04 STI TMIC onto 03 WRX ?? SpicyPeaNut Water/Methanol Injection, Nitrous & Intercooler Cooling 3 05-24-2007 01:01 PM
Steering wheel: 04 STi wheel onto 05 Wrx SLKatzdorn Brakes, Steering & Suspension 0 10-17-2006 03:25 AM
