Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 10-25-2004, 05:28 PM   #1
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Default MY05 WRX center dash vent removal for gauges??
how do you remove the center dash vents on the MY05 WRX, because i am installing gauges soon and would be easier if the vents were not in place so i can access housing easier for running wires?
thanx,
justin
joostin420 is offline   Reply With Quote
Old 10-25-2004, 10:13 PM   #2
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
You must first remove the shifter trim (pull the back up and then out), then the trim around the radio (2 screws at the bottom and then pull out), and then the vents can be removed. Keep in mind that removing the vents will not buy you any more room since the vent duct directly behind the vents stays in place. I just installed the factory triple gauges and there was plenty of room without removing the vents.
-Jeff
jac04 is offline   Reply With Quote
Old 10-25-2004, 11:59 PM   #3
joostin420
Member#: 1046
2007 WRX Wagon
UGM
kewl, i knew the first 2 steps. mounted my kartboy lever from my MY03 sedan into my MY05 wagon in about 25-30min. so i just wanted to know if i should expect anything different than usual than previous years. reason i ask about removing the center vents, arent there some clips up under if you push them it is easier to remove the clock to put the gauge housing in place?
orginally i had done this setup in my MY00 RS, it had a lexan faceplate so it looked real good:
in my MY03 wrx sedan, i did the Autometer Apillar housing when it was released:
i am going back to the center housing, with another custom lexan faceplate for my wagon.
thanx,
justin
Wtb:ac Center Dash Vent 05-07 Sti davidsti1 Private 'Wanted' Classifieds 1 04-26-2010 03:29 PM
Dash vent removal Delton505 Newbies & FAQs 2 03-01-2010 08:05 PM
WTB: GC Impreza center dash vents fantasticfour Private 'Wanted' Classifieds 1 07-02-2009 04:14 PM
Dash Vent Removal Roy Service & Maintenance 1 01-02-2007 07:30 PM
wtb: center dash vent plastic/surround LatentWagen Tri-State Area Forum 5 08-08-2005 09:24 AM
