Old 10-25-2004, 04:03 PM   #1
stoney98
Member#: 65888
2010 FXT
Default Removing stock silencer
I've searched and could not find a conclusive answer to my question.
Stock TS 2.5L
I removed my stock airbox/silencer and noticed an imediate improvement in power. Few questions though.
1. Will removing my silencer/airbox froce my mixture to run thin?
2. How should this effect my mileage? and why?
3. Are there any negatives other then a louder engine that I should be worried about?
4. Will this effect emissions? I need to get my smog done soon.
Thanks, I know alot of the questions have easy answers, I just couldn't find them.
stoney98 is offline   Reply With Quote
Old 10-25-2004, 05:48 PM   #2
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
1: yes it is possible. did you reset your ecu?
2: it should stay the same or get better because the engine is breathign more freely.
3: no.
4: no.
Crash477 is offline   Reply With Quote
Old 10-25-2004, 06:29 PM   #3
stoney98
Member#: 65888
2010 FXT
thank you. I will look into resetting my ecu.
Old 10-25-2004, 08:07 PM   #4
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I would do this so you get cold air.
RS_to_WRX_swap is offline   Reply With Quote
Old 10-25-2004, 08:58 PM   #5
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
did you remove your air filter?
Caplin 2.5 is offline   Reply With Quote
Old 10-25-2004, 10:27 PM   #6
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
No its still in the stock location, with a K&N panel filter.
Old 10-25-2004, 10:43 PM   #7
Handsdown
Member#: 29355
seriously, go get some pvc pipe and run it to the fender. the difference in power is very very noticable, i did the exact same thing and you only think you're making power, but you aren't until it gets the colder air.
Handsdown is offline   Reply With Quote
Old 10-25-2004, 11:04 PM   #8
nySulli
Member#: 32617
2008 STi
you will notice a small decrease in mileage, simply because your ecu will correct things for the increased amount of air flowing into the motor, other then that, there aren't any drawbacks
nySulli is offline   Reply With Quote
Old 10-26-2004, 12:47 AM   #9
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
to reset just disconect the negative battery terminal, then depress the brake pedal 5 or so times to drain the power from the car. then reconect the neg. terminal and go for a drive.
Old 10-26-2004, 10:25 AM   #10
jamesfacts
Member#: 51282
98 RS
black & blue from parking
This will not completely drain the ECU. After pumping the pedal, charge may still linger for up an hour or so.
jamesfacts is offline   Reply With Quote
Old 10-26-2004, 02:30 PM   #11
Handsdown
Member#: 29355
when i installed my spark plugs the battery was out for about 45 mins(impossible to reach cylinders 2 and 4 without removing it) and without touching the brake pedal or anything it sure as hell reset. just disconnect it and leave it for a while.
Old 10-26-2004, 03:07 PM   #12
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
yeah disconect while you are working is the best way.
Old 10-26-2004, 03:19 PM   #13
jamesfacts
Member#: 51282
98 RS
How do you know it reset? I'm telling you from experience it can take a long time for charge to leave the system, even w/ the brake trick.
Old 10-26-2004, 04:01 PM   #14
stoney98
Member#: 65888
2010 FXT
Thanks guys. I'll put in the PVC sometime this week. Any suggestions on easiest ways? Especially with the angle change to reach the filter? Any particular ways to mount it to the fender?
Old 10-26-2004, 04:05 PM   #15
Section 8
Member#: 821
Milage will increase with any modification that allows less vaccum for the same throttle plate position in the throttle body. THe computer putting more fuel into the engine, obviously uses more gas per mile, UNTIL you follow through and figuer out what that means. You are getting more air and fuel into the engine, thus generating more power. More power will make you go faster for the same throttle position. You do not want to go faster, you want to go the same speed, so you use LESS throttle to go ghte same speed. If you have 2 imprezas, the same weight, and the same drag coefficent one with 5 billion horse power one with 125 HP. It doesn't matter which one you drive at 55 MPH, they are going to require the same ammount of HP to the wheels to sustain 55 MPH. With engines with very close brake fuel consumption, they will use the same ammount of fuel to generate that HP needed to sustain a certain velocity.
THe fuel effeciency has nothing to do with horse power, fuel or air in a properly tuned engine. It is all about air entering the engine. With identical engines, the engine with the least amount of "drag" in the intake structure is going to use less engine power to draw air into itself, this power inturn is used for driving the wheels resulting in greater effeciency per volume of fuel.
If you have seen a decrease in milage from mearly an intake, it means your "intake" is junk, or you drive harder to listen to it.
THe same is true for an exhaust to a certain extent.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 10-26-2004, 09:05 PM   #16
stoney98
Member#: 65888
2010 FXT
anyone? I swear I'm not a ricer, I would just prefer to learn from others wisdom.
"Experience; that most brutal of teachers. But you learn, my God do you learn. " -C.S. Lewis
Old 10-26-2004, 09:44 PM   #17
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
First off you want ABS (black) not PVC (white) pipe. I personally have had good luck with 3 inch, but it is loud and requires modifying of the air box. Since the stock intake size is 2.5 inches, 2.5in ABS pipe with a 30 degree elbow and 2.5in rubber connector should suit you well (version 1 in link below)
Where the ABS goes into the fender, use any old hose; cut a slit down the side and line the circular hole with the hose. This stops most vibrations. I will have pics of this soon.
More info on my intakes here: http://forums.nasioc.com/forums/showthread.php?t=604352
Old 10-26-2004, 11:43 PM   #18
Handsdown
Member#: 29355
because my CEL was cleared. that only happens with a reset. also, the car learned how to mix the newer intake with the cold night air MUCH better than it had, there was noticible power all across the rev range, and it no longer leaned out at higher RPM(at least not as much)
RStoWRX- why ABS instead of PVC? i couldn't find any 2"abs and it's much harder to cut(i have no hack saw, i cut mine with a shoelace... no lie.)
Old 10-27-2004, 12:29 AM   #19
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Shoelace....HA HA HA
1. 2" is smaller then stock (2.5"), why are you wanting to detune your car? go with 2.5", same as stock but straight, or 3"; huge hp gain in the last 2k rpm(4750-6750), with a small loss of torque under 1500 rpm.
2. Why ABS plastic? PVC releases harmful gasses when heat is applied. ABS is closer to the stock intake material as well. ANY kind of metal intake is bad, it just gets too hot. Thatís why almost no cars have metal intake from the factory.
3. Get a friggin saw.
Edit; oh wow I'm a Scooby specialist now.....Iím turning into a nerd
Old 10-27-2004, 01:15 AM   #20
rabbitnutz
Member#: 51940
Thatís why almost no MODERN cars have metal intake from the factory.
rabbitnutz is offline   Reply With Quote
Old 10-27-2004, 01:20 AM   #21
Handsdown
Member#: 29355
if i can find some ABS in 2" i'll switch... but for the second time, it's not a downgrade to go from a 2.5" with boxes and turns and baffles and silencers to a 2" straight through pipe. the 2" pipe flows better than the baffle at mid and high rpm.
Old 10-27-2004, 01:55 AM   #22
jamesfacts
Member#: 51282
98 RS
You must have a low charge ECU then, ( ) becuase none of the ones I've reset have gone in <25mins.
Old 10-27-2004, 02:04 AM   #23
Handsdown
Member#: 29355
i said 45 mins...
Old 10-27-2004, 05:49 PM   #24
rsti02
Member#: 71329
2002 rs
so how does the power increase of this diy intake compare to cobbs
rsti02 is offline   Reply With Quote
Old 10-27-2004, 05:54 PM   #25
Handsdown
Member#: 29355
cobbs is a whole lot better, since the filter is a different element and it doesn't use the box.
Trying to remove intake silencer, having some trouble removing the fender liner sportz135 Newbies & FAQs 22 06-15-2005 08:15 PM
Stock silencer removal... IMPEXRALLY Newbies & FAQs 3 12-16-2002 10:45 AM
Operation Remove Stock Silencer BryanD New England Impreza Club Forum -- NESIC 5 08-07-2001 11:08 PM
Removing Intake Silencer BJamerican Normally Aspirated Powertrain 1 04-08-2001 09:16 PM
