Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 10-24-2004, 03:17 PM   #1
teh Phil
Member#: 24888
Question Oil Pump Replacement?
I think my oil pump may be dying, my oil pressure has a tendency to get a little low, but it rises with acceleration. Do I need any special tools for this, or is it pretty straightforward?
teh Phil is offline   Reply With Quote
Old 10-24-2004, 04:28 PM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
You dont need any tools to do the pump itsself (make sure to get new O-rings to install the new pump with) but you will have to re-do the timing belts which required tensioning the pully / timing belt before tightening the bolts on the tensioner pully. (if that makes sense)
Flowmastered87GL is offline   Reply With Quote
Old 10-24-2004, 05:03 PM   #3
teh Phil
Member#: 24888
So would I be correct in assuming the pump is behind the fluctuating oil pressure, or could there be something else?
Old 10-25-2004, 01:19 PM   #4
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Probably the oil pump / oil pump gaskets
Old 10-26-2004, 01:24 PM   #5
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Most likely the oil pump and/or gaskets. You should be hearing plenty of valve tapping already.
But if you replace that and the oil pressure is still low (using a properly installed testing gauge and not the one in the car) then your engine bearings may be worn out.
DerFahrer is offline   Reply With Quote
Old 10-30-2004, 05:35 AM   #6
MilesFox
Member#: 64965
87 87 RX 95 Legacy
duplicolor, aluminum
MilesFox is offline   Reply With Quote
EJ20G oil pump replacement oldhat Pre-2002 Factory Turbo Powertrain 9 01-16-2008 12:06 PM
replace oil pump at 117,000mi.? billtrev Service & Maintenance 5 12-08-2005 05:49 AM
2.2 oil pump replacement TrickNipple Normally Aspirated Powertrain 3 07-14-2005 06:36 PM
Replacing Oil Pump on 1.8L - Advice Needed speedblind Service & Maintenance 10 06-06-2005 10:08 PM
Replaced front main seal and oil pump o-ring archer Normally Aspirated Powertrain 4 12-28-2001 03:28 AM
