Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 06-24-2001, 04:42 AM   #1
Imprezha
Member#: 6818
2004 STI 02 NSX
2010 Gen Cpe,03 CL Type S
Default Is it normal for subarus?
I was wondering if it's normal for subaru's to grind in going from 4th to 5th gear at high revs.
I have a my01 impreza 2.5 RS and whenever the rpms are over 3000rpms going to fifth it'll grind.
It's happened ever since I first bought it but didn't really let it bother me until my friend asked. Waiting for the rpms to drop below 3000
and then shifting into fifth is kinda of a pain when your passing on the highway.
Any suggestions will be appreciated.
Thanks!
Imprezha is offline   Reply With Quote
Old 06-24-2001, 01:32 PM   #2
e_a_olson
Member#: 7034
2005 Nissan Altima
2.5SL - Black
I dont think it's ever normal to grind gears, unless you aren't using your clutch. I'd get it checked out. Or don't use 5th.
/Eric
e_a_olson is offline   Reply With Quote
Old 06-24-2001, 03:25 PM   #3
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
Sounds like a bad syncro.
imprezadan is offline   Reply With Quote
Old 06-24-2001, 03:25 PM   #4
8Complex
Member#: 922
04 FXT
Red
There is a known problem with the synchros that causes that to happen. Take it to the dealer and tell them whats going on and take a tech for a drive (or tell them to really get on it until they find it). Should be a warantee replacement.
Old 06-24-2001, 04:51 PM   #5
Jimmy
Member#: 586
they won;t fix it i tryed
2 dealer and they give me the run around
Jimmy is offline   Reply With Quote
Old 06-25-2001, 01:02 AM   #6
jImp
Member#: 1741
1999 Impreza 2.5 RS
Rally Blue (Sold)
Why don't you e-mail SOA specifically telling them about every little detail of your situation?
I don't know if you can get it replaced under warranty because you have a 1999 RS.
jImp is offline   Reply With Quote
Old 06-25-2001, 01:29 AM   #7
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
If you have less than 60k miles it should be covered under the powertrain warranty.
What reason did the 2 dealers tell you they refused warranty?
Did your SOA area rep inspect your car, or was it the service dept people blowing you off. Ensure the area rep is involved in the final decision.
Albert is offline   Reply With Quote
Old 06-25-2001, 09:40 AM   #8
Jimmy
Member#: 586
because I had an intake and exhuast system
theey all give me the run around even the techican..
I have 51K on the car
I also notice the there was a quart of tranny fluid gone is this normal every 20 or so this happens
I think that why it grind from 4-5 I noticed this problem twice.
After i add the quart to the tranny the clutch noise went away too
when i would push the clutch down it would make this horrible scraping sound when the car was idleing but it stop after i added the quart in the tranny...If you get grinding CHECK the tranny fuild see if its full....
Listen to this only had my Jcsports cat back system from only 1 and the I have A fu***ing hole in the piping not the midpipe the pipe that goes from muffler to mid pipe ..I am going to call them today to see if they will send a new one..........
Jimmy
Old 06-25-2001, 09:44 AM   #9
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Default No wayy
They cant deny you warranty service on your tranny b/c you have intake and exhaust. It's unrelated to the tranny. Thats the law. They have to prove that the aftermarket add-on directly responsible for the problem to deny you service.
Samirr76 is offline   Reply With Quote
Is it normal for the revs to drop so quickly in neutral? Zoso Transmission (AT/MT) & Driveline 2 06-16-2003 06:41 PM
Is it normal for the steering wheel to vibrate while braking? Hazdaz Brakes, Steering & Suspension 34 02-07-2003 11:30 PM
Good Morning.. Is it normal for the clutch pedal to have morning stiffy? PaulRex Tri-State Area Forum 6 12-04-2002 12:41 PM
loud turbo noise. Is it normal for turbo car? myfirstnewcar Warranty Issues & SOA Problems 11 03-07-2002 06:10 PM
Is it normal for a car to smoke after an uppie installation? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2002 03:58 AM
