Old 10-24-2004, 09:57 PM   #1
subiedreamin
Member#: 20407
1999 RS w/ V8 STI
Default cobb stage 3
I recently came into some money and I was thinking of doing the stage 3 route on on my 99 rs. I know there are tons of threads about the price differences between an engine swap and aftermarket f/i but i'm wondering that if i go that whole route with the cams, heads, and maybe add the valvetrain, would I be getting close to the limit of the bottom end?
At what point hp wise would i really need to think about a new crank/pistons/rods?
I love the way a n/a car drives and I think i would like to stay that way but it looks like it starts getting way more cot efective to just look at droping a sti motor in and being done with it.
subiedreamin is offline   Reply With Quote
Old 10-25-2004, 12:54 AM   #2
dkl
Member#: 63096
1998 2.5RS
Green
I would say check out the AVO turbo kit. You would be able to hang with stock STi's, and lag is virtually non-existant (the spool is at ~2000rpm). Check out RalliTek to confirm price and all. They know what they are talking about. I've talked to a number of people who have said that as nice as it is to have bragging rights w/ an NA car, it's not worth the money and effort. As for your original question, the stock block is pretty tough. I know an NA guy who has a full build and went through 12 bottles of nitrous before popping his block.
dkl is offline   Reply With Quote
Old 10-25-2004, 02:40 AM   #3
Diabolical1 CC
Member#: 59897
shouldn't this be in a turbo thread?
Diabolical1 CC is offline   Reply With Quote
Old 10-25-2004, 08:02 AM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Post
No, I don't think he wants to go turbo, initially anyway. I have an opinion, which adds nothing to this post, but I have to bring up the open deck block issue yet once again. Sure you can do it (turbo), some have had a 2.5 RS turbo set-up for awhile, yet, I'd swap.
USDM EJ20 Swap Instructions
Conversions FAQ
EJ20 Swap Info
WRX swap into '99 RS
-Charles-
ImprezaVA is offline   Reply With Quote
Old 10-25-2004, 06:27 PM   #5
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
You could replace the stock cams, pulleys, and etc. check out www.xcceleration.com in the rs section, they got a pretty good package that puts down 80 wheel hp but it is pretty damn expensive.
Caplin 2.5 is offline   Reply With Quote
Old 10-25-2004, 07:27 PM   #6
subiedreamin
Member#: 20407
1999 RS w/ V8 STI
Yea i know i 'can' do that but the way i feel is if i have to pull the engine to do the cams migt as well spring for the heads and maybe the valves/springs. I am just thinking of how close to the limit of the rest of the stock internals you know.
Old 10-25-2004, 08:00 PM   #7
Caplin 2.5
Member#: 71203
2005 2.5rs
if you don't want to take the engine out you could always go with more simple upgrades like , Cold Air Intake, exhaust, removing cats, headers, and maybe an ECU.
Old 10-26-2004, 12:38 AM   #8
Section 8
Member#: 821
Only if you decide to raise the redline (or get some more agressive cams, TWE recomends that you replace the springs with their lumpier cams).
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 10-26-2004, 12:39 AM   #9
Section 8
Member#: 821
Or go crazy with t3h NAAAAAAAWS.
Old 10-26-2004, 11:10 AM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You do realize that those guys are selling TWE parts, right? Buy them from TWE or Rallitek. I hear nothing but questionable things about xcceleration...
Old 10-26-2004, 11:49 AM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
p.s. better order them now since Cobb heads generally take 4-6 months...
2006 WRX Cobb stage 3 (VF39+STI TMIC) 12.3 quarter mile. Bala Proven Power Bragging 139 10-06-2006 01:28 AM
INFO: Which will come first, Cobb Stage 3 or Prodrive Stage 4 Bad Dogg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-25-2005 10:52 PM
alternative to cobb stage 3 block and heads? Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-10-2002 02:49 PM
Cobb Stage 3 Suspension Testing downeyer Brakes, Steering & Suspension 10 05-05-2002 06:19 PM
cobb stage 3 rupteur7000 Normally Aspirated Powertrain 0 04-30-2002 01:28 PM
