Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 06-24-2001, 02:50 PM   #1
jacktam1
Member#: 1783
2000 2.5RS
Default how to bypass coolent on throttle body?
anyone can teach me?
Thanks
jacktam1 is offline   Reply With Quote
Old 06-25-2001, 02:12 AM   #2
Avenger
Member#: 1234
Why are you trying to bypass coolant on the throttle body??
Avenger is offline   Reply With Quote
Old 06-25-2001, 09:04 AM   #3
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Avenger,
It's a pretty common mod that helps cool the temperature of the intake by stopping the flow of hot coolant around the throttle body. I had it done on my Prelude, and the only side effect was a hunting idle at cold temperatures. It made a decent difference, though.
jacktam1,
All you do is find two tubes that go in and out of the throttle body and combine them somehow. There's a number of ways to do this, but the quickest is just to disconnect one totally, and plug the other into where it was coming out of the block, basically creating a single tube of coolant that comes out of the block and flows directly back into the block - effectively useless. If you want to get fancy, you can buy a few more peices of tubing and some T-shaped valves - this way, you can control the flow to the throttle body without having to connect and disconnect tubing.
Just make sure you do it when the engine is as cold as possible. Coolant will spill, and you don't want to burn yourself.
A friend of mine performed this mod on his 2000 RS after I did my Prelude. If I recall correctly, he said it made a difference, and I don't think he had the hunting idle problem I did. I have yet to do it on my RS.
Let us know how it goes. Good luck!
Layman is offline   Reply With Quote
Old 06-25-2001, 01:48 PM   #4
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Exclamation
Just in case anyone was wondering why they run coolant throught the throttle-body: It is to prevent icing. Not because it is cold outside like in the winter time. Any time air goes from an area of higher pressure to an area of lower pressure, it drops in temperature. If you cruise for extended periods of time without moving the throttle plate, it can actually stick in that position for a few seconds! Summer or winter...
subarumantoo is offline   Reply With Quote
Old 06-25-2001, 01:55 PM   #5
elemental
Member#: 2701
'00 obs
so if we live in, oh say, southern california, there should be no downsides?
elemental is offline   Reply With Quote
Old 06-25-2001, 01:59 PM   #6
jacktam1
Member#: 1783
2000 2.5RS
Layman, thx a lot.
subarumantoo:I don't think my TB would be icing during this summer..
Old 06-25-2001, 02:23 PM   #7
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
I did this on my '94 Probe and plan on doing it to my RS. I added two valves, one on each side of the throttle body and a host that connected them.
I never had to worry about re-plumbing the coolant for winter, just throw the valves and it warms the TB back up again
MBX Motorsports is offline   Reply With Quote
Old 06-27-2001, 03:23 PM   #8
sen
Member#: 1216
2007 WRX
WR Blue
Question
Which tube is the inle and which tube is the out let (when you are standing in front of the car)? I have some valves that I am going to put in line to stop the heating for the summer.
sen is offline   Reply With Quote
Old 06-27-2001, 05:18 PM   #9
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
It shouldn't matter which is which. Just put valves in both and open/close them at the same time.
Old 06-27-2001, 07:16 PM   #10
cvalle-sd
Member#: 420
2001 Cr-V
I just bypassed mine, and there was coolant in the driver's side hose, and not in the pass. side, so I assume that it flows from driver's -> passenger's. I got a brass hose fitting (double male) from AutoZone for $1.69, took off th airbox, and spliced 'em right up - 10min job.
cvalle-sd is offline   Reply With Quote
Old 06-27-2001, 07:36 PM   #11
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
Don't suppose you notice any improvements from this?
Scoob_13 is offline   Reply With Quote
Old 06-28-2001, 06:58 AM   #12
sen
Member#: 1216
2007 WRX
WR Blue
PICS?
Old 06-28-2001, 02:14 PM   #13
RS2001
Member#: 3210
01 RS Coupe
05 WRX Wagon
I also did this to my Honda. I can't say for sure I noticed any gains, because I think I did it at the same time I switched to a CAI extension.
But yes, I think it's a good mod as long as you're not living somewhere with cold temps. I'll probably do it when I get my Ganzflow.
-DAN
RS2001 is offline   Reply With Quote
Old 06-28-2001, 03:08 PM   #14
ImprezedRS
Member#: 2771
2003 BMW Z4
yeah any pics? and what is icing?
ImprezedRS is offline   Reply With Quote
Old 06-28-2001, 03:58 PM   #15
elemental
Member#: 2701
'00 obs
ice... as in, moisture in the air gets frozen, coats the TB
Old 06-28-2001, 09:27 PM   #16
IBO
Member#: 5449
2002 Aspen White
2.5RS
Remember me? We met at Motor-R with Devo-2nd Gen. I am just wondering, what are you doing this for?? I had my throttble bored too.
IBO is offline   Reply With Quote
Old 06-29-2001, 03:32 AM   #17
jacktam1
Member#: 1783
2000 2.5RS
sure man..
I'm doing this because the coolant is hot, it can reduce the heat on TB if the coolant don't go into it.
Old 06-29-2001, 08:55 AM   #18
IBO
Member#: 5449
2002 Aspen White
2.5RS
Cool... Are you going to do it by yourself? Or you're gonna take it to the shop again? If you have done, do you mind me take a look at it? I guess I could use the same thing.
Old 06-29-2001, 09:32 AM   #19
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
People who are considering this mod,
I think perhaps it's sounding more difficult than it is. Just go out to your car and locate the throttle body. There should be two tubes connected to it that carry coolant. Once you've found those, you're halfway done! Just combine those tubes somehow. It is incredibly easy. You can do it in under 5 minutes, trust me. You shouldn't need any pictures and you certainly shouldn't take it to a shop to be done.
Again, just be sure to do it when the car is cold - like first thing in the morning.
If you need a better writeup, go to
http://members.tripod.com/~Pre_ludE/pmods.html
and scroll down to throttle body mod. I promise, this is something you can easily do yourself.
Old 06-29-2001, 01:14 PM   #20
jacktam1
Member#: 1783
2000 2.5RS
IBO:sure
Layman: do I need to seal the holes on the TB or just leave its open?
Old 06-29-2001, 01:54 PM   #21
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Well, I kept it open on my Prelude, but if you want, I'm sure putting some sort of cap on the throttle body wouldn't hurt anything.
How to bypass airbag so it still works on passenger side brujo65 Newbies & FAQs 5 11-05-2009 06:20 PM
How to knife edge your throttle body butterfly valve. reddevil General Community 4 02-22-2006 02:10 PM
whats the correct way to fill coolent on wrx with two radiator caps? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-19-2004 06:17 PM
silicon on throttle body atomicapples Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-04-2002 03:19 PM
bypass coolant on trottle body t.rod Normally Aspirated Powertrain 6 03-31-2001 09:53 AM
