Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-24-2004, 10:46 PM   #1
chip4761
Member#: 55867
2005 Saabaru
AS
Default Beating a dead horse with vehemance swap thread!!
Okay, so here's the deal. I have a '94 wagon that I swapped an ej22 into in August. I'm looking for more HP, and have a couple of options.
1: I take the heads from the ej18, get a good PnP, regrind the cams, thinner headgasket, etc etc. Looking at higher compression, would need to hack the ecu to get to effective rpm levels. HP levels? Dunno. No one has done it to my knowledge. Cost? I think somewhere around $650 if all goes according to plan.
2: Find a cheap ej25, replace headgaskets, leave everything else the same. Hack the ecu for a higher redline, buy an SAFC-II to cure the rich burning woes of the ej18 ecu. HP? I guess 165, maybe a touch more with my pulley and intake. Cost? Depends on the engine's cost. If I could find one for $500, then everything would cost somewhere around $800
3: Wait till I finish grad school, find a good job, buy a house with a big garage, and do V* swap. This could be fun, but I don't consider it much of an option, as I want more go power NOW, not in 2 years.
The other thing I need to start thinking about is a new tranny. The one I have in there has 192K +. Things are starting to feel a little sloppy. I want a read LSD. Best cost to options ratio? Input please!
chip4761 is offline   Reply With Quote
Old 10-24-2004, 11:54 PM   #2
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
go turbo !
AsphaltsCry is offline   Reply With Quote
Old 10-25-2004, 12:36 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
three.. but i am biased
Old 10-25-2004, 01:06 AM   #4
chip4761
Member#: 55867
2005 Saabaru
AS
But that's two years. TWO YEARS!!! Could you wait that long? Besides, in two years, even if I did do an ej25 swap now, I would probably have both the time and the money to do an ej20.
The benefit of doing no.1 would be the fact that I would pretty much be the only person with that setup. The downside, I would pretty much be the only person with that setup. I'm not sure I want to blaze any trails right now without any backup-mobile.
Any thoughts on the transmissions? Links to threads?
Old 10-25-2004, 12:10 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
meh prey on the young coeds instead
you won't be able to do that in 2 years
Old 10-25-2004, 02:04 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
EJ25 is my choice...two years is a long time.
Old 10-25-2004, 02:18 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
#2 under the circumstances. And unless you get some cams, there is not point in bumping the redline...
Old 10-25-2004, 08:45 PM   #8
chip4761
Member#: 55867
2005 Saabaru
AS
Jaxx- I'm in a committed relatioship. If I weren't, I think I'd go that route.
Homemade WRX- Know where I can get one? I'm sure someone must want to get that pesky paperweight out of the back of their garage. Hey, I'll even give you money for it.
Matt- If I get the regrind, I would need more RPMs, right? I was reading an interesting post about a guy who did some stuff to his ej22. I'm just guessing that opening up my intake passages really wouldn't be that much of a benefit unless I can get the engine up to a high enough rpm to suck in enough air to balance out the loss of torque I'm going to experience.
Old 10-25-2004, 08:51 PM   #9
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
low boost wrx turbo kit?
DoctorNick is offline   Reply With Quote
Old 10-25-2004, 09:13 PM   #10
chip4761
Member#: 55867
2005 Saabaru
AS
It cheaper to do a whole WRX swap.
I'm beating a dead horse with this one, but..... Mauricio Texas Impreza Club Forum -- TXIC 18 01-25-2002 01:29 PM
Ok, to beat a dead horse one more time......... ARG Brakes, Steering & Suspension 16 06-23-2001 10:02 PM
Let's beat this dead horse again, Larry ;)...N/A v. mild turbo HamFist General Forum Archive 52 02-18-2001 02:09 PM
Not to beat a dead horse with a stick but... Eric SS General Forum Archive 21 12-13-2000 09:31 AM
