Tire & Wheel Forum sponsored by The Tire Rack |
10-25-2004, 12:29 PM | #1 |
Member#: 48270
TXIC
Vehicle:2003 CBR600RR White |
Tire Help
Ok, i got a set of 18x7.5 volk LE28's. offset is +33. which i know sounds low, but it said it would fit on the rays website, also a few other sources, and also the wheel fitment guide for the sti. i ordered some 235/40/18 yokohama avs's. is the rubbing gonna be bad? if any rubbing? i know it isnt an extemely bigger tire than the stock 225. but just curious if anybody knows.
to add i am getting tein flex suspension, hopefully it will come in the next few days or so, but i will be lowering the car also, not extremely low. probably just even out the front with the back.
10-25-2004, 12:52 PM | #2 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
a 33mm offset is way too low for a Subi ... yes you will have tire rub issues and yes they will be quite extensive
10-25-2004, 01:31 PM | #3 |
Member#: 48270
TXIC
My only problem is this, u told me this once before, but my question is, why does it say it clears the brembo's on the rays website. check here
the rims are 18x7.5 10 spoke +33 offset. http://rayswheels.co.jp/cgi-bin/cgi/...odelName=CE28N also here STi Wheel Fitment Guide on NASIOC |
10-25-2004, 04:50 PM | #4 |
Tire Rack Moderator
Member#: 1215
it might clear the brakes but, that doesn't mean that is a correct fit for the car ..... I know of a couple zero offset wheels that will clear also but they do not fit correctly
10-25-2004, 10:39 PM | #5 |
Member#: 48270
TXIC
fits good. doesnt rub.
I need some tire help/advice from you tire gurus. | brucelee | Off-Topic | 50 | 07-25-2008 02:49 PM |
Tire help looking for cheap summer tire | elohdaeh78 | Tire & Wheel | 11 | 05-23-2008 11:58 AM |
Need tire help - widest tire on 17x8 wheel? | Zspectrum | Tire & Wheel | 17 | 11-04-2007 03:05 PM |
I have 4 right side tires! Help with tire direction. | JjSwee | Tire & Wheel | 11 | 12-20-2004 04:26 PM |
New Tires Help. Trackable-Max Performance Tires | Paisan | Tri-State Area Forum | 23 | 01-09-2003 09:16 AM |
