Old 10-23-2004, 12:07 AM   #1
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Default Swapping Parts from Phase I to Phase II Block
I am swapping long blocks on my 98 Legacy 2.5GT (5-speed). So I went and picked up a used 2.5 DOHC long block out of a 98 Outback (auto). I loaded it up and got it home and realized that it is actually a Phase II block! I am happy to learn this given their overall improvements over the Phase I that I"m pulling out (especially since I only paid $500 for it
This engine has had the intake and cam pulleys pulled from it. I was just wondering if I am going to run into any trouble getting parts from the Phase I to bolt onto the Phase II block (intake, cam pulleys, timing belt, etc)
Also this is my first time pulling an engine from a 5-speed tranny. Are there any bolts I need to take off before I seperate the engine from transaxle (other than bell housing bolts)?
Thanks
Dan
dan_j_b is offline   Reply With Quote
Old 10-24-2004, 12:51 PM   #2
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Well I got everything swapped out last night and everything worked out fine. The only differences I noticed are the different timing belt tensioner system and it appears to be an interference motor (when I turned the crank initially to line it up for the belt I could feel it hit valves in certain spots)
Old 10-24-2004, 07:50 PM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
The 1998 Outback had a Phase I interference engine, that's why you felt what you felt. It had 4 cams, right?
All Phase I DOHC 2.5's are interference. Phase II SOHC 2.5's are NON-interference and I think they were introduced in the Outback in 2000, but came out in 1999.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 10-24-2004, 10:11 PM   #4
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
all DOHC - interference
all SOHC - noninterference
known exception: Phase II EJ22 SOHC , 10:1 instead of phase I 9.5:1 that ran until like 98 or 99 (late model impreza, late 90s) - interference.
JonofScio is offline   Reply With Quote
Old 10-24-2004, 11:28 PM   #5
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
As I said before, it is a PHASE II block with DOHC heads, so it has the higher compression 10:1 pistons. You can say it isn't interference all you want, but you'll have to explain to me what else could keep the crank from turning all the way around with the timing belt off. As I read in several other posts, they used a few of these blocks on the later 98 production models before they switched to the SOHC design.
Old 10-25-2004, 12:38 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
The heads you bolted onto it made it interference. I noticed the same thing when I put mine together. I made sure the crank had all 4 pistons at midstroke before setting cam position. Once those were inplace, I moved the crank to #1TDC and finished the belt routing, etc...
Jay Storm
Old 10-25-2004, 09:20 AM   #7
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Yeah thats what I figured, Jay. Actually I didn't bolt the heads on, this is the way it came from the factory in the 98 Outback it came from.
Old 10-25-2004, 01:20 PM   #8
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Interesting. The Legacy didn't get the Phase II till 2000, and the Outback IS a Legacy. What on the engine leads you to believe it's a Phase II?
DLC is offline   Reply With Quote
Old 10-25-2004, 03:00 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Dave,
I was recently informed of this fluke by the folks a Colorado Component Rebuilders who do nothing but rebuild EJ's all day long. For some reason the '98 and '99 Outbacks got the phase II shortblocks but continued to use the DOHC heads...
Old 10-25-2004, 03:53 PM   #10
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
CCR would know, they probably rebuild more EJs than anyone else in the world. Good to know though, for those who want a factory hybrid.
Old 10-25-2004, 05:30 PM   #11
dan_j_b
Member#: 53069
1998 Legacy 2.5GT
Spruce Pearl Green
Yeah, I had heard about this in old threads before. I could tell it was a phase II block by the single ridge marking on the top of the block, the newer style single piece cam tensioner and the extra tranny mount holes in the back to accomodate the newer trannys. I can't say that I notice a difference with the extra .5 psi compression, but then again, it had been a while since I drove it before the swap.
Phase 1 to Phase 2 questions jhull Subaru Conversions 2 01-28-2009 11:29 AM
2.5 phase 1 to phase 2 swap limeylight Subaru Conversions 12 12-29-2004 06:31 PM
phase 1 to phase 2 swap limeylight Normally Aspirated Powertrain 0 12-29-2004 10:24 AM
Tech Info: EJ22 N/A changes phase I to Phase II? FuJi K Normally Aspirated Powertrain 2 12-12-2004 10:12 AM
Swapping AC parts from a '96 to an '00 kcarton Normally Aspirated Powertrain 0 11-30-2003 10:47 AM
