Old 10-24-2004, 12:38 PM   #1
engr
Member#: 62911
Default downpipe to transmission bolt on 4eat?
I purchased a used downpipe and gutted it for my 02 wrx.. I drive a 4eat and the downpipe I got used was from a manual.. The downpipe hanger to the transmission doesn't fit.. so I cut it off...
Does anyone know if this will be a problem?
Does all the aftermarket dp use the transmission hanger?
Thanks.
engr is offline   Reply With Quote
Old 10-25-2004, 11:51 AM   #2
engr
Member#: 62911
any input would be appreciated...
at least tell me if your DP has that hanger?
Anyone?
Thanks.
Old 10-25-2004, 12:08 PM   #3
forsaken
Member#: 50310
Dont worry about it. Most if not all Aftermarket Downpipes dont use the Transmission bolt/hanger
forsaken is offline   Reply With Quote
Old 10-25-2004, 02:57 PM   #4
awdboxer
Member#: 38425
2015 WRX
Lightning Red
If it's not rattling or rubbing against anything I wouldn't worry about it to much.
awdboxer is offline   Reply With Quote
Old 10-25-2004, 04:04 PM   #5
wonny
Member#: 50241
2004 WRX
Java Black Pearl
I didn't put mine back on (5MT) when I took the DP off - that bolt is a biatch to get in!
wonny is offline   Reply With Quote
Old 11-06-2009, 03:13 PM   #6
sc_frontier
Member#: 227641
2004 Wrx
I am looking for the same answer. I bent my brace up and out of the way. What about the second brace that is under the car next to the O2 sensor? Does it fit on the rear downpipe? The car came with an injen downpipe.
sc_frontier is offline   Reply With Quote
Old 11-06-2009, 04:01 PM   #7
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Without that bolt in place on the hanger, more stress will be put onto the bolts that connect the DP to the turbo.
Brock31 is offline   Reply With Quote
Old 11-07-2009, 02:13 PM   #8
ericsitemsforsale
Member#: 229265
It's not a big deal. The only problem not having that hanger secured to the tranny is slight gasket leak over time especially if your engine mounts are shot and your engine moves around a good bit.
ericsitemsforsale is offline   Reply With Quote
Rounded a flexplate bolt on 4EAT mc2 Normally Aspirated Powertrain 1 04-05-2009 01:34 PM
Anyone know the downpipe to transmission bolt size? xcdhridr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-15-2007 03:50 AM
Downpipe to turbo bolt torque? pillarguy17 Newbies & FAQs 7 06-03-2007 10:01 AM
downpipe to transmission bolt MustGoFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 07-18-2006 01:14 PM
Downpipe to tranny bolt size? Houdini Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-07-2004 09:16 AM
