Old 10-24-2004, 12:29 PM   #1
scuby
Member#: 58476
02 wrx
Default soft brake pedal
When I bought my secondhand WRX I noticed that the brake was very soft.Then I changed brake fluid, brake rotor and pads. Now there is a slight improvement. The brake is soft only first time when applied, after that it is fine. But if I dont apply it for a few moments it becomes soft again. Are there any suggestions how to keep it firm all the time?
scuby is offline   Reply With Quote
Old 10-24-2004, 12:45 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
sounds like there is air in the lines. You might want to try bleeding the lines again.
Legacy777 is offline   Reply With Quote
Old 10-24-2004, 05:37 PM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
if you did it yourself and couldnt get the fluid out take it to a shop and have them do it....
or rebleed it youself and when you are bleeding get a ballping hammer and Barely(i mean slightly) tap your Master Cylinder, and Calipers to get all the bubbles that might be stuck to the inseides to brake away...
also are you Manual bleeding it, or vacume bleeding it?
snowman4us is offline   Reply With Quote
Old 10-26-2004, 03:01 PM   #4
scuby
Member#: 58476
02 wrx
I did manual bleeding.But I doubt there is any air because it is like that from the first day.maybe there is a problem with the brake lines.They could be too soft?
Soft Brake Pedal YooperBaja Baja Forum 7 06-03-2007 02:41 PM
Soft brake pedal DiscoGsus Brakes, Steering & Suspension 3 10-19-2006 03:20 PM
soft brake pedal tcspeer Brakes, Steering & Suspension 4 07-14-2006 11:36 PM
soft brake pedal 4x4x4x5 Brakes, Steering & Suspension 7 01-10-2001 10:50 AM
Soft Brake Pedal Frey Brakes, Steering & Suspension 6 10-17-2000 09:51 AM
