Old 10-23-2004, 05:58 PM   #1
want-a-fast-svx
Member#: 48156
92 svx
silver and black
Default Crank walk?
I have a EG33 in an svx and was installing a wrx tranny with RA gears and noticed that the flywheel was moving in and out. Upon taking the flywheel off there is aproximately 1/8in. of movement front to back. THis movement is followed all the way through the engine and is visible on the crankshaft pulley. Does this sound like the internals of the engine need to be taken care of or pulled apart i should say???The engine doesn't make any weird sounds the only sound that is made is when the clutch is released there is a grinding werring sound. From searching on here this sounds like a thrust bearing making noise when under load of the clutch being released..Please tell me Im wrong here...
want-a-fast-svx is offline   Reply With Quote
Old 10-23-2004, 08:12 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
So, you're saying that when you push the flywheel, the crank pulley moves?
orndog is online now   Reply With Quote
Old 10-23-2004, 08:28 PM   #3
want-a-fast-svx
Member#: 48156
92 svx
silver and black
yes that is exactly what im saying...
Old 10-24-2004, 04:14 AM   #4
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Time to pull some bolts and make sure someone didn't let the magic smoke out.
Chi_San is offline   Reply With Quote
Old 10-24-2004, 11:23 AM   #5
want-a-fast-svx
Member#: 48156
92 svx
silver and black
what exactly does that mean???
Old 10-24-2004, 12:26 PM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Yes, you need to get that fixed. It sounds like the thrust washer is missing or something. Was this engine recently rebuilt?
OneOBS is offline   Reply With Quote
Old 10-24-2004, 12:43 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
he means it sounds like the thrust bearings in your engine are toast, before you put that motor back in i'd definitely do a full tear down
Old 10-24-2004, 12:45 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
^what he said...
Old 10-24-2004, 02:04 PM   #9
want-a-fast-svx
Member#: 48156
92 svx
silver and black
**** thats unbelievable...I just put this engine in. Its only got 50,000 or so mile on it.. The way i noticed it was from putting in the 5spd from getting ra gears. What would cause something like this to happen to an engine with that amount of miles???
Old 10-24-2004, 07:53 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
lack of frequent oil changes ususally or running it empty on oil.
if you just got it did it have some kind of warranty with it?
Old 10-25-2004, 04:25 AM   #11
want-a-fast-svx
Member#: 48156
92 svx
silver and black
no warranty on it its been in my possesion for about 6months its only been used maybe 3 tops....This engine hasn't even got to see any life what so ever and there has always been oil since i've owned it...Is there anything else that could cause this???
Old 10-25-2004, 04:47 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i don't recall anyone mentioning anything about crankwalk issues on the EG33, might want to call subaru and see what they say about it
Walked crank Question whitfork Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 12-16-2009 09:24 PM
Crank walk, lets talk. reddevil Built Motor Discussion 22 08-18-2007 11:06 PM
EJ25 Crank Walk, true or Myth fzturbo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-17-2006 12:50 PM
crank walk? Heavy Fuji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-28-2003 02:01 AM
crank walk Mt. Fuji WRX Forum Archive 5 02-20-2001 06:44 PM
